02-02-2013, 04:41 PM
#76 | |
Red Clay Halo
Oddometer: 11,213
The whining noise sounds like "flyback" which Luke describes in the thread you linked as "very faint whining sound like a tube TV" I see you responded to that thread, but the OP of the thread hasn't been back to ADV since 12-23-2010, so you might not get any reply. Seems like Luke's reply is a good for some areas to check. http://www.advrider.com/forums/showp...51&postcount=8
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx You can be Han Solo, and I can be another Han Solo... |
02-02-2013, 05:18 PM
#77 |
tall drink of water
Oddometer: 344
I remember seeing a red or orange looking wire going into the CDI. Tried to trace it back just by observation and couldn't find the other end. It was cold in the shop and fresh-baked chocolate cookies were calling.
I have a wiring diagram but I noticed some inconsistencies with my harness and what's on the diagram. I don't know if it's allowable to post that diagram - read the concerns from the mods about posting service manuals.
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=Vl7XlZs2CRc (May 2013 trail riding) '02 Kawasaki KX250 L4 http://www.youtube.com/watch?v=Sjgw-yZJdfs (Jan 2013 gopro ) |
02-02-2013, 05:29 PM
#78 | ||
tall drink of water
Oddometer: 344
Cross referencing another interesting thread, similar problem as mine.
From 2006: LC4 CDI issues? In reply #9, bigtators wrote, Quote:
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=Vl7XlZs2CRc (May 2013 trail riding) '02 Kawasaki KX250 L4 http://www.youtube.com/watch?v=Sjgw-yZJdfs (Jan 2013 gopro ) Queen of Spades screwed with this post 02-02-2013 at 05:42 PM |
02-02-2013, 05:31 PM
#79 | |
I.Hopp.
Oddometer: 3,079
A few pages back I mentioned for you to visually inspect the stator and pickup coil, have you done that? I have seen more than a few times where the stator/ pickup running surfaces were scored up and gave intermittent electrical problems similar to what you have been describing... It is very easy to remove the stator/cover { 4 bolts} and if your careful you may get away with reusing the gasket... You'll have to remove the counter sprocket cover as well...
640 A x 2 |
02-02-2013, 05:45 PM
#80 | |
tall drink of water
Oddometer: 344
Another clue by CountPacMan:
02-02-2013, 05:46 PM
#81 | |
tall drink of water
Oddometer: 344
02-02-2013, 05:48 PM
#82 | |
tall drink of water
Oddometer: 344
And this from bigtators:
02-02-2013, 06:05 PM
#83 | |
I.Hopp.
Oddometer: 3,079
It is possible that in your poking and prodding with the tester you may of fried your CDI , hopefully not...
640 A x 2 gunnerbuck screwed with this post 02-02-2013 at 06:13 PM |
02-02-2013, 06:15 PM
#84 |
tall drink of water
Oddometer: 344
Never tested resistance or voltage on any of the CDI wires. The symptoms haven't changed before I even did any of that.
02-02-2013, 06:23 PM
#85 | |
Red Clay Halo
Oddometer: 11,213
Sounds like a possibility... Though $201.55 is quite a bit of a guess... EDIT.. $181.58 for your bike. Neither one as bad as I would have thought actually.
02-02-2013, 06:36 PM
#86 | ||||||
tall drink of water
Oddometer: 344
Next thing I will check out is the start/stop switch. Where did you find a CDI for $181.58? I'm showing KTMWorld listing it as
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=Vl7XlZs2CRc (May 2013 trail riding) '02 Kawasaki KX250 L4 http://www.youtube.com/watch?v=Sjgw-yZJdfs (Jan 2013 gopro ) Queen of Spades screwed with this post 02-02-2013 at 07:11 PM |
02-02-2013, 07:23 PM
#87 | ||||
tall drink of water
Oddometer: 344
Found it on KTM Parts House at $182
Will hold off ordering until I am positive nothing else is causing the problem. I'm beginning to wonder if the loose wires from reply #17 this thread didn't cause the CDI to malfunction.
02-02-2013, 08:29 PM
#88 | |||||
Red Clay Halo
Oddometer: 11,213
Yep, that's the place. I've ordered $300 in bits a pieces from them over the last few months.
02-04-2013, 08:41 AM
#89 | |
tall drink of water
Oddometer: 344
Update:
I placed an order for a replacement/spare CDI with KTM Parts House. I haven't ruled out other problems (see further below) but ran into trouble getting a headlight switch last year (discontinued for the 99 model). This machine is getting some age on it, and I don't want to run into a similar problem with a CDI. Also ordered a spare start/stop switch for the same reason, since I've read that part has been associated with failures on some LC4's. I should probably get a spare pulsar coil for the same reason. Having said all that, check the response from KTMPartshouse regarding updated CDI part number and price: Quote:
While I have the top end exposed I'm going to check valve clearances and adjust as needed. Motion Pro feeler gauges arrived last week. Have two cover gaskets on the way. Next Steps: Plan is to check my current stop/stop switch for resistance and make sure that is working properly. Will pull the generator cover (per post above) and make sure there isn't any damage there. Finally, will go through the existing wiring with a fine tooth comb, organizing and zip-tying/taping where needed.
02-11-2013, 05:33 PM
#90 |
tall drink of water
Oddometer: 344
Trouble with a Molex .093 connector. I removed the male pins out with a .093 extraction tool, but the female pins appear to be the same size as the tool I have.
Anyone know what size tool I need to get the female pins out? EDIT: Called Molex directly, they say that the extraction tool should remove both male and female pins in the connector housings. The tool I bought was a cheapy, they recommended their own tool, which I've since ordered.
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=Vl7XlZs2CRc (May 2013 trail riding) '02 Kawasaki KX250 L4 http://www.youtube.com/watch?v=Sjgw-yZJdfs (Jan 2013 gopro ) Queen of Spades screwed with this post 02-12-2013 at 06:46 AM |
