View Results: Which option should I go with?
Option 1 5 100.00%
Option 2 0 0%
Voters: 5. You may not vote on this poll
Old 01-23-2013, 03:13 PM   #46
Black-Ops
The left one....
Black-Ops's Avatar
Oddometer: 120
So bad it didn't work. Try again
Roam if you want to.
Black-Ops is offline   Reply With Quote
Old 01-23-2013, 03:28 PM   #47
brieninsac
brieninsac's Avatar
Oddometer: 206
The RAM Mount is the way to go! Very solid and reliable. I feel very comfortable with it holding my iPhone. The cradle that the phone sets in works great and can be rotated slightly.
I also installed the TAPP USB outlet to power the phone. It's a new model with 2.1 amps to charge more power hungry devices like tablets.
Installation was pretty simple. One end is secured to the handle bars and the other end is wired to the battery. There's a rubber cap to cover the USB port when not in use and to keep moisture out. I found that it drained my battery after a few days so I installed a cut-off switch and it hasn't been a problem since.
Here are some pics of the install and final product.
I have a short black iPhone USB cable on order
Charging the iPad
2012 Kawasaki KLX250S
Dynojet FMF Q4 K&N Air Filter KDX Snorkel RAM Mount
15/42 Pirelli Scorpion MT 90/AT Pro Moto Rack Seat Concepts
brieninsac is offline   Reply With Quote
Old 01-23-2013, 07:18 PM   #48
worwig
Oddometer: 1,300
Do you find that the X-Grip lets the phone rotate a bit clockwaise and counter-clockwise?
I found that annoying so I prefer the finger grip. It was annoying to look down and see the map or whatever twisted to the side.
Hog mountain Weather
worwig is offline   Reply With Quote
Old 01-23-2013, 07:41 PM   #49
brieninsac
brieninsac's Avatar
Oddometer: 206
It has a little give both ways which is fine for me. But it would nice to go into a portrait mode at times too.
Old 01-31-2013, 09:40 AM   #50
darkstarmoto
Am I evil? Yes I am
darkstarmoto's Avatar
Oddometer: 415
FINALLY for the 5! And is a ADV vendor http://advrider.com/forums/showthrea...ght=interphone
I had the ultimate add on version for my 4S and never gave it a second thought being out in the elements.
http://interphonewireless.com/produc...ars-smiphone5/
05 KTM 950ADV - 08 KTM 690 SMR - 07 Ducati MTS1100S - Redneck Engineering Mutant
darkstarmoto is offline   Reply With Quote
Old 02-01-2013, 05:55 PM   #51
Plane Dr
Plane Dr's Avatar
Oddometer: 888
RAM has a PDA mount with adjustable sides 2 solid hooks on the bottom with th top 2 spring loaded. I've used the same mount for all my phones. I'm not a big fan of heavy duty cases as my phone lives with me.
Personally when it rains or is stupid hot it goes in the top box. The Bluetooth works just the same. For long trips build bigger play lists.
http://www.gpscity.com/ram-mount-uni...ond-plate.html
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Old 02-22-2013, 09:12 AM   #52
SantaFeTrailer
Stromtrooper
SantaFeTrailer's Avatar
Oddometer: 320
Just ordered my Otterbox Armor case (they were released today). They have blue and orange, but not green so sorry for all you Kawi riders
I'll post up a report
SantaFeTrailer is offline   Reply With Quote
Old 02-22-2013, 04:50 PM   #53
jprovence
Oddometer: 67
This setup is proving its weight in gold. Waterproof and easy access and very solid.
jprovence is offline   Reply With Quote
Old 02-23-2013, 05:30 PM   #54
ValpoFz OP
Oddometer: 102
Which holder is that?
ValpoFz is offline   Reply With Quote
Old 02-23-2013, 06:27 PM   #55
jprovence
Oddometer: 67
Lifeproof case and bike mount with custom Ram arm added for mounting flexibility. A little spendy at $120 for the case and cradle.
Old 02-24-2013, 05:31 AM   #56
SantaFeTrailer
Stromtrooper
Oddometer: 320
Lifeproof on Santa Fe CL for $60: http://santafe.craigslist.org/app/3636115428.html
Old 02-24-2013, 03:37 PM   #57
MiguelVR
MiguelVR's Avatar
Oddometer: 73
I've been using Lifeproof case with bike holder, and am very happy. The case is solid. Will not try to swim with it, but it will hold any rain and dust. The holder is just perfect. Simple design, it holds tight. For power its simple and easy, but for Iphones 4 you need the original cable charger. Its the only that fits.
MiguelVR is offline   Reply With Quote
Old 02-24-2013, 06:10 PM   #58
jprovence
Oddometer: 67
Lifeproof makes an adapter that fits the 4/4S case.
http://www.lifeproof.com/shop/us_en/...-dock-adapter/
Kind of a rip off.
Old 02-24-2013, 08:03 PM   #59
ValpoFz OP
Oddometer: 102
Hey can you show a pick of the back, on the Lifeproof site I cant see how to get a ram ball mounted to it
Old 02-24-2013, 08:59 PM   #60
jprovence
Oddometer: 67
I used this:
Times are GMT -7.   It's 11:44 PM.
