Old 02-01-2013, 01:55 PM   #271
xaman
Oddometer: 243
I recently bought a Xmoto with a Staintune exhaust, which is annoyingly loud. But I also got the stock exhaust, and have been thinking about reinstalling it. The last few posts would quickly convince me, except that I don't know what I'm doing...
Forgive my total ignorance, but is this a simple bolt on procedure? Is there any remapping necessary, etc?
xaman is offline   Reply With Quote
Old 02-01-2013, 01:56 PM   #272
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 4,568
Just a simple bolt on only.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
Cruz is offline   Reply With Quote
Old 02-01-2013, 02:39 PM   #273
Johnnyboxer
Oddometer: 857
Less than 5 mins, no remap necessary
So many roads...........So little time..!!!
2005 BMW R1150GS Adv - Black
2005 BMW R1150GS Adv - Silver
1998 Honda XR250R
Johnnyboxer is offline   Reply With Quote
Old 02-01-2013, 03:53 PM   #274
xaman
Oddometer: 243
Thanks guys, think ill give it a try
Old 02-03-2013, 02:40 AM   #275
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,795
Originally Posted by Johnnyboxer View Post
How much are the SR ones?
Email Stephan for the current prices mate
Sibirsky Extreme 2009 BOOK and DVD available HERE
Moroccan Extreme 2011 DVD available HERE
www.sibirskyextreme.com
Colebatch is offline   Reply With Quote
Old 02-04-2013, 09:15 AM   #276
aprilian
Can I change this?
aprilian's Avatar
Oddometer: 263
To replace the stock exhaust to the stock header, you will need an exhaust gasket. All else is simple, although you need to remove the Remus bracket to get the stock bolt back in (at least I did).
I put 2 db reducers in the Remus and still prefer the sound of the stock, but this time I reinstalled the stock can and left the Remus header. Header is slightly shorter and doesn't fit fully into cut outs in stock muffler. I have used a shorten exhaust gasket, clamped and sealed the potential leak points, but will probably need a better solution this summer. To tell which header you have, the stock header shrinks in size from block to muffler inlet and the Remus grows in size.
My current record is 112 MPH on dash which is about 105 true (stock muffler and stock header). In addition to the better designed Remus header, I am doing a PC V, so I may be able to eek out an additional 1 MPH Going up on the front 1t helped me not hit rev limiter in 6th.
There is no such thing as bad weather, only inadequate clothing.
aprilian is offline   Reply With Quote
Old 02-04-2013, 09:18 AM   #277
aprilian
Can I change this?
aprilian's Avatar
Oddometer: 263
Also, most Staintunes have DB reducers - if yours is missing. My dyno tune on a Staintune on an SV650 showed better power with the insert installed.
Old 02-05-2013, 05:29 PM   #278
xaman
Oddometer: 243
Thanks for this info. But I'm a dummy, assumed the "S" was Staintune but its definitely Scorpion.
So, if I have the stock header, which I assume mine is cause it says BMW on it, I don't need a gasket, just bolt the old muffler (pipe) on?
Thanks for your patience :)
Old 02-05-2013, 05:55 PM   #279
aprilian
Can I change this?
aprilian's Avatar
Oddometer: 263
stock header to stock exhaust pipe DOES take a gasket between the two.
Old 02-05-2013, 06:43 PM   #280
xaman
Oddometer: 243
Awesome, thanks again. Off to the parts shop...
Old 02-14-2013, 05:52 PM   #281
xaman
Oddometer: 243
Got this gasket in today, intending to reinstall the factory exhaust system. It's bent and looks beat up.
I hate to send it back and wait 2 more weeks. Do you think it's usable or not?
Old 02-14-2013, 07:10 PM   #282
jonnyc21
n00b sums it up.
jonnyc21's Avatar
Oddometer: 225
That looks like the one from the tail end of the header to the silencer, not as critical as the one on the cylinder. Maybe not the best but I think I would use it. (Disclaimer: This is only what I would do and is not a recommendation or advice, its only my point of view)
(if it's not the one for the end of the can to the header pipe then disregard my comment...)
jonnyc21 is offline   Reply With Quote
Old 02-14-2013, 07:35 PM   #283
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,302
yep, that is the gasket that goes between the head pipe and the silencer, I would use it.
Rob Swartzwelder, Southern AZ
I'm not real fast, but I do have a dog named Dakar!
97 M900, 07 G650 XChallenge,11 KTM 990 ADV R
2011 North up the CDR
Sierra Vista AZ to Paonia CO and Back through Moab UT
AZ-Twin is offline   Reply With Quote
Old 02-15-2013, 12:40 AM   #284
Johnnyboxer
Oddometer: 857
I'd send it back, it's farked
1998 Honda XR250R
Old 02-24-2013, 11:31 AM   #285
Inniswhe
Oddometer: 142
SR-Racing Exhaust
Does anyone know if there is a SR-Racing dealer in North America. I just bought a X-challenge that came equipped with the Remus pipe that I find too loud and am looking for a quiter solution, I am in Canada.
Inniswhe is offline   Reply With Quote
Times are GMT -7.   It's 01:56 PM.
