Old 01-19-2013, 06:21 PM   #61
lamebrain
Oddometer: 38
Originally Posted by brucifer View Post
Anybody have an extra set of grommets and the steel collars that go in the frame to mount the top of the rear fender? I need a set and they're NLA from Honda.
I'd be happy to buy them from you if you have any you'd care to turn loose of.
Are you talking about where the seat bolts go through? If so, I might have a set.
lamebrain is offline   Reply With Quote
Old 01-19-2013, 06:54 PM   #62
brucifer OP
brucifer's Avatar
Oddometer: 2,429
Yes.
Originally Posted by mcma111 View Post
Bruce,
Post up a parts fich picture and I'll see if I have them or something clos.
Steve, numbers 4 and 5.
http://www.bikebandit.com/houseofmot...9700#sch404066
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 01-19-2013, 07:00 PM   #63
mcma111
mcma111's Avatar
Oddometer: 12,089
Bruce,
Probably have #5. I'll look for #4
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-19-2013, 09:23 PM   #64
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 713
I honestly don't know how that end cap comes off. Is there maybe a snap ring in there or something?
Yeah, this parts shock of mine has not been serviced since it left Japan 30 years ago
I didn't spend a whole lot of time trying to remove the cover, but I think its just pressed on. I was wondering if there was a way to remove it without destroying it. Only thing I could think of was to drill a pair of holes and use the slide puller with the right attachment to yank it off.
Having never done the job before, I was hoping someone would chime in and describe the right process.
I was missing one of those fender grommets too for the parts bike. However, I found a usable substitute in one of my bolts lots purchased off of ebay. Which I needed for something else during the rebuild.
Ghost_Mutant is offline   Reply With Quote
Old 01-20-2013, 08:41 AM   #65
velocipus
Oddometer: 6
I stripped the bike down to the frame and did a few mods. First I test fit an XR650L swingarm and it was a virtual bolt-on deal. Then, eyeballed the position for the rear brake pedal pivot and master cylinder bracket and tack welded them in place. I then took the frame to work and had my boss' son weld them up for me. I ended up doing the pivot twice because I wasn't happy where I had positioned it the first time.
A few pics.
The shock I'm hoping to use is from a 1988 XR600 that I purchased from an inmate.
I'm considering doing the XR650L swingarm on an XL600 as well.Any input on what I'll need to watch out for/ modify to get it to bolt up?
velocipus is offline   Reply With Quote
Old 01-20-2013, 10:53 AM   #66
lamebrain
Oddometer: 38
Bruce,
I have the rubber grommets for sure. I'm sure I have the sleeves as well, but I'll have to dig around my shed a little more for them.
Old 01-20-2013, 12:38 PM   #67
brucifer OP
brucifer's Avatar
Oddometer: 2,429
Steve and lambrain- Thanks for looking for those pieces for me. Much appreciated.
velocipus- Not really much more to say than what I've already posted.
The swingarm itself is truly a bolt-on. You'll have to use the XL linkage and the XL shock will work too.
The biggest thing is welding on brackets to the frame for the disc brake set-up.
Good luck with it and if you have any other questions, feel free to ask.
Old 01-23-2013, 02:01 AM   #68
Manos
Oddometer: 17
subscribed (again...!)
M.
Manos is offline   Reply With Quote
Old 01-26-2013, 06:03 PM   #69
brucifer OP
brucifer's Avatar
Oddometer: 2,429
Hey Manos.
I was all set to get the rear wheel mounted up....got some new parts.
The difference between the CR axle (top) and the XRL axle.
But, I ran into problems with bearing and seal fitment on the sprocket side so....I hung the wiring harness...
....found the handlebar mounts and bolted them on then went back to the Honda dealer and picked up the best cheap bars money can buy. Remember, I want this bike to look like an XL600R and that means no fancy Fat Bars or anything like that.
Not much accomplished and probably didn't warrant any pics but, what the heck, everyone likes pictures.
Old 01-27-2013, 05:06 PM   #70
lamebrain
Oddometer: 38
Hey Bruce, I can't find the sleeves, but if you pm me your address i can send you the rubber grommets!
Old 01-27-2013, 05:15 PM   #71
mcma111
mcma111's Avatar
Oddometer: 12,089
Bruce,
I was just thinking if you got the rubber bits and collars. Guess I'll have a look at the parts bin.
Better late than never eh?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-27-2013, 05:35 PM   #72
brucifer OP
brucifer's Avatar
Oddometer: 2,429
PM sent. Thanks man.
Bruce,
No worries Steve.
Old 01-30-2013, 03:56 PM   #73
mcma111
mcma111's Avatar
Oddometer: 12,089
Bruce,
I finally made it to the parts shelf. Think slashing one's way through the thick jungle.
Rubber part:
21.5mm OD
12mm thich
inner grove is 14mm x 3mm
The hole will accept the collar.
Collar:
Washer end is 22mm
overall length is 17mm
Hole will accept the 6mm seat studs.
I went to take a picture of these bits but the dam battery is dead. Recharging now if you want a pic.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-30-2013, 06:24 PM   #74
brucifer OP
brucifer's Avatar
Oddometer: 2,429
Bruce,
Rubber part:
21.5mm OD
12mm thich
Collar:
Washer end is 22mm
LOL. I know the slashing through the jungle all too well. You've seen pics of my garage.
Those numbers sound right.
Old 01-30-2013, 06:40 PM   #75
lamebrain
Oddometer: 38
I mailed you the rubber parts today!
Times are GMT -7.   It's 04:24 AM.
