Thread Tools Search this Thread Rating: Thread Rating: 41 votes, 4.34 average. Display Modes
Old 02-01-2013, 08:18 AM   #6811
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 413
Originally Posted by lmychajluk View Post
Not sure if this is the right place to ask, but here it goes - If I have different maps for the Montana, can I load them all onto a single SD card and switch between them? Was hoping to be able to do City Nav, Topo, and BlueChart by buying the DVD versions and not swap SD cards.
YES!
More info here.
Buying DVD versions is my first choice, AFTER checking GPSFileDepot for free maps that have the information I need.
Garmin Montana Wiki Oregon 6xx Wiki BaseCamp Wiki
atlas cached is online now   Reply With Quote
Old 02-01-2013, 08:33 AM   #6812
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,823
Originally Posted by Emoto View Post
Thanks! Are we limited in the Montana as to how many of those there can be in a route?
Shaping points, no. Via points yes, limited to 50 per route.
Guess what doofus, nobody reads your lame blog.
Old 02-01-2013, 09:23 AM   #6813
lmychajluk
Oddometer: 491
Originally Posted by atlas cached View Post
YES!
More info here.
This was why I was asking (from your link):
Map Names
These are default map names used by Garmin. Do not use these file names when naming your maps.
  • gmapprom.img | Primary or Pre Installed Map
  • gmapprom1.img | Secondary Map
  • gmapbmap.img | Device Base Map
  • gmapoem.img | OEM Installed Map (can not be disabled in Map Settings)
  • gmapsupp.img | Map written to device or uSD card by MapSource, BaseCamp or MapInstall
Let's say I get the DVD for City Navigator and BlueChart, will they both use gmapsupp.img as the fileame when transfering the maps to the SD card, overwriting each-other? Or are they kept seperate, allowing you to select which you want to use? Again, I just want to be able to load all my maps onto an SD card (maybe have the Topo built-in w/ the 650t) and not have to switch SD cards or re-load maps from a PC.
Thanks.
-Lee
lmychajluk is online now   Reply With Quote
Old 02-01-2013, 09:47 AM   #6814
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 16,133
If I understand this correctly, as long as I am using the "grab the route and rubber-band it to the road I want to follow" method, I will not bump into limits.
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA
Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/
Old 02-01-2013, 10:03 AM   #6815
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,823
Yup, but that can be a real PITA method for route creation.
Old 02-01-2013, 10:12 AM   #6816
atlas cached
OX Ambassador
Oddometer: 413
Thanks.
I don't know if you are using a Mac or PC, but links exist on that page to walk you through sending maps to your GPSr from either, with three options for PC users.
If you DO NOT use MapSource, the IMG maps sent to your GPSr will not be titled gmapsupp.img, but rather some other name taken from the map data.
If you do use MapSource (I do not advise it), the map sent will be named gmapsupp.img, but, as the walk through instructs, you can simply rename that file once the transfer is complete.
Newer Garmin GPSr units allow for maps to be titled as you see fit, so long as the .img extension is used.
Send Map. Rename Map. Repeat.
Old 02-01-2013, 10:26 AM   #6817
woodsatyr
What?!!!
woodsatyr's Avatar
Oddometer: 233
What defines an earlier unit? Do you have a serial number range or something?
I'm still hot... it just comes in flashes now.
woodsatyr is offline   Reply With Quote
Old 02-01-2013, 10:37 AM   #6818
dlh62c
Oddometer: 1,562
Emoto
Can you do me a favor?
Attempt to load these two files into your Montana, One has 51 viapoints, the other 52. If they load correctly you should get the 'GO' prompt in the Montana's screen.
Also do you see blue flags along the route for each viapoint added?
daryl
Old 02-01-2013, 10:37 AM   #6819
dlh62c
Oddometer: 1,562
Here's the other file.
daryl
Old 02-01-2013, 10:48 AM   #6820
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 16,133
Ok. Stand by.
Old 02-01-2013, 10:55 AM   #6821
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 42,791
Originally Posted by Emmbeedee View Post
I think we need to take this up with Garmin Cartography. Here's a series of screen shots I made tonight, while simulating a route through the 417 to Alexandria. As seen in the shots, it clearly looks like you're to get off at the Metcalfe street exit. Even the lane indicator says so.
Nice to know I wasn't just seeing things.
Thanks Mike.
Is that latest citynav too?
Life is not measured by the number of breaths we take,
but by those moments that take our breath away.
George Carlin
Drif10 is offline   Reply With Quote
Old 02-01-2013, 11:27 AM   #6822
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 16,133
Originally Posted by dlh62c View Post
Emoto
daryl
They both load to the device without problem using basecamp on a pc.
Where to > routes> 51 =
It takes a bit of time for the map to paint, then the magenta route shows, then it gets covered with blue push pins.
Yes, I get the GO button. When I click GO, it appears to commence navigation normally, although I am 1200 miles from the start.
When I click the 1279 up in the upper left corner, it shows me this:
Where to > routes> 52 =
I do NOT get the go button with the route showing on the map like I did with 51.
However, if I click the rectangle at the top center that says 52ViaPoints, I get this:
And when I click GO, I get this:
When I click OK, it takes me back to:
...and that cycle repeats endlessly if I keep clicking the 52ViaPoints box, so there may be no way to use that one. However, this was using CN. I did not try it with the 100k topo set.
If any of the above is useful, you guys can put it on the wiki or wherever; I don't mind.
Old 02-01-2013, 12:07 PM   #6823
dlh62c
Oddometer: 1,562
Emoto
Thanx!
That's what I see on my 62s. The route with 51 via-points will load, the route with 52 will not. The routes were made using Basecamp. The routes should be the same except for one via-point being added. Keep in mind, the effort was some what rushed. The route via-point details can be seen in the route property window in BC
The points were added using the route 'Insert' tool. So by most people's definition, these would be considered route shaping points. IMO any point used to tailor a route is considered a via-point. It could be a point placed on a road as a shaping point or a series of way-points strung together or a combination of both.
daryl
dlh62c screwed with this post 02-01-2013 at 12:36 PM
Old 02-01-2013, 12:29 PM   #6824
mass-klr
mass-klr's Avatar
Oddometer: 66
"More" detail
I found out that the Montana will freeze or take a long time to catch up so that it is not usable if you increase the Details setting and drive into the city. Seems like there is just too much things to load and it just freeze. As soon as I get out of the city with less roads and businesses it will work fine again. Is this the same for everyone else?
_____________________________
Leon
'11 Orange KLR650
mass-klr is offline   Reply With Quote
Old 02-01-2013, 12:39 PM   #6825
Stromberg
Oddometer: 1
Hello evryone, i just saw that a new firmware version is available, 4.70.
Changelog:
Change History
Changes made from version 4.60 to 4.70:
Improved Ascent and Descent calculation.
Improved map performance in densely-populated urban areas.
Improved EXIF image direction data in camera photos (650 and 650t models).
Fixed potential issue with 'External Power Only' automatic mount detection option. See TrailTech (http://garmin.blogs.com/softwareupda...MountDetection) for more information.
Fixed issue where default vehicle names and default background image names were not being translated.
Fixed issue with trip odometer where distance between two tracks would be incorrectly added to the total distance.
Fixed potential issue where waypoint averaging would not create a correct waypoint gpx file.
Fixed issue with distorted battery icon when on landscape charging page and when charge reaches 100%
Fixed potential issue with numerical keyboard in landscape orientation
http://www8.garmin.com/support/downl...ls.jsp?id=5335
Stromberg is offline   Reply With Quote
Times are GMT -7.   It's 10:16 AM.
