Old 01-31-2013, 06:29 PM   #301
bmwktmbill
Traveler
Oddometer: 4,002
Loosen the oil filter...retighten. run, repeat.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 02-07-2013, 06:57 PM   #302
gunnerbuck
I.Hopp.
Oddometer: 3,078
Hi Flo Filters
I have been using Hi Flo filters from day one on my 640s mainly because of economics... The OEM spin on filters through KTM are priced around $25 and the paper filters about $10 which adds up to about $35 combined... I buy the Hi Flo filters in bulk and can get 3 of each {6} for the same price... If you are looking to do the same I found that these guys have good prices on Hi Flo filters and will soon have a proper website up: http://www.classiccycleparts.com/
640 A x 2
gunnerbuck is offline   Reply With Quote
Old 03-01-2013, 11:00 AM   #303
zsmiley88
Oddometer: 6
Hey guys, I have recently changed my oil and apparently made the mistake of putting too much oil in. I discovered this when my 98 620 LC4 started running poorly after about 150 miles. BTW when it began running poorly there was a significant amount of oil in the air box. I have since drained the oil to the proper amount but the oil smells of fuel and seems awfully thin. Do you recommend just starting over with a fresh oil change and new filters? Or am I screwed?
zsmiley88 is offline   Reply With Quote
Old 03-01-2013, 02:26 PM   #304
Droptarotter
Oddometer: 827
If the oil smells like fuel, I would change it again.
How did you get fuel in the oil???
You are not screwed........it's nothing that time and money won't fix.
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 03-01-2013, 03:01 PM   #305
zsmiley88
Oddometer: 6
That's what concerns me. From my understanding, fuel has no place any where near oil. Money is something I have access to, time however is a different story. Which leads me to my second conundrum; if I have no time, is it worth fixing? Things to think on I guess.
Old 03-01-2013, 03:13 PM   #306
Antikid
Oddometer: 66
it really warms my lc4 powered heart to see that this thread is still active
i have the instructions printed, and still use them. granted i have only put about 11k miles on my 625SMC
05 KTM 625 SMC
09 KTM 200 XCW
00 KTM 200 MXC
Antikid is offline   Reply With Quote
Old 03-01-2013, 09:55 PM   #307
gunnerbuck
I.Hopp.
Oddometer: 3,078
With the fuel smell in your oil what you may have is a faulty float needle or a chunk of debris holding it open in the carb... When the carb float bowl fills to the correct level the needle/seat is supposed to stop any further flow of fuel until the level drops... If the needle does not do it's job then the fuel will keep on flowing, making your engine rich when running... When your engine is not running and the fuel tap is open it is possible for the fuel to make it's way into your engines base with gravity and mix with the oil...
640 A x 2
Old 03-01-2013, 10:25 PM   #308
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 1,235
What gunner said. If the petcock is open while the bike is off and the float valve leaks, gas drains and overflows through the carb and past the piston into the crankcase. If your oil smells strongly like gas you should change it and fix the cause. Remember, your oil is now as flammable as gas so be careful around sources of ignition!
Sent from my SCH-I535 using Tapatalk 2
Sparrowhawk is online now   Reply With Quote
Old 03-02-2013, 09:50 AM   #309
zsmiley88
Oddometer: 6
Thanks guys! This actually makes a lot of sense. The bike has sat longer than expected and I did not properly prepare it for storage. For the time being i am going to drain the fuel, then when I have some spare time I will change the oil and clean the carb and fuel tank. Thanks so much for the advice.
Old 03-02-2013, 07:30 PM   #310
bmwktmbill
Traveler
Oddometer: 4,002
Replace the rubber tipped needle and the O-ring,
set the floats.
b
Bill Shockley
Old 03-11-2013, 03:07 PM   #311
pondo
bantu
Oddometer: 13
Send a message via Skype™ to pondo
Hi Guys - im a new lc4 adventure owner and decided to do an oil change. all went well but i just have two questions which ive searched the answers for to no avail. i filled it up with motorex oil and the oil through the sight glass is still black. should i flush/change oil again or is this normal. i did get the oil hot and drained it properly and changed all the filters. secondly - when the motor runs what should one see in the sight glass? i see oil slowly pulsing down the window. seems the oil is circulating which seems good to me - just want to be sure this is what should be happening. any advice will be appreciated....
pondo is offline   Reply With Quote
Old 03-11-2013, 03:19 PM   #312
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 2,691
Even on the first run of my totally rebuilt & sparkly clean engine my oil turned black quite quickly just like it always has. Don't worry about it. When running & warmed up the oil level should be around the lower sight glass line & it should be flowing down like you say.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is online now   Reply With Quote
Old 03-11-2013, 03:24 PM   #313
pondo
bantu
Oddometer: 13
Cheers
Clint
thank you clintnz. suppose all i need to do now is ride...
Times are GMT -7.   It's 02:27 AM.
