Go Back   ADVrider > Riding > Mapping & Navigation
Thread Tools Search this Thread Rating: Thread Rating: 458 votes, 4.94 average. Display Modes
Old 02-01-2013, 09:23 AM   #6796
lmychajluk
Oddometer: 2,116
Originally Posted by atlas cached View Post
YES!
More info here.
Buying DVD versions is my first choice, AFTER checking GPSFileDepot for free maps that have the information I need.
This was why I was asking (from your link):
Map Names
These are default map names used by Garmin. Do not use these file names when naming your maps.
  • gmapprom.img | Primary or Pre Installed Map
  • gmapprom1.img | Secondary Map
  • gmapbmap.img | Device Base Map
  • gmapoem.img | OEM Installed Map (can not be disabled in Map Settings)
  • gmapsupp.img | Map written to device or uSD card by MapSource, BaseCamp or MapInstall
Let's say I get the DVD for City Navigator and BlueChart, will they both use gmapsupp.img as the fileame when transfering the maps to the SD card, overwriting each-other? Or are they kept seperate, allowing you to select which you want to use? Again, I just want to be able to load all my maps onto an SD card (maybe have the Topo built-in w/ the 650t) and not have to switch SD cards or re-load maps from a PC.
Thanks.
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is offline   Reply With Quote
Old 02-01-2013, 09:47 AM   #6797
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,196
Originally Posted by Albie View Post
Shaping points, no. Via points yes, limited to 50 per route.
If I understand this correctly, as long as I am using the "grab the route and rubber-band it to the road I want to follow" method, I will not bump into limits.
Old 02-01-2013, 10:03 AM   #6798
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,937
Yup, but that can be a real PITA method for route creation.
Old 02-01-2013, 10:12 AM   #6799
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Thanks.
I don't know if you are using a Mac or PC, but links exist on that page to walk you through sending maps to your GPSr from either, with three options for PC users.
If you DO NOT use MapSource, the IMG maps sent to your GPSr will not be titled gmapsupp.img, but rather some other name taken from the map data.
If you do use MapSource (I do not advise it), the map sent will be named gmapsupp.img, but, as the walk through instructs, you can simply rename that file once the transfer is complete.
Newer Garmin GPSr units allow for maps to be titled as you see fit, so long as the .img extension is used.
Send Map. Rename Map. Repeat.
atlas cached is offline   Reply With Quote
Old 02-01-2013, 10:26 AM   #6800
woodsatyr
Kitty Boy
woodsatyr's Avatar
Oddometer: 504
What defines an earlier unit? Do you have a serial number range or something?
woodsatyr is offline   Reply With Quote
Old 02-01-2013, 10:37 AM   #6801
dlh62c
Oddometer: 1,603
Emoto
Can you do me a favor?
Attempt to load these two files into your Montana, One has 51 viapoints, the other 52. If they load correctly you should get the 'GO' prompt in the Montana's screen.
Also do you see blue flags along the route for each viapoint added?
daryl
Old 02-01-2013, 10:37 AM   #6802
dlh62c
Oddometer: 1,603
Here's the other file.
daryl
Old 02-01-2013, 10:48 AM   #6803
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,196
Ok. Stand by.
Old 02-01-2013, 10:55 AM   #6804
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,738
Originally Posted by Emmbeedee View Post
I think we need to take this up with Garmin Cartography. Here's a series of screen shots I made tonight, while simulating a route through the 417 to Alexandria. As seen in the shots, it clearly looks like you're to get off at the Metcalfe street exit. Even the lane indicator says so.
Nice to know I wasn't just seeing things.
Thanks Mike.
Is that latest citynav too?
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 02-01-2013, 11:27 AM   #6805
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,196
Originally Posted by dlh62c View Post
Emoto
daryl
They both load to the device without problem using basecamp on a pc.
Where to > routes> 51 =
It takes a bit of time for the map to paint, then the magenta route shows, then it gets covered with blue push pins.
Yes, I get the GO button. When I click GO, it appears to commence navigation normally, although I am 1200 miles from the start.
When I click the 1279 up in the upper left corner, it shows me this:
Where to > routes> 52 =
I do NOT get the go button with the route showing on the map like I did with 51.
However, if I click the rectangle at the top center that says 52ViaPoints, I get this:
And when I click GO, I get this:
When I click OK, it takes me back to:
...and that cycle repeats endlessly if I keep clicking the 52ViaPoints box, so there may be no way to use that one. However, this was using CN. I did not try it with the 100k topo set.
If any of the above is useful, you guys can put it on the wiki or wherever; I don't mind.
Old 02-01-2013, 12:07 PM   #6806
dlh62c
Oddometer: 1,603
Emoto
Thanx!
That's what I see on my 62s. The route with 51 via-points will load, the route with 52 will not. The routes were made using Basecamp. The routes should be the same except for one via-point being added. Keep in mind, the effort was some what rushed. The route via-point details can be seen in the route property window in BC
The points were added using the route 'Insert' tool. So by most people's definition, these would be considered route shaping points. IMO any point used to tailor a route is considered a via-point. It could be a point placed on a road as a shaping point or a series of way-points strung together or a combination of both.
daryl
dlh62c screwed with this post 02-01-2013 at 12:36 PM
Old 02-01-2013, 12:29 PM   #6807
mass-klr
mass-klr's Avatar
Oddometer: 185
"More" detail
I found out that the Montana will freeze or take a long time to catch up so that it is not usable if you increase the Details setting and drive into the city. Seems like there is just too much things to load and it just freeze. As soon as I get out of the city with less roads and businesses it will work fine again. Is this the same for everyone else?
_____________________________
Leon
'11 KLR650 ... '04 DRZ400S
Paved Roads are just another example of wasted Taxpayer Dollars
mass-klr is offline   Reply With Quote
Old 02-01-2013, 12:39 PM   #6808
Stromberg
Oddometer: 3
Hello evryone, i just saw that a new firmware version is available, 4.70.
Changelog:
Change History
Changes made from version 4.60 to 4.70:
Improved Ascent and Descent calculation.
Improved map performance in densely-populated urban areas.
Improved EXIF image direction data in camera photos (650 and 650t models).
Fixed potential issue with 'External Power Only' automatic mount detection option. See TrailTech (http://garmin.blogs.com/softwareupda...MountDetection) for more information.
Fixed issue where default vehicle names and default background image names were not being translated.
Fixed issue with trip odometer where distance between two tracks would be incorrectly added to the total distance.
Fixed potential issue where waypoint averaging would not create a correct waypoint gpx file.
Fixed issue with distorted battery icon when on landscape charging page and when charge reaches 100%
Fixed potential issue with numerical keyboard in landscape orientation
http://www8.garmin.com/support/downl...ls.jsp?id=5335
Stromberg is offline   Reply With Quote
Old 02-01-2013, 12:45 PM   #6809
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,196
Emoto
Thanx!
daryl
You're welcome. I wonder what happens if you have "rubber-banded" those points into place.
Old 02-01-2013, 12:55 PM   #6810
Rocky TFS
Rocky TFS's Avatar
Oddometer: 605
Emoto
The points were added using the route 'Insert' tool. So by most people's definition, these would be considered route shaping points. IMO any point used to tailor a route is considered a via-point. It could be a point placed on a road as a shaping point or a series of way-points strung together or a combination of both. But the total can't be more than 51 which includes both the Start & End points.
daryl
No, this is not correct. Re-read post #6802 above. Shaping points, when supported by the device, are NOT part of the allowable total of 51 via points; you can have hundreds. Waypoints or POI's used as points ARE subject to the 51 point limit. It's Garmin's use of these conventions that we need to understand, not our own. Unfortunately these conventions ARE different from one device to another, and so we must understand just how they are used and the limitations on OUR OWN device.
BAD GARMIN!!! GO LIE DOWN!!!
Rocky TFS is offline   Reply With Quote
Times are GMT -7.   It's 10:16 AM.
