Old 02-01-2013, 11:15 PM   #16726
tvscum
tvscum's Avatar
Oddometer: 109
Originally Posted by bp_josh View Post
So...I needed to drain my nearly full tank. Asked the wife to pick up a siphon tube while she was in town, and of course the guy at the hardware store just couldn't sell her a siphon tube, he had to sell her some gimmicky thing that you drop into the tank and shake up and down in a slightly sexual manner, which is supposed to build up pressure and start the siphon (it doesn't work).
The tube on it is pretty fat, so as I shook it up and down the best I could, the somewhat sharp underside of the filler hole scraped/shaved a bunch of plastic flakes off the tube and down into the tank. I didn't realize until I pulled the tube out.
Anyways...is there a fuel filter on this bike? Please tell me it's not inside the tank where the fuel pump is. I'd like to make sure I don't have a bunch of plastic flakes floating around my tank before I fire the bike up. Of course there's also a little ledge around the filler hole so I can't just dump some fuel in and then turn the tank upside down, as the ledge would catch any debris.
Not sure if this helps?
http://www.bikebandit.com/2010-trium...8750#sch632218
Or these photos:
http://www.triumphrat.net/twins-tech...s-of-pics.html
Current: 2012 Triumph Scrambler;
'97 Honda XR440 (plated)
Past: '83 Honda XR500; '84 Honda XL600;
'86 Yamaha XT350
tvscum is offline   Reply With Quote
Old 02-02-2013, 07:25 AM   #16727
bp_josh
bp_josh's Avatar
Oddometer: 88
The parts diagram does, yes. Thanks.
Guess I can run the engine a bit and then just check/clean the filter to see if plastic did get in the tank.
XRL rider in east San Diego county
bp_josh is offline   Reply With Quote
Old 02-02-2013, 02:46 PM   #16728
DoubleCafe
DoubleCafe's Avatar
Oddometer: 95
Originally Posted by ZappBranigan View Post
Yes, you could go over to Triumphrat.net.
Or you could go back to page 1104 of this very thread where I posted the exact same thing. http://www.advrider.com/forums/showp...ostcount=16560
Incidentally, since it looks like we're getting good weather this weekend, I'll probably put the side cases on (Duratool cases - basically cheap Pelican copies.) I'll be using the Happy Trail brackets to connect them.
Thank you Zapp & T-Storm!
'06 Triumph Thruxton
'07 Triumph Scrambler
'05 Honda CRF 230
'01 Honda XR 400
'02 BMW R1150 GS
DoubleCafe is offline   Reply With Quote
Old 02-02-2013, 04:07 PM   #16729
Jazbec
Oddometer: 2
Hi guys! i have a request for you triumph owners.
My name is Jan and I am an architecture student from a small European country of Slovenia. I am in love with the scrambler and I'm doing my motorcycle driving license atm.
Because I'm an student, my finances are limited, and I have some saving ahead of me before i purchase the bike.
In the meantime I'm planning all the modifications I will be doing to the bike.
I plan to fabricate quite a few bits, and since I'm an architecture student I'm used to CAD and also other 3d visualisation software and I make my living doing architecture visualisations.
To get to the point, i plan on making a highly detailed 3D model of the original scrambler in 3ds max, that will serve for the basis of my build.
I will make detailed sketch renderings for the final build, and i will be able to design particular elements in detail ( new rear fender, etc...)
Since this is a bit different that my usual work I'm used to, i would need a lot (50 - 100) pictures of the Bike from various angles shot with a DSLR camera(from the pictures, a simple program will build a simple 3d model, that will serve as the blue print for the detailed model that I will model myself).
The pictures would need to be shot 360 degrees around the bike, with the bike being stationary (best shoot with cloudy sky - diffuse lighting)
http://www.youtube.com/watch?v=byqFZD5AILU
So if there is a kind soul with some free time, it would make my day! since triumphs are rare here in Slovenia i cant photo shoot the bike myself
The model once i finish it will be free to share (it will take me some time, with all the collage duties :) )
Jazbec screwed with this post 02-02-2013 at 04:12 PM
Jazbec is offline   Reply With Quote
Old 02-02-2013, 11:03 PM   #16730
tvscum
tvscum's Avatar
Oddometer: 109
It has to be a DSLR?
'86 Yamaha XT350
Old 02-03-2013, 12:01 AM   #16731
Denis_mb
Oddometer: 1
Triumph in Slovenia
Zdravo,
Jan jaz sem lastnik novega Scrembler-ja v Sloveniji, če želiš se lahko oglasiš v moj kraj in si ga sam ogledaš ali slikaš. Zanimiva ideja, tudi sam sem imel v mislih kaj modificirati po svoje. Trenutno sem nabavil Bitubo komplet amortizerje za bolj udobno vožnjo s Scrambler-jem.
Sem v Savinjski dolini, tako da se lahko oglasiš.
Še kakšna fotka.
Ang.
Hi,
Jan I'm the owner of a new Scrembler in Slovenia, if you want to see you can visit me at my place and see for your self and make pictures. This is interesting idea, I too have had in mind to modify my own. I just bought a set of Bitubo shock absorbers for a more comfortable ride with Scrambler.
Here are some pictures.
Denis_mb is offline   Reply With Quote
Old 02-03-2013, 12:59 AM   #16732
SkiFastBadly
A beer? Yes, please
SkiFastBadly's Avatar
Oddometer: 1,371
Have you tried contacting Triumph directly, explaining your situation, and asking for some IGES, STEP, or JT files?
2004 HD Softail Heritage Classic
2008 Buell Ulysses
2008 Triumph Scrambler
Once in awhile you can get shown the light in the strangest of places if you look at it right. ADVrider Relay 2008: UT
SkiFastBadly is offline   Reply With Quote
Old 02-03-2013, 02:38 AM   #16733
Jazbec
Oddometer: 2
Originally Posted by Denis_mb View Post
Zdravo,
Hi,
Well, that solves everything!
I did not expect to run across another Slovenian, especially that fast! thats great
Not really since its just a Hobby project, that Im doing for myself.
This step is not that important, but it gives me a rough 3d model, that helps me where pictures cant and gives me a sense of scale. I could always skip it .
Not realy, the better the pictures, the better the final model.
Thats sorted, i will drop by Dens and do the photos myself !
Jazbec screwed with this post 02-03-2013 at 02:48 AM
Old 02-03-2013, 07:41 AM   #16734
herrstedt
Oddometer: 23
here are some wallpapers. I dont know if the resolution is large enough, but enjoy anyway : http://www.bikewalls.com/motorcycles...Scrambler.html
Herrstedt
herrstedt is offline   Reply With Quote
Old 02-03-2013, 10:29 AM   #16735
henryII
henryII's Avatar
Oddometer: 222
Great country to ride in, here is wife on her way over Vrsic pass on the way to Kranjska Gora
________________________________________
http://www.triumph-hinckley.no/
[/URL]
henryII is offline   Reply With Quote
Old 02-04-2013, 09:49 AM   #16736
mstakern
Oddometer: 2
Arrow Exhaust best prices
I have been doing a lot off looking for the Arrow 2 into 1 exhaust for my Scrambler. I keep coming up with the $1,099.00 price. Does anyone know where I can get one for less? Thanks in advance!
mstakern is offline   Reply With Quote
Old 02-04-2013, 12:18 PM   #16737
henryII
henryII's Avatar
Oddometer: 222
They will terminate the Arrow Product for the classic series due to the New euro rules. No mapping allowed
my Guess is that the price could move the other way
[/URL]
Old 02-04-2013, 01:43 PM   #16738
ZappBranigan
Oddometer: 250
As promised: My side case install (on Metal Mule racks)
Had nice weather and some time this weekend so I installed the side cases. The cases are Duratool cases, basically imitation Pelicans, that I found out about somewhere here on ADVrider.com. Place I got them from is called MCN electronics. They come in multiple sizes, I got the biggest ones I thought would fit and they were $30 each plus about $16 for shipping to Colorado.
First step was to get out the tools so I could remove one of the side racks. I suppose you could put the cases on without drilling but it would be unneccessarily difficult and you might end up with sloppy results.
It literally took me about 5 minutes to remove the left side rack (4 bolts and out.)
Next, I used a strip of duct tape to show where I wanted the bottom of the racks to sit:
Next, per the instructions that came with the Happy Trail pucks, I placed the pucks and drilled. I had to use a small bit (about 3/16") to go through the screw hole on the pucks. Once that hole was drilled I removed the puck and enlarged it to the recommended 5/16" size that is neccessary for the bolts to come through.
Once the 5/16" holes were drilled, I was able to bolt in the pucks:
The bottom two pucks are held on by bolts while the top two have a large plastic knob. You can loosen this knob to allow the pucks to rotate when putting the rack on or taking it off.
Fitted the bag to the remaining (right side) rack just to see if it would fit. On the Metal Mule racks (and I'm guessing on most others) the shape of the rack's "hoop" is the same on both sides so the arrangement of the pucks allows either bag to be fitted to either side.
After that, I put the left side rack back on and was able to bolt on both bags:
Front view. This gives you an idea of width. Safe to say that even if lane splitting was legal in CO, I wouldn't be doing it in this configuration!
Here she is fully "geared up" with all the cases on.
So all's good, right? Well, not quite. No matter how you put those pucks on, they're going to rattle a bit. That bothers me. It also bothers me that the pucks don't "wrap around" the rack in any way. My fear is that if I were to ride over a rough surface or bumpy pavement, the upper pucks (the ones that are designed so that they can turn so you can remove or replace the bags onto the rack) might rotate enough for the bags to fall off in traffic - obviously "not good."
So, I'm going to work on it a bit more and possibly might see if I can either augment or even replace the upper pucks with one or two "J-hooks" that will positively wrap around the upper bar preventing catastrophic loss of the bag. I will also work on waterproofing the bag, probably by putting a rubber patch sealed with silicone sealant around the holes.
And of course, then I have to apply my ADV stickers to make it "official!"
Martin (AKA ZappBranigan)
"Branigan's Law is like Branigan's Love: Hard, and Fast!"
Current Ride: 2008 Triumph Scrambler "Unscrambled" w/ Dunlop D404 street tires, AI removal kit, Bonnie Seat, Handlebar Spacers, Slipstreamer Spitfire shield, Metal Mule rear and side racks and an el-cheapo JC Whitney top box!
ZappBranigan is offline   Reply With Quote
Old 02-06-2013, 10:59 AM   #16739
Cooper-Clubman
Cooper-Clubman's Avatar
Oddometer: 60
Nice Video found
http://vimeo.com/rsutantyo/am41-troupe
Cooper-Clubman is offline   Reply With Quote
Old 02-06-2013, 05:25 PM   #16740
Goat_locker
Oddometer: 53
Pretty cool...
Originally Posted by Cooper-Clubman View Post
Kind of a neat video. Pretty well done too.
Still haven't wheelied mine... where are my keys?
2006 Triumph Scrambler
1971 Triumph T120RV Bonneville
Coming Soon: BMW Adventure Bike
Goat_locker is offline   Reply With Quote
Times are GMT -7.   It's 11:37 PM.
