Old 09-01-2012, 06:08 PM   #301
Dastard
Just another guy
Oddometer: 560
Send a message via MSN to Dastard
Dude, you are awesome. Good luck with the new build
D
WR250R converted to X
S10 (the faster, sexier, more awesome BLACK one). Its like a mustache, with titties!!
Dastard is offline   Reply With Quote
Old 09-03-2012, 01:37 PM   #302
TipsyMcStagger
TipsyMcStagger's Avatar
Oddometer: 957
Glad to see you're healing. This has been one of my favorite builds.
Looking forward to following along with the rebuild!
Tipsy
2008 Buell XB12X Ulysses
2008 KTM 450 EXC-R
"There's a plane! Where there's a plane there's probably a pilot! Where there's a pilot there must be a bar! I can finally get a drink!" - Brian from Family Guy
TipsyMcStagger is offline   Reply With Quote
Old 09-03-2012, 06:46 PM   #303
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,306
Send a message via AIM to johnwesley
Tipsy
Thanks, I have said if I ever did this again that I would do some things different. Now I have the opportunity. have a call in on a good frame with title so we'll see where that goes.
Should I keep it here or do a new build thread?
johnwesley is offline   Reply With Quote
Old 09-03-2012, 09:46 PM   #304
TipsyMcStagger
Oddometer: 957
My opinion, I'd start a new thread called "The project that shouldn't be: Part II."
I'd be interested in reading descriptions of what changes you're making and why you've decided to make those changes.
As a Buell rider and a former Sportster rider, I might be compelled to follow in your footsteps one day and would like the opportunity to learn from your mistakes and experiences.
Tipsy
2008 KTM 450 EXC-R
Old 09-04-2012, 06:12 AM   #305
Danger4u2
KX & CR 500 Rider
Danger4u2's Avatar
Oddometer: 317
Keep it here so we don't have to switch back and forth.
Won't it be a new to you frame, like the one you had, just a different VIN #?
Go faster than everyone.
Only worry about what's in front of you.
'08KX500AFC(my favorite) '07KLR650
'04KX500(street legal) '97CR500R
'06KLX250(351cc kit) '08KFX450R quad
Danger4u2 screwed with this post 09-04-2012 at 07:15 PM
Danger4u2 is offline   Reply With Quote
Old 09-04-2012, 06:53 PM   #306
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,306
Laugh
same dimensions different vin. Should pick it up next week. I will have a spare motor to build now lets see I think 88" should be enough for gettin' dirty
Old 09-06-2012, 07:09 AM   #307
Ginger Beard
I have no soul
Ginger Beard's Avatar
Oddometer: 5,598
There's always the S&S 100" . It may be fun to have a dirt bike with 140 rwhp and an equal amount of torque.
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~
My HD Scram-ster build
Help Save a Pit-Bull
Ginger Beard is offline   Reply With Quote
Old 09-06-2012, 08:13 AM   #308
JimmyTheHog
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 644
Ive been eye'ing that motor myself for a while!!! Pricey though
Do you know if there are any mods required to drop it in ?
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog is offline   Reply With Quote
Old 09-06-2012, 11:41 AM   #309
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,306
You will have to have the cases bored to fit the big bore and on some cases need clearance machined. That's not normal but has happened. If you buy the SS kit then you have all you need. I'm looking at the axtell mountain motor. A little less money and you still have the same rpm capability, plus no change in engine heigth. I have to put a new crank in the motor on the donor bike, so while it's apart might as well bore the cases, and the 88 kit is the same as a 1250. I'll go all cat iron, and build it as I go. No hurry since I have a nice sport motor in great shape.
Old 09-27-2012, 06:12 PM   #310
trav72
I can't ride where?
trav72's Avatar
Oddometer: 776
Any updates on the bike? Are you all healed up?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
trav72 is offline   Reply With Quote
Old 09-29-2012, 12:38 PM   #311
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,306
I'm healed up, got a donor bike for the frame, and have my engine in it. I'm on hold for a bit as I have tests for my Job coming up and am traveling alot. Mainly just boring stuff right now. Custom wiring harness stuff and basic parts swapping.
Old 11-27-2012, 07:29 AM   #312
Utah Bones
Gas X ready!
Utah Bones's Avatar
Oddometer: 1,574
Awsome!
Tito's vodka a weber grill and the rocky mountains,...it all goes away!
Utah Bones is offline   Reply With Quote
Old 01-11-2013, 07:33 PM   #313
WhicheverAnyWayCan
Deaf Biker
Oddometer: 357
Just found this thread after your reply to my 'sportster or KLR' thread. Wow, I am glad you are doing fine after your accident and I thought you had sold your bike. I think we exchanged email couple of times few months back?
Anyway, curious to see what you will be doing differently this time around. It sounds as if you really love your dual sportster so much I don't think you should abandon it but you got to do what you think is best for yourself.
This thread gave me few ideas what to do with my sportster. I contacted Rick about making a rear shock for sporty but haven't heard from him assuming he doesn't do sporty until I see that you used his fork springs and he helped you tweak your sporty a bit. Maybe I should give him a call instead of email and see what he can do. Maybe he can do my forks and I'll just go with Works Performance rear shocks if he doesn't do sporty rear shock. I'd like to try and keep my sporty closer to factory setting but raise it up off the ground a bit and make a 2-in-1 exhaust pipe but the front exhaust pipe will run above the base of motor like Dough Wothke did with his Dirtster. But I think I would add spark arrestor muffler on right side and a dummy muffler on other side so I can make a safety box(with key) in there to keep important documents for my Central/South America trip. At least that's on my drawing board but doesn't mean it will go forward. We will see.
WhicheverAnyWayCan is offline   Reply With Quote
Old 01-30-2013, 02:02 PM   #314
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,306
I have my little shot of fame, a pic of my bike made it into Motorcycle consumer news
Old 01-30-2013, 07:03 PM   #315
trav72
I can't ride where?
trav72's Avatar
Oddometer: 776
Very cool! Now, did you get it back together yet?
Times are GMT -7.   It's 01:15 AM.
