Old 01-30-2013, 07:49 AM   #616
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 3,987
Originally Posted by jgas View Post
If I did this, the trailer would have to be built for me to lay down on, stable, narrow, and tough. It would need to be close to the bike so I could turn around without unhooking on roads and wide trails. My goal would be to pull it behind my DRZ in all but the hardest singletrack. I would need to be able to pull it into some really tough spots without crashes or breaking it. My dream trailer would be long enough for me to use it for a camper after I unloaded it. Maybe have a small lightweight rack that I could drape a tarp over and lay inside of for camping, then take it apart or fold it all up for riding. It would need to have a lightweight detachable frame that could be put together to lay on for sleeping and stay off the ground. The frame could theoretically be mounted lengthwise or crosswise to the trailer. My ideas far outstrip my ability! I would like to have a brake on the trailer, and I think that one wheel would be better than two, maybe with outrigger tires like training wheels that only touched the ground when going slow or turning around.
If someone could build this and market it cheaply it would make a fortune! Or sell easy to use plans for the do it yourselfer. Some of the ones I've seen here look great but I'd want to somehow try various ones before copying one to make sure it worked for my uses. I'm probably the only idiot that would even try to ride singletrack with a trailer, but it sure would be cool! I have seen bicycle trailers that hardcore off road guys pull with Mtn bikes. One guy has ridden all over Colorado pulling a trailer with a bicycle.
Has anyone tried pulling the trailers from the top of the bike, attached to the subframe or rear rack area? This would put the trailer at an upward angle so that it wouldn't drag, give it cornering clearance, and bring the trailer tire/tires closer to the bike. It would also keep the trailer from being affected by the swingarm moving up and down. On most bikes the subframe/rack area would have to be modified to hold up to the stress, but that would be pretty easy compared to designing the trailer I'd think?
Anyone thought of making the trailer tire, (the singletired ones), so that the tire/wheel actually leans with the bike? It would keep the trailer tire's contact patch constant and the trailer should follow the bike better.
Go back and read through the thread. All single wheel trailers lean with the bike.
As far as sleeping in it, that would be a big trailer. Just throw a fold up cot and tent in the trailer.
Here's mine going through some mean stuff.
oPAULo is offline   Reply With Quote
Old 01-30-2013, 08:06 AM   #617
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 633
axel mount best off road
Attaching at the axel provides unsprung weight to the bike. Any attachment to the bike subframe or frame will be sprung weight. I would think a low unsprung weight would be more stable off road, not changing the weight bias of the suspension fore and aft.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 01-30-2013, 09:37 AM   #618
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 3,495
The trade off is that your rear suspension setup is reliant on the weight of whatever is hanging off the shock, which would now include the "tongue" weight of the trailer. In the world of high performance unsprung weight is far worse than sprung weight, as it compromises the ability of the rear wheel to track over bumps because of added inertia. However subframes are usually not designed for the kind of loads discussed and move the weight higher up on the bike.
If I had the skills I would find a way to hook the trailer to the footpeg mounts. It keeps the weight sprung, at a low, central point on the bike, better bias the front/rear loading etc.
The trade off is this method would be slightly heavier, more complicated, and less flexible in terms of moving the mount from one bike to another,
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne is offline   Reply With Quote
Old 01-31-2013, 06:04 AM   #619
blacktruck
Oddometer: 170
Question Way to carry your stuff....
I'm in complete agreement with you. In my opinion there should be a way to mount the hitch portion to the frame somewhere. I looked at the moto mule website. I like the idea of the single track but not keen on the axle mount. Need to rethink this for me a little. I've even seen a couple of the two wheeled trailers that looked pretty good but you now have to add some for width. I've pulled a two wheeled trailer with a bike before but it was a touring bike so you didn't really worry about the width or going in to a corner too hot and flipping the trailer. Has anybody ever made a regular hitch for the KLR or does this need to be invented too? I would just like to find some way to reduce the actual weight carried on the bike.
Anywhere is home
blacktruck is offline   Reply With Quote
Old 02-26-2013, 02:55 PM   #620
GHO100
Crazy George
GHO100's Avatar
Oddometer: 1,056
Has anyone considered using a mover's hand truck as a body for their trailer?
Like pictured above, but laid flat.
Remove the standard wheel and add your own, say from a 50cc scooter attached with a shock and hingepoint.
Only thing left to figure out would be the hitch attachment to the bike?
2012 BMW R1200GS
www.TeslaLEDS.com
www.NYMSTF.org - Support NY Riders!
GHO100 is offline   Reply With Quote
Old 02-26-2013, 06:02 PM   #621
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 3,987
So cut the bottom off to add suspension, then cut the top off to add a hitch?
Not much left of the hand truck after that is there?
Old 02-26-2013, 08:46 PM   #622
GHO100
Crazy George
GHO100's Avatar
Oddometer: 1,056
I wasn't really thinking about cutting anything off, to be honest. Other than removing the axle that's currently on there, I think that rear/bottom plate makes a good place for mounting lights, plate, etc.
Also, not thinking about cutting off the top. I picked up one of these to go around the handle:
The only thing I've left to figure out is the yolk that goes around the rear tire and connects to that hinge bracket. I'm currently considering removing the wheel from a heavy duty castor, like this:
Perhaps a few sections of aluminum tubing or square piping will complete the setup?
2012 BMW R1200GS
www.TeslaLEDS.com
Old 02-26-2013, 08:54 PM   #623
fullmetalscooter
Let me take this duck off
fullmetalscooter's Avatar
Oddometer: 2,931
It;s like anything if it's sitting around with crapped out tires or up 20 bucks someone might just use it. The reason you some time see really old motorcycle engines running pumps becasue someone 40 years gee lets use that , it's not worth much.
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE.
"Life is a tragedy when seen in close-up, but a comedy in long-shot." Charlie Chaplin
fullmetalscooter is offline   Reply With Quote
Old 02-26-2013, 09:02 PM   #624
boatpuller
Oddometer: 517
Before buying a trailer I considered the same thing. Went to Harbor Freight and was suprised by all the different hand trucks they had, some would be an even better choice than the one you pictured. You should check them out.
boatpuller is online now   Reply With Quote
Old 02-26-2013, 09:05 PM   #625
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,301
The problem with using the dolly is it's width.It will need to be high in order to clear the ground when leaning into turns.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 05-26-2013, 06:40 PM   #626
lonewolf97
lonewolf97's Avatar
Oddometer: 2,354
Great for beach chairs and cooler for two. Just right!
A day at the beach with the Mrs.
Sent from my Galaxy Nexus using Tapatalk 2
I'd rather be lost in the woods, than found at home.
lonewolf97 is offline   Reply With Quote
Old 05-27-2013, 10:48 AM   #627
Patrick46
visionary
Patrick46's Avatar
Oddometer: 2,824
That's a nice little utility trailer ya got there ^^^
however, this IS the "DUAL-Sport Trailer" thread, and your bus doesn't exactally qualify as a 'dual-sport'.
hey......neither does mine!
well....at least not this one!
"Good Times & Good Friends Make Life Better"
www.artworks-unlimited.com
Patrick46 is offline   Reply With Quote
Old 05-27-2013, 11:10 AM   #628
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 3,987
Both good looking rigs in my opinion!
Thanks for sharing!
Old 05-27-2013, 05:25 PM   #629
lonewolf97
lonewolf97's Avatar
Oddometer: 2,354
Hey Patrick46. Looks like You have a full blown popup camper.
I chopped a jet ski trailer down to carry my beer cooler.
All I've got left to do is make a hitch for my old dr and I can
pull it with both bikes. It has enough ground clearance
to be a good offroad trailer too. I like to party in the woods too.
Old 05-29-2013, 10:21 AM   #630
Patrick46
visionary
Patrick46's Avatar
Oddometer: 2,824
Yeah, it's a Kwik-Kamp, and they're the bomb!
My buddy's got one too, and last summer I put my E-Z Up room between them and we came up with this....
everything you see was hauled to the party on these 2 bikes in 1 trip!
OK, hyjack over!
Times are GMT -7.   It's 09:00 AM.
