Thread Tools Search this Thread Rating: Thread Rating: 335 votes, 4.92 average. Display Modes
Old 01-31-2013, 06:31 AM   #6781
dlh62c
Oddometer: 1,603
Originally Posted by snooker View Post
…. are people often just intermixing old terminology from previous Garmin apps and hardware and not necessarily the Basecamp and Montana combo terms?
I think that’s part of it. I can certainly see the confusion in the use of the terminology. Some people are using Basecamp, but thinking in terms of Mapsource. Even Garmin has been misleading at times. The intent of my post was not to confuse anyone about via points. The intent was to point out that the user can keep tabs on the via point total as they tailor their route in Basecamp.
Shaping points are a special type of Via Points in Basecamp but that are added just to force a route to go a certain path (usually after and/or before a turn). Technically to be a "shaping point", in the Properties Tab, right click on a Via Point and select "Don't Alert on Arrival (shaping point)" so then this becomes a Shaping Point type of via.
What your doing is turning on or off wither there will be an announcement of the via point on the GPS screen as you approach it. If you right click on the via point, a drop down list will appear that will allow you to change its property to ‘Alert On Arrival’ or ‘Don’t Alert on Arrival (Shaping Point)’. Not all gps support non announcement of shaping points. I’m not sure about the Montana.
One thing you want to check is via point placement on divided highways. Zoom in and make sure that the via point is placed in the correct lane for the direction of travel. Instead of placing via points at the intersection, put them just past the intersection on the road you wish to travel. You also need to zoom in close enough so as to avoid clicking on POI’s and making them via points. On the other hand, via points can also be a POI, a city park, a cafe or a gas station. These you might want to set the via point's property to 'Alert On Arrival', if you want to stop there.
- I think like many people I want to go from Start to Finish and I want to take certain roads to get there. But just because I end up adding Via Points in between the Start and Finish to shape the route, I don't want to be FORCED to hit each Via Point as a real destination, I mean if I pass one by then just keep routing me towards the Finish only and forget any Via I have already passed.
Is this possible?
On my 62s, I set 'Off Route Recalculation' to 'Off'. This prohibits the gps from recalculating the route. If I overshoot the route, I can zoom out, see where I'm at in relation to it and work my way back. Some gps's like the Delorme PN40 allow you to set the off route recalculation threshold, i.e. distance from route, before it recalculates. This is handy, should you ride off the route when refueling or getting something to eat.
I hope this answered your questions.
daryl
dlh62c screwed with this post 01-31-2013 at 10:37 AM
Old 01-31-2013, 07:47 AM   #6782
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,410
The Montana does support non announcements of points.
Old 01-31-2013, 07:53 AM   #6783
Rocky TFS
Rocky TFS's Avatar
Oddometer: 561
I'm guessing that a lot of the use of terms (via vs. shaping) comes from past GPSr's (perhaps Zumo?) but I want to know if this is correct........
Here is a discussion I lifted from the Basecamp forum some time ago that may clear up some confusion:
Originally Posted by KGANSHIRT
The concepts are quite simple. It's the method of distinguishing one from the other that is likely quite subtle in the code.
POI - A formal Point Of Interest. An entry in the internal POI database with a name, location and usually other information associated with it.
Waypoint - Any arbitrary point on the map that you have designated you want to keep track of. Usually stored in the "Favorites" or "My Locations" or whatever your personal navigation device calls its waypoint storage database. Your device will usually allow you to store such things as the location, any arbitrary name you want to supply and other information such as address, phone number, category(ies) and a symbol/icon to be used when displaying it.
Via Point - A point used to create a multipoint route, e.g. Go from Point A to Point B via some other arbitrary point(s) that you will designate. If your personal navigation device supports multipoint routing, the via point can be a POI, an existing waypoint/favorite or any other form of location that is searchable on your device, e.g. address, intersection/junction, custom POI, etc. In most cases, to use something as a via point it must already exist in one of the devices' searchable databases.
Shaping Point - In Mapsource, to "shape" a route to go exactly where you want there are a couple of methods. Just as with the personal navigation device, you can edit the route's properties to insert Via points (these are not shaping points although they do serve a similar purpose). You can also just use the route tool to click on spots on the map to force the shape of a route. When you do that, you are using a location that is not already in one of the searchable location databases. Mapsource does not force you to add these points to any of the formal databases. It simply inserts the actual coordinates invisibly into the route. These are shaping points.
Shaping points occur in another, automatic, fashion as well. Even when you only designate a two-point route, e.g. go from Point A to Point B, there will usually be multiple places, usually intersections, where a change in direction is required. When building the route, the personal navigation device (or Mapsource/Basecamp) will automatically include all of these points in the route.
To easily illustrate this, you can create a two-point route in Mapsource by clicking on a Point A and a Point B that will require a few turns to get from one to the other. Now export the route to a GPX file and take a look at it with Notepad or your favorite text editor. You will see that, in addition to the starting point and the ending point, there will be a bunch of other points in the file to control all the turns.
I apologize if you already knew all that. Perhaps it will be helpful to others with inquiring minds.
And yes, these terms are often misused, adding to the confusion.
Rocky TFS is offline   Reply With Quote
Old 01-31-2013, 05:16 PM   #6784
TravellingStrom
TravellingStrom's Avatar
Oddometer: 397
Posting a light blue on white text means it is invisible to me so I will have to skip it :(
www.travellingstrom.com
TravellingStrom is offline   Reply With Quote
Old 01-31-2013, 05:32 PM   #6785
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,591
Is this better?
Old 01-31-2013, 06:34 PM   #6786
Rocky TFS
Rocky TFS's Avatar
Oddometer: 561
Oops, sorry....
Something weird happened when I pasted it..
Thanks MBD..
Old 02-01-2013, 02:15 AM   #6787
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,756
Originally Posted by Emmbeedee View Post
You might have an early unit. Have you called Garmin?
r.e touchscreen problems
They took it off me today and I will get a refurbished one in a couple of weeks - you were right they said it was an earlier model thanks
But the fact that some geniuses were laughed at does not imply that all who are laughed at are geniuses. They laughed at Columbus, they laughed at Fulton, they laughed at the Wright Brothers. But they also laughed at Bozo the Clown.
Carl Sagan
Beer'o'clock Baz is offline   Reply With Quote
Old 02-01-2013, 04:53 AM   #6788
TravellingStrom
Oddometer: 397
Thanks for the reposted NON blue on white explanation Emmbeedee, my eyes are grateful
No worries to the original poster, some people have different themes so the colour schemes are not the same anyway
But, to the post, as it explains, I personally do not use VIA points, I seem to use shaping points if I do it manually to force it, or it adds a bucket load in by itself
Cheers from a bar in Siem Reap, Cambodia
TravellingStrom
Old 02-01-2013, 05:03 AM   #6789
Elsjo
Oddometer: 17
New software 4.70 http://www8.garmin.com/support/downl...ls.jsp?id=5335
Elsjo is offline   Reply With Quote
Old 02-01-2013, 05:58 AM   #6790
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,022
What kind of point does it make if I grab the route with the arrow shaped tool and rubber band it to a road?
Old 02-01-2013, 06:08 AM   #6791
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 700
Shaping point.
IBA #33260
cablebandit is offline   Reply With Quote
Old 02-01-2013, 06:17 AM   #6792
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,022
Originally Posted by cablebandit View Post
Shaping point.
Thanks! Are we limited in the Montana as to how many of those there can be in a route?
Old 02-01-2013, 08:11 AM   #6793
lmychajluk
Oddometer: 1,927
Not sure if this is the right place to ask, but here it goes - If I have different maps for the Montana, can I load them all onto a single SD card and switch between them? Was hoping to be able to do City Nav, Topo, and BlueChart by buying the DVD versions and not swap SD cards.
Also, as an FYI - If you're a Citi customer w/ reward points, they have the Montana 600. It's a ridiculous # of points (120K or so, IIRC), but if you're not using your points for anything else, why not? Actually, it would probably be cheaper to buy 10 $50 Amazon or BestBuy gift cards for 60,000 points and just buy it there...or maybe 5 Cabelas $100 cards for 10,000 each?
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is online now   Reply With Quote
Old 02-01-2013, 09:18 AM   #6794
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
YES!
More info here.
Buying DVD versions is my first choice, AFTER checking GPSFileDepot for free maps that have the information I need.
atlas cached is offline   Reply With Quote
Old 02-01-2013, 09:33 AM   #6795
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,410
Shaping points, no. Via points yes, limited to 50 per route.
Times are GMT -7.   It's 02:42 PM.
