Old 01-28-2013, 08:55 AM   #14206
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,040
money is no object.
I'd like to be able to say that...at least once in my life
alas, it always seems to be - an "object" that is.
Ladder106 is online now   Reply With Quote
Old 01-28-2013, 04:52 PM   #14207
happyclam
happyclam's Avatar
Oddometer: 169
Originally Posted by Dr E View Post
If you are looking for the 250/400/450 shocks, you need to make sure that the nitrogen reservoir is either remote like mine or points downward away from your frame. You will see that many of the EBay shocks are later model shocks and they angle upwards...this will hit your frame and not work.
Best of luck on your search!
Thanks for the heads up. Your bike is coming together beautifully.
happyclam is offline   Reply With Quote
Old 01-28-2013, 05:01 PM   #14208
happyclam
happyclam's Avatar
Oddometer: 169
Originally Posted by MookieBlaylock View Post
i got a wilbers type 641 w/ all kinds of adjustments,damping, rebound and remote height adjust, that i pretty much set and forget but really to nice to have for fine tuning .
Eventually, or maybe sell the vstrom to free up some cash.
Old 01-29-2013, 05:39 AM   #14209
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
Originally Posted by happyclam View Post
Eventually,
yea i figured it was worth it. Of all the 10 or so bikes I've had the TA is the keeper so a little extra refinement worth any price,almost
MookieBlaylock is offline   Reply With Quote
Old 01-30-2013, 03:41 AM   #14210
AppFan
Oddometer: 396
Getting ready to order the Ricor Intiminators for the stock forks (1989).
Is one quart of fluid going to be enough or does it take slightly more? Knowing my luck I figure it'll be better to check first......
AppFan is offline   Reply With Quote
Old 01-30-2013, 07:58 AM   #14211
Ladder106
Ladder106's Avatar
Oddometer: 5,040
If my memory serves, 1 qt is just barely enough. It depends on where you set your oil level.
Since the front of my bike is heavier than a normal TA and I hate fork bottoming, I set mine up with a bit higher oil level than normal.
Don't remember the air gap measurement but I think 115 mm. Standard is, I believe, 125 mm. All measurements suspect due to corrupted hard drive in my head.
Old 01-30-2013, 12:17 PM   #14212
mas335
xendurist
Oddometer: 1,998
The shop manual states 18.6 ozs. per leg, ( 125mm - 4.9" oil level) so 1 quart is not enough.
Transalps
mas335 is offline   Reply With Quote
Old 01-30-2013, 01:57 PM   #14213
wdeTA
TransAlp Adv
wdeTA's Avatar
Oddometer: 473
Intiminators
When I installed mine it took more than the 1 qt. provided. Amsoil Fork oil was hard to find locally. I had the progressive springs in though, not sure if that makes a difference. I would recommend just getting the second qt now. If you don't need it now, you'll have it for later when you change out the fluid.
Dale
89 Transalp
01 XR400R
http://daleeva.smugmug.com/Motorcycle
wdeTA is offline   Reply With Quote
Old 01-30-2013, 03:08 PM   #14214
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,178
Set mine the same.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 01-30-2013, 03:34 PM   #14215
AppFan
Oddometer: 396
Thanks all. Two quarts it shall be!
Old 01-31-2013, 06:09 AM   #14216
Iron_Floyd
BIG ENDURO FREAK
Iron_Floyd's Avatar
Oddometer: 22
This is No. 1 Transalp mods thread on the Internet! I'm following this thread for about a year now, and I'm very pleased to post some of my mods and upgrades here.
So, here we go
In the year of 2012, it was 20 February ( I remembered it because it was my birthday), I had crash on the snow with speed of about 25 to 35 km/h. When I started that little journey of 45 km to my home that day, It was chilly but very nice weather for daily ride. But unbelievably, after 20 km of sunshine road, I was suddenly hit by snow blizzard. Anyway, a fell first time, the second time, and the third time was the hardest hit to road. I was absolutely fine, but I didn't believed how easily everything cracked. The fairing was cracking like it was made of glass. The outside temperature was about +2 degrees centigrade, and the aftermath is... the side cases were givi and completely destroyed, the right crash bar took a major damage and also damaged my side panel fairing, and because of side cases, motorcycle roll over on the front windshield destroying it completely, and my front faring was also heavily damaged. And when I picked up a bike, and put it on side stand, it fell again... I was like ... put it upright again and realized that side stand snapped!
So, here is is the picture 20 minutes before crash that day
And pictures about 2h hours after getting home...
And what left from side case's
In one hand, I was like.. omg my trusty old honda , and in the other hand I was glad that happened near my home.. because otherwise the same crash as that could and my journey anytime.
Repairs and mods:
So, the side stand.... more rusty than trusty... and do you believe that whole your bike is sitting on this thin wall tube crap???
On the left is the tube with thicker wall that replaced old one, and on the right side of the picture is original hoooonda.. snapped tube..
And finished moded side stand with thicker tube, and bigger surface mud/sand proof surface but still unpainted, only rust protected
It will be continued
Iron_Floyd screwed with this post 01-31-2013 at 07:11 AM
Iron_Floyd is offline   Reply With Quote
Old 01-31-2013, 06:40 AM   #14217
Iron_Floyd
BIG ENDURO FREAK
Iron_Floyd's Avatar
Oddometer: 22
Fairings repair:
Some plastic parts ware missing, left somewhere on the road, so I had to rebuilt it.
And job well done
The same story done on the front:
Welded the plastic
Filled in, and sanded
There was also dent on my tank... it was real pain in the ass to pull that out.
And it was sucessfull torchure without painting and sanding. I just pulled the dent out.
Fixing a big hole that exhaust pipe melted from the front cylinder. The hole can be seen in right corner of upper picture
It looks good as new
Iron_Floyd screwed with this post 01-31-2013 at 07:33 AM
Old 01-31-2013, 07:00 AM   #14218
Iron_Floyd
BIG ENDURO FREAK
Iron_Floyd's Avatar
Oddometer: 22
Just take look again at this junk design...
I decided to mod it and to make it much more reliable, but not to weld it to a frame. The previous design was to hang on bolt that was attached trough radiator... very bad and vary sad solution, the fell could tear it trough. So I made a piece that attaches to frame. It was made from 11 mm thick ship steel.
And completely modified the crash bars so they are wider.. far from side fairing
Also made it more harder with another parallel pipe in place
Crash bars (roll bars), painted and ready to roll
And, everything put togeather again
But, the windscreen was still missing
And finaly, after few months... a new very well made windshield
Iron_Floyd screwed with this post 01-31-2013 at 07:35 AM
Old 01-31-2013, 07:05 AM   #14219
Iron_Floyd
BIG ENDURO FREAK
Iron_Floyd's Avatar
Oddometer: 22
Here are some latest photos of my alp
http://advrider.com/forums/showpost....&postcount=369
and short explanation of my other gadgets currently in place.
http://advrider.com/forums/showpost....&postcount=371
I will post that mods later Cheers
Iron_Floyd screwed with this post 01-31-2013 at 11:54 AM
Old 01-31-2013, 07:50 AM   #14220
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,705
Floyd nice plastic repair!
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is online now   Reply With Quote
Times are GMT -7.   It's 09:49 AM.
