01-18-2013, 09:25 AM
#76 | |
I Survived The '60s
Oddometer: 1,680
http://www.flickr.com/photos/14934865@N07/ '07 1250 Bandit, '06 650 VStrom, '78 SR500E '68 Yamaha DT1, '78 TT500 and no money http://www.flickr.com/photos/48000856@N06/ |
01-19-2013, 09:29 PM
#77 |
Oops...
A.D.D. is about the best way possible to sum up the flow of my projects...
http://www.mobilemrt.com http://www.dorkpunch.com "I've been going to this high school for SEVEN YEARS. I'm no dummy!" -Charles De Mar. |
01-25-2013, 04:22 PM
#78 |
Oops...
Still trying to figure out my edge former so I whipped this out. I think it turned out incredible... Usually things like this end up as scrap when I touch 'em.
![]() Drew up a shape on a piece of paper real quick, traced it onto some aluminum and hacked it out. ![]() Ran it through the slip roll to give it a bit of a curve and tried it on with some duct tape ![]() ![]() Did a little creative measuring... Made some brackets to mount it to the headlight ears, and viola! ![]() ![]() ![]() ![]() I intended to roll the edge with the edge former but I couldnt get it to work nicely on my scraps, so I just rolled a bead all the way around and filed the edges. Now maybe someday I'll start on the tank...
01-25-2013, 06:33 PM
#79 |
Oddometer: 347
Got any video footage Dorkpunch? Would love to hear how that bike sounds.
I had a FS1-E 'Fizzy' back in the day. Great little bike.
Japan 6 Days Have fun working dude while I ride your Harley! Mt. Fuji Climb On A Varadero Cycles is a mean toy, lady |
01-25-2013, 07:45 PM
#80 |
Oops...
Hmmm... Not sure that I do! Might have a clip of it when I tested the pipe but I kinda doubt it. I'll check though.
01-28-2013, 05:39 PM
#81 |
Oops...
Playing around some more. Working on the seat bump. First attempt was more of a test, I didn't really expect it to work out. Tried to get all fancy, and it didn't turn out.
![]() ![]() Second attempt turned out much better- less fancy, and less shape to it but I think it looks good. ![]() ![]()
01-29-2013, 03:51 AM
#82 |
Oddometer: 501
Nice work Dorkpunch.
These are great small projects for your students to see!
"Dream as if you'll live forever. Live as if you'll die today" James Dean 1993 XR650L 2008 530 EXC-R |
01-29-2013, 04:38 PM
#83 |
Oops...
More on the seat... Hacked out a seat pan and marked out the hole I'm going to cut in in to get it to sit down over the frame.
![]() Trimmed the cover up to accomodate the thickness of the wood. ![]() And worked a bit more on the lip of the cover... getting closer but still have a ways to go.
01-30-2013, 05:20 PM
#84 |
intrpd travlrwanabe
Oddometer: 175
Cafe 75
That is a good looking project you have going.
I let my mom's 69 Trailmaster go @ VMD last year. It hadnt run in 10 years. The guy had it running after 2 days of working in his vender area. We still have a blue 75cc with the long tank and seat with low bars. I found it full of water under the eaves of an old house. The motor is solid (one rusted lump) the tank is full of rust. |
01-30-2013, 06:34 PM
#85 |
Oops...
Cut the hole out of the seat pan so it would fit down over the frame, made a cover for it out of sheet metal, and temporarily mounted the bump. Also cut down the tank mock up a bit, I like it a lot more. The tank will have radiused bends (hopefully) so it will be a little curvy-er.
01-30-2013, 07:12 PM
#86 | |
Is still learning
Oddometer: 254
Thanks for sharing the build with us. I can't wait to see the tank finished! Greetings!
2010 Honda XR 250 Tornado |
02-01-2013, 06:54 PM
#87 |
Oops...
Started on the tank today...
![]() ![]() ![]() Even got the pieces tacked together with my crappy TIG welder without blowing any (major) holes. Turned out great I think, even though I got a little excited about finally starting and used my old measurements, which means the tank sticks down about an inch further than I wanted it too. Oh well... I can camouflage it with some paint if I don't like it.
02-02-2013, 09:59 AM
#88 | |
I Survived The '60s
Oddometer: 1,680
02-02-2013, 10:06 AM
#89 |
Oops...
Its just an old beater Century DC/AC welder a friend gave me broken... I fixed the amp selector thingy and scrounged up a tig torch for it, bought a bottle of argon and a regulator and used it a bit. Couple months ago I finally decided I wanted to do something with aluminum so I figured out how to wire the high frequency stabilizer and set it up for AC...
![]() ![]() I don't think its going to work for this thin stuff. I've been practicing a fair bit and I can get some decent beads but not having the foot control to vary the amps while welding means welding a teensy bit and then waiting for the metal to cool down... My welder only goes down to 30 amps. Seems like thats okay to start, but when I get going it needs to drop down to more like 15. I'll probably tack it all together for now and see if I can figure out how to get my hands on a newer ($$$) machine, or see if I can borrow one at the high school. Thinking I might try to sell this one and maybe a bike or two to fund the purchase of a nice one later this summer. This plate started out at 1/8" thick.. It's well over an inch thick now. ![]()
02-02-2013, 02:34 PM
#90 |
Lost in Space
Oddometer: 486
Cool project. I've got a YL1 I'm giving a mild cafe treatment but the project has stalled with the crappy winter weather. Love these little Yamahas. Looking forward to seeing how yours turns out.
"The memories of a man in his old age are the deeds of a man in his prime" - Pink Floyd
