Old 01-29-2013, 03:25 PM   #1
flossandfly OP
flossandfly's Avatar
Oddometer: 334
Repair cracked motorcycle windshield
I had 2 cracked spitfire windshields and couldn't bring myself to order a 3rd one without attempting to repair them since one was just cracked. (the other had one piece break right off and cracked the rest)
After googling I found out about Acrylic Cement. Guys use it to make fish tanks out of acrylic and it works well.
I bought IPS Weldon 5 Oz 16 Acrylic Cement
It worked pretty well. It doesn't really act like glue, it acts more like a weld. I used it on the 2 broken windshields and I can now flex them without re-cracking them. I haven't taken a ride with them yet, but they seem to be good.
flossandfly is offline   Reply With Quote
Old 01-29-2013, 04:42 PM   #2
bwalsh
bwalsh's Avatar
Oddometer: 12,033
Can you post some pics?
Prices fluctuate quite a bit on that stuff! A quick online search reveals Wal-Mart wanting $21 for the 5 oz tube. but can get it online for under $8 plus shipping.
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 01-29-2013, 04:49 PM   #3
flossandfly OP
Oddometer: 334
I don't have a picture storing account so can't post pics. That price sounds right.
Old 01-30-2013, 08:51 PM   #4
b1pig
Oddometer: 905
correct me if i'm wrong... but shouldnt stop-drilling also prevent the cracks from spreading? i've done that with plastics and sheet metal.
got pics of the repairs? does sound interesting.
b1pig is online now   Reply With Quote
Old 01-30-2013, 11:07 PM   #5
heirhead
Oddometer: 581
shield repair
Hello,
Just finished shield repair 5 mins ago and saw this post, what timing.
Cannot post pics but if someone wants to PM me with there email I will send over for them to post.
You will see the work of a true craftsman.
Heirhead
heirhead is offline   Reply With Quote
Old 01-30-2013, 11:24 PM   #6
Contevita
Cigar Adventurer
Contevita's Avatar
Oddometer: 2,964
You can get a free account here http://www.imageshack.us/
And that's just one of many free hosting sites you can choose from.
Now where are those pics?
Contevita is offline   Reply With Quote
Old 01-31-2013, 07:55 AM   #7
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,292
worthless without pics
This thread is worthless without pics!
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 02-01-2013, 01:19 AM   #8
Contevita
Cigar Adventurer
Contevita's Avatar
Oddometer: 2,964
I see you went to the wrong end of the French Quarter before the Super Bowl.
Old 02-01-2013, 07:43 AM   #9
foxtrapper
Oddometer: 853
Well shoot, that would be a heck of an improvement over my normal practice of using zip ties to stitch it back together.
foxtrapper is offline   Reply With Quote
Old 02-01-2013, 08:31 AM   #10
Skippii
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,508
Here's my method which has worked well, but I warn you it's not the prettiest. On a dark/smoked windscreen it's alright, but I probably wouldn't do it on a clear one.
With everything nicely held in place, melt/cut a trough in the back of the windshield with a soldering gun (I got my 230W one years ago from radioshack for about $30, but 100W or probably a lot less would work just as well) so everything is attached correctly. Scrape up the burrs or lightly sand with rough grit, and then fill in the trough you melted with plastic epoxy.
Super cheap to do, and works just fine.
"Umm be careful what you say, this is Skippii....
You may get it delivered in the form of a shake or some interperative dance routine that involves nakedness, pizza and a stuffed raccoon..." -DCrider
Skippii is offline   Reply With Quote
Old 02-01-2013, 10:38 AM   #11
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,381
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 02-01-2013, 09:16 PM   #12
Contevita
Cigar Adventurer
Contevita's Avatar
Oddometer: 2,964
Originally Posted by heirhead View Post
Hello,
Heirhead
Here are your pics...
I'll let you expain what we're seeing here.
Old 02-01-2013, 09:30 PM   #13
heirhead
Oddometer: 581
artisan at work
Hello,
Thanks to Contevita for posting pics of my Beautiful repair of my Parabellum shield off dr650, also pictured.
Clean crack do to pilot error. Wanted it to be strong. like a weld, stronger than the material. Edges of 16 ga, 6" steel are very sharp as you can see. Won't break in this spot again. Bending the steel both ways to the contour of the shield is tricky. Neighbors on Harleys won't ride unless I ride something else.
Kind of gives off that macho Bobber look, you think?
Heirhead
Worlds worst mechanic
Old 02-02-2013, 09:43 AM   #14
flossandfly OP
Oddometer: 334
That picture is exactly what the acrylic cement repair looks like. It is not pretty but is simple to do and appears to be quite strong.
That pic of the large lady made me laugh.
Old 02-02-2013, 10:06 AM   #15
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,718
Originally Posted by Ricardo Kuhn View Post
Chain links???? That's pretty crafty. Just my answer I was looking for some off the shelves "thingies" for a rivetted seat cover job.Usually blued when new, that's also easy to redo if working out of the scrap pile. Gun blue does have uses on motorcycle sometimes if just for looks.
Looks like you rivetted on the bags also. BMW bags can be a real pita for that, twin walls in some parts with a space in between and if you poprivet may squeeze and they'll crack. Had to do that and ended up filling the void space with expansion foam just so I could rivet without more crackings.
Someone just gave me one of them kits to fill gaps & cracks. That's industrial strenght CA and 2 little jars of black and grey powders to use as a filler then set with the CA.
This stuff, Q-Bond:
http://www.amazon.com/Bond-Repair-Sm.../dp/B003YI421I
Have tools, will travel!
Times are GMT -7.   It's 07:29 PM.
