Old 01-30-2013, 02:26 AM   #15886
Beserker
Red Rider
Beserker's Avatar
Oddometer: 94
Originally Posted by Sean-0 View Post
....with the tank bra ...
Sounds like you are cruising around with your mistress
Beserker is offline   Reply With Quote
Old 01-30-2013, 03:21 AM   #15887
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,409
hahaha i wish
Sean-0 is offline   Reply With Quote
Old 01-30-2013, 11:21 AM   #15888
Shibby!
Oddometer: 1,657
Originally Posted by stuntheavy View Post
What kind of range can be had out of the 4.6? 6.3?
Sent from my SCH-I535 using Tapatalk 2
My stock carb and 4.3 had me around 200-220 KM I think.
My 6.3 with TM-40 I can almost always do 400KM, often a lot more. I bet if I had to on a gravel or paved road I could do over 500KM. I've never pushed it though. I've done low 400KM a few times.
There has only been once I've hit reserve at 380KM, and that was in Baja, all deep sand roads and roosting around corners.
I get around 50-52 MPG with the TM-40 and 70lbs of gear.
For those wondering, 1.6KM / Mile.
If you ride WTF out there, having a tank with lots of gas is a GREAT feeling. I've been in some VERY remote places and knowing my tank is half full still always brings comfort.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 01-30-2013, 11:42 AM   #15889
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,109
hahaha i wish
I think you forgot some stuff
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 01-30-2013, 11:51 AM   #15890
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,409
14 days .. you cant carry enough stuff
Old 01-30-2013, 11:55 AM   #15891
Shibby!
Oddometer: 1,657
Haha.
I can't say I share the same way of thought... I had less stuff with living off my bike for 4 months... Provided I didn't have to bring food or cooking gear.
I think we covered this before, but always fun to bring it up again. ahha.
In my opinion, lighter = better. Not only easier to ride, more simple, quicker pack-ups, etc.
I know you aussies like your massive sleeping mats / tents, but you should really see about a Thermorest or similar pad. If you don't need thermal properties, there are ones that weigh very, very little. The ProLite + which is my other matt weighs quite a bit more but much, much warmer. What I brought on my trip was awesome for size, but too cold. Even here in the summer I feel chill using it, often resorting to my Pro-lite Plus for better sleeps.
Old 01-30-2013, 12:51 PM   #15892
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,409
its hard to xplain .....the swag on the back has my clothes and all sleeping stuff
its now been retired off the bike ...am going to tent from now on ..i have a exped mat was in my swag
on that trip we had way diffent temps over the 14 days from freezeing cold to hot
the bladders sit up front there a must ..we have big distance with low fuel options
the bags on the side 1 held food and 1 held spares and nick knacks ..all up the gear is light just the swag makes it look heavy
running the CSR this yr for 4 weeks ......gear is getting cut down as its all tuff sand .....bladders will still be there but going a giantloop tent and exped and sleeping bag ....4 xrr's in the desert makes it easy for us to spread the tools and spares between bikes ...
gunna take 1 set of clothes and throw them away each week and buy new stuff where i can
60 ltrs fuel on board and 10 ltrs of water ...hard going in desert
Old 01-30-2013, 01:16 PM   #15893
stuntheavy
Oddometer: 146
What kind of reserve range are you seeing with the 6.3?
stuntheavy is offline   Reply With Quote
Old 01-30-2013, 01:48 PM   #15894
jm-2008
jm-2008's Avatar
Oddometer: 512
[QUOTE=Sean-0;20611514]its hard to xplain .....the swag on the back has my clothes and all sleeping stuff
Sean-O
Guess you must have a portable shower packed in there somewhere as well.
Enjoy the trip!
JM
jm-2008 is online now   Reply With Quote
Old 01-30-2013, 02:09 PM   #15895
Shibby!
Oddometer: 1,657
No idea. I haven't tested it but you actually have two reserves provided you have the plumbing run appropriately. The 6.3 has two petcocks on either lobe. The second tube has to run either above or below the carb. In either event you don't get all the gas because the lobes go below the carb intake. In a REALLY bad situation you could then tip the bike over and fill a bladder / bottle then tie that into the carb to use all the gas. Once again, not great but it would get you that extra 10K if need be.
I need to fill up from empty and see what the tank actually holds, then see how much is there when I fill to better guage my distance. With possibly 500+ KM of range I don't worry too much about gas and know 400 is no issue unless I'm working the bike really hard, and even then I only hit the reserve once on my way to San Ignacio in Baja. I had to pull over just before the military stop to turn on my reserve.
Old 01-30-2013, 05:33 PM   #15896
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,358
not to beat a dead horse, but here's my oil level after oil / filter change and 1.7 QTS oil added. Idled bike for 5 min and shut it off and checked the level upright.
and here's hontri's level - I haven't added any extra to see how much it takes to bring it up to that level. Anybody just adding 2 QTS at the oil change?
PineyMountainRacing is offline   Reply With Quote
Old 01-30-2013, 06:24 PM   #15897
hontri
Global Bummer!
hontri's Avatar
Oddometer: 303
Yoh Piney Those black marks on the steel oil tube are the correct upper full mark and lower add mark in relation to the dipstick. I have never let it get down to the add mark.There is not much oil in these things to start with. My bike takes 2 quarts to fill after a complete oil change. I start by adding about 13/4 quarts, warm up real well and then add oil slowly till i reach the upper full mark. Those marks are right in relation to the dip stick.
hontri is offline   Reply With Quote
Old 01-30-2013, 06:26 PM   #15898
Sierra Thumper
Oddometer: 641
6.3 is nothin .......mine holds that then i add bladder bags for a total of 12 gal
bladders hang over the side of the tank ...now thats some weight ....suspension is workin over time when fully loaded ...but i dont motorcroos the bike when she's got full weight on
on another front ..we are making some steal rear subframes ..made out of box steal ...better that globtotting subframes ..as we keep them box section same as stock and add gussets to give more strength ....
we test them out very soon
we need to carry 12 gl of fuel and 3 gal of water for our desert trip later this yr
And I complain about my 4.6 gallon full You're carrying more fuel than some cars hold
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 01-30-2013, 06:48 PM   #15899
PineyMountainRacing
Oops....
Oddometer: 2,358
another 1/2 qt will prolly bring mine up to your level - I'll pop the Scott's off tomorrow and see what it takes to bring it up. Appreciate your advice.
Old 01-30-2013, 09:22 PM   #15900
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,409
have added a dc system to my bike .. no more ac pwr all runs dc
makes it easy to install heated grips lights gps and so forth here's the finish
a little house for the battery behind the fairing
Times are GMT -7.   It's 12:48 PM.
