Thread Tools Rating: Thread Rating: 59 votes, 5.00 average. Display Modes
Old 01-28-2013, 06:32 PM   #286
Hodakaguy OP
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,092
Originally Posted by Mr. Fisherman View Post
Wow Tom, that is looking good
What are you preping the axles for?
Going to powder coat the front axles the same color red that the back axles were done in
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 01-28-2013, 06:34 PM   #287
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,092
Originally Posted by ducnut View Post
I did the 4-light high beam conversion on my Silverado. My relay power runs straight off the battery, as it's right behind the left headlight. Where did you tap into? The main power to the panel?
Very "euro". I like it.
The fuse box had a couple open slots on it's power distribution block so I was able to tap in at the fuse box :-)
Hodakaguy
Old 01-28-2013, 06:34 PM   #288
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,092
Since I needed to take the lights out one more time to clean up the wiring I decided to add local grounds at the same time, this should guarantee no grounding issues with the lights.
Soldering and heat shrinking the new ground wire to the harness.
Wiring cleaned up and ground installed.
Hodakaguy
Old 01-28-2013, 08:59 PM   #289
Mrmerlin
K1300S fast as shi..
Mrmerlin's Avatar
Oddometer: 339
really like the headlight upgrade,
I would put a piece of 3M paint protectant film on all of the glass,
check out the possibility of using some HID lights for the low beams,
they are reasonable priced and put out lots of light suggest to use 4300kv version for the best light not the 5600 its too blue
Mrmerlin is offline   Reply With Quote
Old 01-28-2013, 09:23 PM   #290
Mr. Vintage
Family Dude
Mr. Vintage's Avatar
Oddometer: 866
Lookin' good, Hodaka. What kind of 7" lights are those? I'm just curious what you went with; I have H4 copies on my van and I took a rock to one, so I'm looking for replacements. I think I'll get some of that clear headlight film too - it seems that with their carefully streamlined shape vanagons might be more susceptible to road debris.
- Jeff (Mr. Vintage) -
Quota, SL350, MW250, MT250, CT90
Mr. Vintage is offline   Reply With Quote
Old 01-29-2013, 07:21 AM   #291
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,092
I'm using the bosch 1 305 603 038 assemblies. I've used the 3m headlight guard before, good stuff!
Yeah the Vanagon is pretty streamlined lol.
Hodakaguy
Old 01-29-2013, 08:53 AM   #292
ducnut
Oddometer: 3,320
If the housing is not a projector beam, a HID bulb will just scatter the light, which blinds every oncoming driver. A projector beam is a lot like pencil beam reflector in that it concentrates the beam onto a desired area. A standard housing isn't much more than a reflector or mirror behind a bulb. If you compare a standard type bulb to a HID bulb, you'll see they are totally different in the way they direct light.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 01-31-2013, 05:25 AM   #293
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,092
This is the same experience I've had with HID bulbs in Non-HID housings. I think the H4's in the grill and a couple HID's on the push bar should work pretty good.
Hodakaguy
Old 01-31-2013, 06:47 AM   #294
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,867
HID is not good on the Vanagon. It will blind oncoming traffic. I'm thinking about replacing my halogen fog lights with LED lights.
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 01-31-2013, 09:03 PM   #295
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,120
The retrofit source has some nice HID projectors for a reasonable cost, to retrofit existing headlights, or mount them up as driving lights. I put one in my motorbike, really nice light and clean cutoff.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 02-01-2013, 07:49 PM   #296
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,092
A little powder coating today in preparation for getting the front end back together.
Pre-heating the axles a bit in the oven before heading outside to powder coat.
Hanging to cool down after coming out of the oven.
Preparing the hubs to receive powder.
Finished product.
Hodakaguy
Old 02-01-2013, 11:30 PM   #297
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,776
Purdy
Mr. Fisherman is offline   Reply With Quote
Old 02-02-2013, 03:58 PM   #298
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,092
Progress continuing.
Time to get the hubs put back together.
Pressing the new bearing into the housing.
Good thing I saved the old bearing. The old bearing outer race worked great to finish seating the new bearing.
Installing the new Circlip
The old bearing race is also a perfect fit to drive in the new seals.
Pressing the hub into the new bearing. The bearing inner race is being supported from the bottom.
Lookin good.
Finished applying a coat of POR 15 to all the newly drilled screw holes for the center lights, sealed all the connections with Dielectric grease and re-assembled/tested the lights.
Hodakaguy
Old 02-03-2013, 10:06 PM   #299
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,092
Installed the new Rocky Mountain Westy plate bumper today.
Original bumper removed.
And the new RMW Plate bumper installed :-). Oh yeah, that looks a LOT better.
Hodakaguy
Old 02-04-2013, 01:10 AM   #300
Mr. Fisherman
PROUD 2B Riff Raff!
Oddometer: 10,776
Dig that
Thread Tools
Times are GMT -7.   It's 12:42 AM.
