Old 01-30-2013, 01:37 PM   #16
Konflict Motorsports
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 625
Originally Posted by KEELAYMONSTER View Post
Thanks! Ill do that. Ill post whatever I find. If they don't work then expect to see a set of wheels for sale.
Put me at the front of the list if it doesn't work out, but I think it will for you.
Konflict Motorsports & Suspension Services
www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Old 01-30-2013, 02:33 PM   #17
KEELAYMONSTER OP
BRRAAAAPPP!!!
KEELAYMONSTER's Avatar
Oddometer: 77
The folks at RAD are awesome! They did the research and apparently All Balls stocks a set of bearing that will allow a 30 mm axle. A stock SE is 26mm and an adventure is 30mm. I have RAD making my spacers to spec. On another note the rear wheel from an SE is not a direct replacement. The only difference is the spacer on the disc side is narrower. I'm not sure what the SE has for a rear brake but my guess is its a different caliper/caliper bracket. Or the swing arm is just wider on the SE.
Here are my measurements and part numbers for bearings and seals to convert (Note: this is only for RAD hubs. The front is a single disc hub and rear is different from adv).
All Balls numbers:
Bearings x2: 20-1024
Seals x2: 30-5210
EDIT:
Front spacers:
RH: .292" no shoulder
LH: .635" no shoulder
Center spacer should be the same length just bigger ID to accommodate the 30mm axle.
Rear spacer (disc side)
.65" with no shoulder
Sprocket side is the same
Ill keep everyone updated on the progress.
Kyle Montagne #141K
KEELAYMONSTER screwed with this post 02-20-2013 at 04:07 PM
KEELAYMONSTER is offline   Reply With Quote
Old 01-30-2013, 10:03 PM   #18
max2
max2's Avatar
Oddometer: 168
I think you should sell them to me!!....way to much work
2007 Super Enduro...Finally got another one & 2008 Kawi KLX 450 - Plated
2010 KTM 690R - Sold
2006 BMW R1200GSA - SOLD...Thank Goodness...I hated that thing.
2007 KTM Super Enduro - Sold - HUGE Mistake letting it go
2006 KTM Adventure S - Sold / 2007 KTM 950 Supermoto - Sold
max2 is offline   Reply With Quote
Old 01-31-2013, 08:07 AM   #19
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 77
If they do go up for sale Konflict will be the first to know. Ill put you down for second in line though
Ill be giving All Balls Racing a call today to order the bearings.
Kyle Montagne #141K
Old 02-01-2013, 08:16 AM   #20
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 77
So...$30 later and the bearings and seals are on their way Oh Joy!!! More great customer service from All Balls Racing.
Im used to people begrudging my attempts at customization. Some people are just too close minded. Its nice to deal with people that are willing to think a bit out of the box and help someone. RAD and All Balls are those kind of people. Defintiely will do business with them again.
Kyle Montagne #141K
Times are GMT -7.   It's 05:13 PM.
