02-01-2013, 03:59 PM
#16 |
Vtwin madness
Oddometer: 282
02-01-2013, 05:44 PM
#17 | |
Dans le doute...gaz!
Oddometer: 1,723
I had them on my 990. But they vibrate out as they do not lock in properly. So beware and modify the locking aspect or your whole airbox will be loose......
The race is long and, in the end, it's only with yourself...
02-02-2013, 10:42 AM
#18 |
Oddometer: 277
I thought that too, but was told the fuel injected stacks don't go into the carbed version. I didn't check it for myself, has anyone out there????
02-02-2013, 11:02 AM
#19 | |
Oddometer: 277
02-02-2013, 01:40 PM
#20 |
Gnarly Infantry
Oddometer: 884
By Sakurama´s thread i dare to say that
Longer stacks : More grunt Shorter stacks: More topend
02-02-2013, 05:11 PM
#21 |
No neck tie, Ti neck
Oddometer: 572
02-02-2013, 05:24 PM
#22 |
Oddometer: 277
02-02-2013, 10:18 PM
#23 |
Oddometer: 267
Based on my working on sprints and midgets, the key thing is the stacks move the power band, long stacks make the power peak at lower RPM shorter ones at higher RPM.. Smaller diameter stacks raise torque, larger diameter stacks increase horse power at higher pm (To a point its not magic...) You have to balance runner length against diameter.
Typically you put the engine on the dyno and test say 4 sets of stacks ,, Map their performance, then you use the set that keep the motor on the power band at the RPM's the track demands of the car to keep it at speed. Dave |
02-02-2013, 11:55 PM
#24 |
Oddometer: 267
Here is something that's close to the same idea..
this is a standard 32/36 Webber on a Nissan 1600. http://www.flickr.com/photos/3362913...in/photostream http://www.flickr.com/photos/3362913...in/photostream http://www.flickr.com/photos/3362913...in/photostream Fairly stock motor with headers, NISMO camshaft. The engine was only making consistent power between 4000 and 5000 with the webber alone. The velocity stacks lifted the whole power band and pumped the engine up nicely from 2500 to 4000, netting a really race-able power band from about 3000 to 5500 rpm. I included the filter pics for reference since its similar to the rottweiler. Cheers. Dave |
02-04-2013, 02:17 AM
#25 | |
Alive
Oddometer: 133
Long answer: Below a movie about my SE through the woods after heavy rain. My SE has the MotoHooligan airbox (and a very old and weak battery.) At 6:14 minutes the puddle is too deep and it killed the engine. https://www.youtube.com/watch?v=goJWXDOtRQc
< KTM 950 Super Enduro| Husaberg FE570 | Honda CBX 1000 Z > |
02-04-2013, 06:39 AM
#26 |
Iron Man
Oddometer: 2,002
that frame looks too clean
seems never suffered too much mud , or you are just the number one cleaning itgood work anyway and agree about the amazing performance without air box, looks like the bike´s in a hurry all the time, but here where I ride, ain´t an option ata screwed with this post 02-04-2013 at 10:33 AM |
