Old 02-03-2013, 11:37 AM   #46
dpetersak OP
Oddometer: 44
Originally Posted by Ginger Beard View Post
How much did those shocks run you and what is the stroke ?
By the way it looks much better with the fairing!
Ginger, the shocks were a grand. I went with the pricier model because, like the WP forks, I can dial in the suspension I want. The shocks have 60 positions for rebound and 20 for compression. Also I can adjust the length and spring preload. In my neighborhood we have two kinds of roads, great and crap. The idea is, if I'm going to ride hundreds of miles on a crap road like the one pictured below, I can dial in the suspension to handle it and stiffen up the suspension when I'm on a good road. And stroke is 4.5 inches which translates to 5.5 of travel.
dpetersak is offline   Reply With Quote
Old 02-03-2013, 11:52 AM   #47
Ginger Beard
I have no soul
Ginger Beard's Avatar
Oddometer: 5,598
Cool, thanks for the response. Yeah the roads up there aren't great but they sure do have great scenery! My dad lives in Homer and every time I go up there I do my best to get out a ride as much of your beautiful state as possible.
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~
My HD Scram-ster build
Help Save a Pit-Bull
Ginger Beard is online now   Reply With Quote
Old 02-03-2013, 01:41 PM   #48
dpetersak OP
Oddometer: 44
Yep. I've ridden all over the U.S. and my favorite roads are still in my own backyard... the Seward Hwy towards Homer and the Richardson Hwy. out of Valdez. Motorcycle heaven.
Old 02-20-2013, 06:17 PM   #49
WhicheverAnyWayCan
Deaf Biker
Oddometer: 357
Subscribed.
WhicheverAnyWayCan is offline   Reply With Quote
Old 03-08-2013, 07:48 PM   #50
dpetersak OP
Oddometer: 44
tires
My rear wheel is laced and ready to go. For the rear, I went with a 3.5" Excel rim laced to a hub from an 06 Dyna FXD that I picked up on Ebay for $75. Although I had researched the axle sizes for that year, this was a transitional period for Harley as they went briefly from .75" axles to 1" and then to 25mm. The 06 Dyna was supposed to be 1", but of course the hub I bought was .75". It was a nice hub and I couldn't return it, so I took it to the machine shop and had it drilled out. For tires, I decided upon Pirelli AT 90 Scorpions, which fit my intended riding style of 60-70% street and 30-40% trail. The reviews regarding street handling are excellent. Even with my shortened front forks, I still need to get the rear as high as possible to correct the chopper-like geometry of the Sportster, so I went with 18" 140/80. For the front, I kept the stock 21" KTM wheel with a tire size of 90/90.
The both tires went on with no problems.
The front tread of the Pirelli is beefy but still street capable.
dpetersak screwed with this post 03-08-2013 at 07:55 PM
Old 03-08-2013, 07:52 PM   #51
WhicheverAnyWayCan
Deaf Biker
Oddometer: 357
Edit the image links for you..
What brake are you using on front? It looks like harley rotor? And how long is the brake rotor?
Old 03-08-2013, 08:10 PM   #52
dpetersak OP
Oddometer: 44
fender
With the tall suspension, the rear fender didn't look 'right'. There was too much hanging out the back with that huge taillight sticking out even further. I bought a hidden, under-the-fender tail light from Drag Specialties and chopped the fender to match it. It kind of has a dirt track look to it now.
I didn't take a picture of the stock fender with the new shocks, but here it is in the original photo of the bike.
The bobbed fender with the new wheel/ tire.
Old 03-08-2013, 08:15 PM   #53
dpetersak OP
Oddometer: 44
Because I am obsessed with weight, the new rear wheel shaved off another 9 pounds of weight (unsprung) when compared to the stock wheel. The front wheel with the Pirelli tire is 7 pounds lighter.
Old 03-09-2013, 08:30 AM   #54
JimmyTheHog
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 644
Its looking good! It will be interesting to see what the finished weight comes in at. Not sure your doing this, but the Shorai or other L-I batteries can shave up to 10 lbs off. I went with the Shorai and so far, so good.
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog is online now   Reply With Quote
Old 03-09-2013, 01:29 PM   #55
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 927
Definately looking better with the laced wheel and cut fender. Nice stuff.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 03-09-2013, 09:14 PM   #56
dpetersak OP
Oddometer: 44
Everything on the front end is KTM. The front rotor is an oversized supermoto rotor, which comes with an adapter bracket to step the caliper out further. The only thing still Harley is the brake line, and Harley and KTM use different style bolts. I think I can marry the Harley line to the KTM caliper though, and I'll be working on that riddle this week, so more to come soon.
Old 03-11-2013, 02:30 AM   #57
Trane Francks
Trane Francks's Avatar
Oddometer: 179
Subscribing: This is looking really good!
Trane Francks is offline   Reply With Quote
Old 03-11-2013, 11:45 PM   #58
dpetersak OP
Oddometer: 44
A few weeks back I was unable to get rid of the play in the front end, even after cranking down on the top bolt as much as I dared. After looking at it further, it seemed that the bottom seal was hitting the edge of the steering head before the bearing seated in the race. I decided to try a spacer on top of the race. I used the old seal as the spacer by grinding off the lip, honing and beveling the inside, and then filing off the burrs. The race seated nicely in the steering head and the bearing seated in the race with no play. Another problem solved
Photo & Video Sharing by SmugMug
Old 03-11-2013, 11:53 PM   #59
dpetersak OP
Oddometer: 44
I cut-out, bent, and drilled some aluminum plate to create a skid plate.
I also added some mini crash bars. They're off a 79 Yamaha 1100. The bottom is bolted to one of the bolt holes for the forward pegs and for the top I welded a tab to the frame.
Old 03-12-2013, 03:28 AM   #60
WhicheverAnyWayCan
Deaf Biker
Oddometer: 357
Looking good!! Your skid plate is really simple!
I am curious to see what your plan is for the kickstand. I like JimmyTheHog's but I think his might be a bit too tall for mine. Or are you gonna stay with what you have?
Times are GMT -7.   It's 08:12 PM.
