Old 02-05-2013, 11:08 AM   #1
Ben99r1 OP
Ben99r1's Avatar
Oddometer: 2,800
Plumbing advice.
I need some plumbing advice. I have a problem that I am trying to figure out. I have a gas water heater that's never been drained or service in the 11 years that I have owned it. Last month I tried to drain it but it was clogged with what I think is hard water and sediment. I also have galvanized pipes that were installed in 1964. This my problem I am starting to hear a bellowing noise from either the pipes or the water heater. I am not sure from where of the two its coming from/ Would the water heater cause that noise or could that be from the pipes being old? I seen inside some pipes and they also have sediment in them too.
Ben99r1 is offline   Reply With Quote
Old 02-05-2013, 11:16 AM   #2
groop
So much to ponder
groop's Avatar
Oddometer: 2,551
Ben
I live down the 57 freeway from you and have the same crappy water you do. 11 years for a water heater is remarkable in SoCal. I've replaced two in my house in the past 15 years. No matter how bad your pipes are, I'm sure the water heater is toast either way. The noise is likely from your water heaters- at least is was for mine.
The good news is that new water heaters are far more energy efficient than the old ones and I saw a drastic decrease in my gas bill. It also heats the water up a lot faster too.
Originally Posted by DR. Rock
once you leave the pavement, it's like entering a parallel universe... a wormhole in both space and time... sometimes you won't believe you're still in the United States, or in this century.
groop is offline   Reply With Quote
Old 02-05-2013, 12:12 PM   #3
troidus
Oddometer: 6,916
I'm surprised you have any original galvanized still in service. I figured it would have rusted away by now.
troidus is offline   Reply With Quote
Old 02-05-2013, 12:19 PM   #4
groundrules
groundrules's Avatar
Oddometer: 874
totally not surprising that the drain valve filled with sediment before you could drain it entirely. It's not uncommon to have to remove the whole valve assembly, and even then you might have to jab screw driver in there periodically while draining to loosen up accumulated sediment.
groundrules is offline   Reply With Quote
Old 02-05-2013, 12:26 PM   #5
Wlfman
Wlfman's Avatar
Oddometer: 869
Never ceases to amaze me. People will religiously maintain their vehicles but do not perform regular maintenance on their house. Water heaters should be drained and flushed at least once a year and more often if you have hard water or lots of sediment in your water.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Old 02-05-2013, 12:58 PM   #6
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 286
That is true. However, if done improperly the water heater will be damaged. Much like furnace maintenance, not everyone should do this.
The primary problem is not shutting off the heat to the water heater when draining. If the gas or electricity is disconnected, the water heater will not be damaged when drained. Although, there is no guarantee the drain valve will not start leaking.
Stan_R80/7 is offline   Reply With Quote
Old 02-05-2013, 02:07 PM   #7
Benesesso
Benesesso's Avatar
Oddometer: 8,501
What You SHOULD Do!
Repost from 2009.
For those who haven't installed their just-bought new gas or electric tank-type heater yet, first thing to do is find and unscrew the corrosion-protecting anode from the top--before the pipe threads corrode and lock up tight.
Then wrap no more than 2 turns of teflon pipe thread tape around the male thread and screw it back in. Use an ohmmeter to make sure you still have some metal-to-metal contact between the anode and the tank. If not, screw it in a little more. After ~2 years unscrew the anode, which you should be able to do thanks to the Teflon tape, and see how much is left.
If you don't have enough space above the installed tank to lift the whole anode out, cut it in half, thirds or whatever so you can easily get it back out. Just connect the cut pieces with a short piece of wire and sheet metal screws--the anodes are soft alum. or zinc.
The anode dissolves slowly in order to protect the inside surface of the tank. Good hardware stores sell them for ~$20 or so. Much easier and cheaper to replace than the whole tank, especially if you treat the pipe threads when new. These anodes are available in chain form, although not easy to find.
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 02-05-2013, 03:27 PM   #8
Ben99r1 OP
Ben99r1's Avatar
Oddometer: 2,800
I didn't know that it had to be done. Ill do it every 6 months from now on. Trust me I am a maintenance whore. 200,000 miles on my truck. 42,000 miles on my Xr650L. I know how to take care of my stuff. I am going to try to flush the water heater using a method a friend gave me. If that does not work Ill get a new water heater on Thursday. thank for the input and advice guys.
Old 02-05-2013, 04:17 PM   #9
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 9,522
My gas water heater is on borrowed time. Banging noises every night and the thing is 17 years old. Gonna replace it pretty soon! In my experience though, you can have one make the banging/rumbling noise for YEARS before they give out. This one's only been makin' noise for a year now.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Cobbie Award Winner
LuciferMutt is offline   Reply With Quote
Old 02-05-2013, 04:23 PM   #10
D.T.
One wheel wonder...
D.T.'s Avatar
Oddometer: 6,302
I havta flush mine here too.
Damn, too much shit to take care of! This DIY shit is hard!
"Tough times don't last, but tough people do." Robert A. Schuler
D.T. is offline   Reply With Quote
Old 02-05-2013, 04:26 PM   #11
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
If the drain valve is plugged, I use a piece of 1/2" copper with a hose fitting soldered to one end and suck the water out through the hot side pipe fitting.
You need to cut the pipes off of course but you'll need to do that anyway if you're replacing it. Don't use the cold side, the dip tube won't let you shove the pipe into the tank You could siphon or use a little water bed pump.
Just say'IN
crankshaft is offline   Reply With Quote
Old 02-07-2013, 07:16 AM   #12
1911fan
Master of the Obvious
1911fan's Avatar
Oddometer: 1,649
1) get a new water heater.
2) install a sediment filter in your water inlet to the house.
3) install a water softener too.
1911fan
Read The Patriot Post -- It's Right. It's Free.
http://patriotpost.us/subscribe/
Sometimes the light to see your way forward is provided by the bridge burning behind you.
1911fan is offline   Reply With Quote
Old 02-08-2013, 07:20 PM   #13
mcstark
Oilhead convert
mcstark's Avatar
Oddometer: 930
The banging noise is the water in the bottom of the heater boiling due to the sediment floating around. It's your tank telling you it needs a flush.
Another tip is to remove the plastic drain valve and install a metal one before installing the new tank. It makes draining it much easier. The plastic ones fail and leak quite often.
Regards,
Mark
2003 BMW R1150GS
mcstark is offline   Reply With Quote
Old 02-08-2013, 11:10 PM   #14
PoundSand
PoundSand's Avatar
Oddometer: 4,271
So not amazing. An average car costs close to $30k these days. A water heater that costs $500 can last 10 - 20 years with no maintenance, and is relatively easy to replace.
PoundSand is offline   Reply With Quote
Times are GMT -7.   It's 03:24 AM.
