Old 01-31-2013, 02:02 PM   #15811
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 1,138
Laugh Told ya' so...
Originally Posted by WARRIORPRINCEJJ View Post
Didn't you announce your shared jealously and love, last night?
And then you said something about liking licking, this morning.
Come clean, Pluric; Did you paint your bike blue?
What did I tell ya'?
Dallara
You never see a motorcycle parked outside a psychiatrist's office
Dallara is online now   Reply With Quote
Old 01-31-2013, 03:12 PM   #15812
markjenn
Oddometer: 9,700
Originally Posted by Dirty bike View Post
And the guy with 8 bikes in the garage, it's not the other 7, it's a Yamaha and there is a known issue with EFI Yamahas. The cold start sequence doesn't like to be interrupted. Do that, then let it sit, it will display the hard start 99% of the time.
Bull. Go out and fire your bike up for 60 seconds, shut it down and come back 3 days later. You'll have a classic hard start.
Originally Posted by markjenn View Post
Okay, test underway.
To close on this, I did exactly as instructed, ran the bike for exactly sixty seconds three days ago and just went out and started it. It fired up immediately and ran normally without touching the throttle. And this is a bike which has had three previous "no start" episodes, all with none of the often-discussed contributing factors such as an interrupted previous start or cycling the ignition.
I guess I'm either an exceptional 1% who doesn't match the pattern, or else your 99% statistic is BS. I'll leave which is more likely as an exercise to the reader.
- Mark
Old 01-31-2013, 03:25 PM   #15813
Dirty bike
EVal Innovations Inc
Dirty bike's Avatar
Oddometer: 367
Well Mark, I have to thank you for playing along all the same.
I can create the hard start by doing what I said, though I haven't tried to repeat it multiple times in a row either. And the FJR did the same thing.
Aside from your koolaid addiction, you do have some good posts and good input. We will continue to disagree on some matters though. Feel free to call BS when you feel the need, and I'll do the same.
Dirty bike is offline   Reply With Quote
Old 01-31-2013, 03:28 PM   #15814
GrahamD
GrahamD's Avatar
Oddometer: 3,824
- Mark
Same here...
"It's better to ride a boring bike than push an interesting one" ... Canuman
The 2012 Yamaha Super Tenere is a hungry bike. Touring? Eats it up. Twisties? Eats it up. Back country camping with a heavy load. Eats it up." - Tumu Rock AMA.
GrahamD is online now   Reply With Quote
Old 01-31-2013, 04:12 PM   #15815
crazyjeeper
crazyjeeper's Avatar
Oddometer: 146
Send a message via AIM to crazyjeeper
Originally Posted by pluric View Post
So.... anyone tried to start their bike recently.
Nope.
Current:, 2012 Yamaha Super Tenere, 1985 Honda XR350R, 1976 Honda GL1000 Goldwing
Past:
1998 Triumph Tiger, 1993 Honda CB750 Nighthawk, 1984 Honda VF500F Interceptor
crazyjeeper is offline   Reply With Quote
Old 01-31-2013, 04:26 PM   #15816
Dirty bike
Dirty bike's Avatar
Oddometer: 367
Originally Posted by GrahamD View Post
Same here...
You did a lot of other things too Graham, w/o any real hard start, just some minor stumbles.
Are the AUS bike ECUs different? You do get foam filters instead of the paper, if I recall correctly. Any other differences?
Probably moot, but I've never noticed any "off idle stumble" either. Have you?
Old 01-31-2013, 04:27 PM   #15817
Dallara
Dallara's Avatar
Oddometer: 1,138
Laugh Speaking of statistical probability...
- Mark
Of course, we could consider another much more likely scenario for those "three previous 'no start'" episodes you had...
It was put this way by a poster in a thread on the Super Tenere forum:
"Without examining the bike, mechanical failure can't be ruled out, but it is MUCH less likely than simply (rider error, operator malfunction, rider losing control, etc.). The weakest link is typically the nut behind the handlebar."
Given that you've had probably hundreds and hundreds of starting attempts during the time you've owned your bike it perhaps stands to reason that those few (3) times you had a "hard starting problem" it was probably something you did, eh?
Dallara
Old 01-31-2013, 05:37 PM   #15818
GrahamD
GrahamD's Avatar
Oddometer: 3,824
Are the AUS bike ECUs different? Don't know. It's a first gen 2010 Pre Fukushima bike.
You do get foam filters instead of the paper, if I recall correctly. Yep.
Any other differences? It's the fastest and most economical colour combo..
No electrical farkles. Other OZ bikes have had the hard starting issue so it's not an "OZ bike thing".
Probably moot, but I've never noticed any "off idle stumble" either. Have you? Yes. Only in touring mode because I usually use that in traffic which I do as little as possible.
This is not what I call a minor stumble.
. If that was a minor stumble all I can say is I cleared it before the battery went flat.
All I wanted to do was figure out the most reliable way of inducing the hard start and a reliable way of clearing it.
And, after all that I can say that it was easier to induce if the battery was not 100%, no amount of switching the ignition had any effect and that it reliably occurs if the bike is cranked without firing between one or multiple times.
I could induce it with a freshly charged battery but it was harder to do. As the battery softened it became easier to induce.
It can be cleared by opening the throttle between 1/2 and 3/4 throttle for one to three starts. WOT may do it as well but I never did WOT.
I have started the bike and switched it off immediately, left it for days, with no problem.
I have started and let it warm to just over "Lo" and left it for days with no problem.
The most reliable way to induce it is to crank it without it actually firing cold. The more time that happens in succession the worse it gets.
GrahamD screwed with this post 01-31-2013 at 05:58 PM
Old 01-31-2013, 05:48 PM   #15819
snakebitten
Small Town Hick
Oddometer: 369
Originally Posted by crazyjeeper View Post
nope.
f150?
12 Super Tenere...........04 DRZ 400E
06 950SM (Yehaw!!).... 96 DR350SE
06 KLR
98 VTR (Track Bike)
snakebitten is online now   Reply With Quote
Old 01-31-2013, 06:24 PM   #15820
iridemotorbikes
Look a moose
iridemotorbikes's Avatar
Oddometer: 699
Short video of my Saddleman Adventure Track heated seat. I had Saddleman build it with a red insert and red stitching, not over the top flashy but looks sharp in my opinion .
Videos here
iridemotorbikes is offline   Reply With Quote
Old 01-31-2013, 06:36 PM   #15821
crazyjeeper
Oddometer: 146
Originally Posted by snakebitten View Post
f150?
Yup. 2011, just crossed 50k miles.
Past:
Old 01-31-2013, 06:38 PM   #15822
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 11,386
The seat fondling is just a little creepy. Just sayn'.
pluric is offline   Reply With Quote
Old 01-31-2013, 07:18 PM   #15823
William42
William42's Avatar
Oddometer: 844
I think I detect a note of jealousy.
Mud is evil
William42 is online now   Reply With Quote
Old 01-31-2013, 07:41 PM   #15824
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 11,386
Maybe a little when I think about the strong sensual curves of the D rings so
teasingly hidden under the fine Corinthian leather. The supple yet pouting
closed cell foam taunting me to just sit on it and wiggle. The custom stitching
plunging out of sight only to reappear exposing it's vibrant nature. Begging to be
touched and at the same time disappearing leaving the imagination as to where
it went and what it could possibly be doing there. Mmmmmm.
To be able to caress that black sea of suede cover with a light drag begging one
to linger longer. The thoughtfully scuptured center indent so inocently designed
to replicate the female anatomy. It's enough to drive a man to make a soft porn
video of the experience.
I still prefer an AirHawk with the continuous flow of breast like cushions supporting
my willing ass.
Old 01-31-2013, 07:56 PM   #15825
Specterx
Specterx's Avatar
Oddometer: 31
The perfect seat for someone who has ever broken their tail bone. Or just someone who doesn't have back...
Have you done a long trip on it yet? On long trips my tailbone is what gets soar. So I am guessing this seat doesn't have that problem at all. But how comfortable is it?
Specterx is offline   Reply With Quote
Times are GMT -7.   It's 06:37 PM.
