Old 01-29-2013, 07:26 PM   #17746
150ron
150ron's Avatar
Oddometer: 816
Originally Posted by Starchamp View Post
Nice! Now you just need a real set of hand guards to put them on!!
Thanks, yeah, i agree
i had the Cycra pro bend CRM'S on my previous bike, and they are terrific, would like to get them for this bike as well.
Just some dude...
150ron is offline   Reply With Quote
Old 01-29-2013, 07:54 PM   #17747
0ldhippie
0ldhippie's Avatar
Oddometer: 566
Originally Posted by 150ron View Post
$3.99 blind spot mirrors from Orielly's auto parts, show a whole lot more then the stockers, fold in and out of the brush guards, cheap easy good mod imo.
They clean up the bike a bit too, by getting rid of the stockers.
Hey did you wash that thing????
I've forgot more than you kids ever knew!
Retired and living off the interest on the money I owe.
0ldhippie is offline   Reply With Quote
Old 01-29-2013, 08:32 PM   #17748
955616846
Oddometer: 1,692
Hey, it is outside the workshop and there isn't a spanner (wrench!!!) in sight.
Cheers, Numbers
05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800
Founding member Longtails SC
955616846 is offline   Reply With Quote
Old 01-29-2013, 10:35 PM   #17749
riverrat1515
riverrat1515's Avatar
Oddometer: 37
Will rings from a 2001 drz400s model fit 2000 drz400e model. Bike needs ring job and the site I'm ordering from only shows 2001 and on oem rings. Also putting in new timing chain. Should i get new tensioner also?
riverrat1515 is offline   Reply With Quote
Old 01-29-2013, 11:51 PM   #17750
955616846
Oddometer: 1,692
Yes and yes.
Reverse lookup on the OEM part number here:
http://www.ronayers.com/WhereUsed/N/...er/12140-29F00
Cheers, Numbers
Old 01-30-2013, 04:20 AM   #17751
supermono
Oddometer: 4
DRZ 400 E manual
Hi
Does anyone have a link for an "E" manual please. I,ve got an "S" but it doesnt cover the carb.
I,d buy one but I have no work and I,m skint.
Cheers JD
supermono is offline   Reply With Quote
Old 01-30-2013, 05:03 AM   #17752
riverrat1515
Oddometer: 37
Thanks for quick response. Will later model tensioners fit the 2000drz 400e. Should i get manual or automatic one.
riverrat1515 screwed with this post 01-30-2013 at 05:32 AM
Old 01-30-2013, 07:35 AM   #17753
focallength
patty cake champion
focallength's Avatar
Oddometer: 3,405
Unless your adept at monitoring/adjusting your tenioner just stick with a new tensioner acct. its the same engine so just buy 2013 parts.
Unregistered destructive device.
focallength is offline   Reply With Quote
Old 01-30-2013, 07:44 AM   #17754
955616846
Oddometer: 1,692
Yes...
Manual unless you're not confident in your mechanical skills...It's a "just enough" adjustment... improperly adjusted they'll chew through the chain and guides real quick.
I pointed you at the reverse lookup page at Ronayers for a reason... Look up the parts you're interested in the fiche, click the part number in the list and then "where used"... It'll tell you quickly and easily what you need to know.
Cheers, Numbers
Old 01-30-2013, 09:56 AM   #17755
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,180
Originally Posted by supermono View Post
Hi
Cheers JD
Here u go:
2000-2009 Suzuki DRZ400 DRZ 400 CLYMER REPAIR MANUAL
Suzuki DRZ400 DRZ 400 SM S E Service Manual Tech Info - CD Only
Haynes Suzuki DR-Z400, DRZ400E, DR-Z400S & DR-Z400SM, 00-10 Repair Manual
DR-Z400E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 01-30-2013, 10:47 AM   #17756
shb1129
Oddometer: 1
Laugh
Did you create custom mounting brackets for the mirrors? The local auto parts stores in my area (KC, MO) only have the stick on blind spot mirrors, nothing like what I see in your pictures.
shb1129 is offline   Reply With Quote
Old 01-30-2013, 03:03 PM   #17757
toadl
toadl
toadl's Avatar
Oddometer: 588
Hi
Cheers JD
The FCR carb is pretty popular. Check out videos on youtube or more info at the TT website.
M&M's don't know anything and have no meaning.
toadl screwed with this post 01-30-2013 at 03:30 PM
toadl is offline   Reply With Quote
Old 01-30-2013, 04:23 PM   #17758
150ron
150ron's Avatar
Oddometer: 816
Yeah, i just cut up 2 strips of plastic and stuck the blind spot mirrors onto it with the self sticking tape, then put some plastic epoxy around the edges to make it stronger, very easy to do.
Just some dude...
Old 01-30-2013, 08:33 PM   #17759
Buckeye105
Buckeye105's Avatar
Oddometer: 9
04 and up have the fixed/ better working acct right?
Buckeye105 is offline   Reply With Quote
Old 01-30-2013, 08:39 PM   #17760
focallength
patty cake champion
Oddometer: 3,405
Not sure, I always buy 2010 parts, gets rid of the confusion (or 2007 if its an e model, as that was the last year) but it somewhere around there they started fixing the glitches
The acct works fine, set it and forget it, if it starts making noise its time for a new timing chain, no amout of manual adjustment will fix that.
Times are GMT -7.   It's 11:45 PM.
