02-02-2013, 12:25 AM
#6856 | |
Oddometer: 52
____________________ 84 Harris Magnum 2 84 XL600R 85 Vespa PK135 |
02-02-2013, 03:51 PM
#6857 | |
Oddometer: 4,790
C-dub...... Powered by CW-Pistons/cams Wizard manufacturing.... |
02-02-2013, 04:44 PM
#6858 |
Oddometer: 11
I recently bought a new chain slider for the swingarm on my 1987 XL600R. When I took the swingarm off I felt reassembly was going to be tough as the swingarm was very hard to get apart from the frame. I cleaning everything and put the new chain guide on and got ready to install the swingarm but I can't get the swingarm to slide into position. Is it easier if I loosen the other engine mount in the rear ? Are there any tricks to make re-installing the swingarm easier ? Thank you.
02-02-2013, 04:50 PM
#6859 | |
Oddometer: 69
I'm reading the all thread and I'm @ page 96...
02-03-2013, 07:21 AM
#6860 | |
Oddometer: 167
There must be something else going on here, the swingarm is not that hard to get back in. I have extra wheels with mounted tires ready for a quick swap and on the rear. I scavenged up enough parts to outfit a spare swingarm I have figuring that would be a faster swap than fiddling with axles and adjusters and stuff. The hardest part for me is holding the end caps in place while sliding the swinagarm into place, and that is really not that hard at all. I would study a parts breakdown online (like Babbits online, or partszilla) and make sure all of the pieces are in their respective places and the dust seals on the ends fit tightly and bottom out on the ends of the arm. Maybe someone folded the seals over in the dust caps and somehow got it forced back together. It would be really hard to bend the frame there making it tighter, and loosening motor mounts wouldn't help anything there either in my opinion, but that is easy enough to try. Swingarms are very much alike between models so even if it were the wrong one it should still fit. i think 500, 600, 650l, even 250 and 350 all interchange easily. I would try to test fit it without the seals on the end first to see what the measurement is between the frame and arm, then go from there. If someone assembled it with pieces missing and pinched it together there, I bet you could jack it back out with a bottle jack or similar device. |
02-03-2013, 01:56 PM
#6861 |
Oddometer: 11
Thank you davek181. I had tried the bottle jack yesterday and again today, even after loosening the other engine mount, but I just couldn't get it to fit. After taking a little break and relaxing I went out and the swingarm went in with a little extra push and jiggling. I went to assemble the pro-link and noticed I had another stripped nut for one of the linkage bolts. The linkage is cleaned, regreased and assemble, just need the last nut to finish. Riding days are with me again !
02-03-2013, 08:34 PM
#6862 | |
Oddometer: 638
02-03-2013, 08:36 PM
#6863 | |
Oddometer: 638
02-03-2013, 09:18 PM
#6864 |
Oddometer: 143
Hid
Anyone put one in? Experience with them, trouble, one to stay away from?
I would am thinking of doing it. Should just need a H4/9003 kit to do it with. Just wondering about any feedback on it. Also I have ask this before, but is there a source for carb bowl orings? Thanks Chris
If you find yourself in a fair fight, '83 XL 600r |
02-04-2013, 08:36 AM
#6865 | |
Oddometer: 48
O-rings
Hope that helps. |
02-04-2013, 10:35 AM
#6866 |
Oddometer: 167
I haven't done the HID conversion but I have pondered it. The advantages of course are the higher light output, but the disadvantages outweigh that in my opinion.
The major disadvantage on an XL is the necessary Dc conversion to the headlight. I have read stories of lights shutting off due to voltage and/or battery reserves being low, and an XL is marginal that way anyhow since the DC circuitry is not utilized or designed very heavy. Bulb expense and vibration resistance fears compound my reluctance. Maybe as an auxiliary light but there I would probably opt for LED driving lights instead keeping in mind current draw limitations. |
02-04-2013, 11:04 AM
#6867 |
SAND EATER!
Oddometer: 480
I broke a zerk off of my linkage..... Now what??
'83 Honda XL600R valve seat ![]() RIDE RED! |
02-04-2013, 11:14 AM
#6868 |
Oddometer: 7,986
Easy out or left hand drill bit.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
02-04-2013, 12:53 PM
#6869 |
Oddometer: 112
replace factory air box
In the process is putting my XL600 back together and want to do something a little different with the air filter. I would like to install dual air filters directly on the carbs and by-pass the factory air box. My factory air box is pretty beat up already and the rubber snorkels makes remove and installing the carbs very difficult.
Has anyone documented their successful factory air box replacement? Have not have not found anything whilst searching. If I removed the air box completely, then where does one mount the battery and related wiring? TIA |
02-04-2013, 01:49 PM
#6870 |
Oddometer: 167
My experience with aftermarket air filters, especially pod filters, especially K&N is that they are slightly better than no filter at all. They will filter out the sticks and rocks, but let damaging dust come right through. If you are running on only pavement and never in the dust, then maybe your rings will last a little longer.
I would hunt eBay for a better air filter box if yours is damaged beyond belief and run either a factory Honda( preferable and still available ) or a twin air filter. |
