02-06-2013, 03:31 AM
#6916 |
Oddometer: 21
Thanks for that bighopper, I shall check that out.
02-06-2013, 06:11 AM
#6917 | |
Kool Aid poisoner
Oddometer: 4,827
What really sucks is I'm lazy and I usually just use the routes that my buddies create. Of course they have 276's which don't have the ridiculous 50 point max so their routes usually contain more. As for displaying both route and track, it doesn't matter if you can't see the track under the route. When you do see the track then you know somethings up since the route and track are no longer following the same line.
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
02-06-2013, 06:16 AM
#6918 |
Web Adventurer
Oddometer: 555
As posted a few pages back before this latest rat hole, the below pic clearly shows the track is quite visible on the route. On the right you can see where the route deviates from the track.
I think all these issues have been answered time and time again in this thread. ![]()
IBA #33260 |
02-06-2013, 06:54 AM
#6919 |
Oddometer: 198
I agree!!!!
![]() However, I learned early on not to use much of anything besides the zoom buttons when going over 5 mph, and to place either a thumb or the heel of the hand on the bars or the side of the unit to help the index finger's accuracy. I haven't had a reset happen since. The other REALLY dangerous Reset button is in the trip computer menu, last item....this will reset EVERYTHING, including all profiles. I NEVER use the trip computer menu unless stationary and also made a shortcut that uses the first menu option, reset trip timers, averages, etc. Much safer.
02-06-2013, 12:29 PM
#6920 | |
Sure, why not?
Oddometer: 16,136
UPDATE: I pulled a 911 point route into a Zumo 350 and posted results in the 350 discussion thread here: http://www.advrider.com/forums/showt...9#post20668779
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA Proud walking jingle in the midnight sun. Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/ Emoto screwed with this post 02-07-2013 at 05:16 AM |
02-06-2013, 02:24 PM
#6921 | |
Kool Aid poisoner
Oddometer: 4,827
02-07-2013, 05:18 PM
#6922 | ||
AttitudeIsEverything
Oddometer: 1,255
Thanks Cable and Albie... I see your example is Black for tracks and I guess the route is always PINK, so the skinny black line on the PINK shows up pretty well. I'll try that out, I was using Yellow or Green for tracks and it is not easy to see the track stacked up on top of PINK. Can you change the Route color?
I came from using only Tracks on my 60Csx and after this entire discussion I think for most of my offroad trips I will end up just using Tracks if I have them or else create my own Routes if I don't and then create tracks from them but may not use the routes much. For a quick "city" trip I may use Routes more. I'm not a long distance tourer type. But I'll keep experimenting. So... all in all sortof anti-climactic, thinking how cool it will be to do Routes on this fabulous new toy. It is but I guess you just have to learn the beast and its limitations. The clincher for me was yesterday when I ran across this admission by DRTBYK: Quote:
Long live Tracks! ![]()
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400 ~~~ Kids: OSET electric | Honda CRF50FindMeSpot ~~~ Spotwalla Baja Trip ~~~ Neduro Did Dakar! |
02-07-2013, 05:22 PM
#6923 |
Oddometer: 1,255
Popped my cherry in another way today. First day with the Montana on my bike (been in a cage before today, experimenting without crashing)...
I have the Rugged Mount with the Montana in portrait mode fairly steep angle (vertical-ish like 60 degrees up from flat). It was often rotating either left or right into landscape mode. I fixed it by locking the display in Portrait, but is this a common "problem"? What seems to cause it, just vibration or ?
02-07-2013, 07:14 PM
#6924 |
Procrastinators
Oddometer: 5,791
Very common; even if using the Montana handheld, you're likely to want to lock the orientation. Inertia can cause the problem; acceleration, braking, leaning. You name it.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
02-08-2013, 05:54 AM
#6925 | |
Deputy Cultural Attaché
Successfully surviving motorcycling since 1976. |
02-08-2013, 06:23 AM
#6926 |
Oddometer: 388
That is a misleading term as fused means in electronics to have become hot and melted toegther.
In this instance I am sure you meant "confused" which would make sense It is not a fault with the unit
www.travellingstrom.com |
02-08-2013, 05:30 PM
#6927 |
Oddometer: 2,203
yes that why he put ' before the fused
aka BMWST?
02-09-2013, 08:46 AM
#6928 |
Oddometer: 808
This thread is so massive, it is impossible to read. I just bought a Montana 600 yesterday. It seems like a great unit.
I found it only supports somwhere around 200 via points in direct routes. I cannot figure out the exact number as when I look at the routes from the unit in Basecamp, it shows the whole thing but when I look at it on the Montana (not hooked up to computer) the route is truncated. I would like to see more. How do I give this input to Garmin? Perhaps someone else already ran into this limitation??
MasterMarine 2013 KTM 500 EXC Exploring Amazing Northern Nevada and SE Oregon 2011 Returning to the desert – Nevada and Oregon 2012 |
02-09-2013, 09:50 AM
#6929 | |
Oddometer: 198
I checked it in mine, but I can't actually try navigating, since it's in Colorado and I'm in Idaho. All 249 points showed up in the edit page. Hint: the last point is called 2 ELHillElkMtnRd 537 (Requires a LOT of page downs to see.... Might be easier to show on map and zoom to last point in the SW corner.) If it's there, the route has not been truncated. If you need more than that you're only choice is to make it a track, which has a 10,000 point limit. |
02-09-2013, 11:07 AM
#6930 |
Oddometer: 808
I was guessing on the number of via points before it truncated in direct mode. I tried to find specs but of course I could not. It could be closer to 250. Still it is not enough. I do not understand why they do not up the limits considerably. My old Lowrance iFinder allowed 9999 point tracks and I bought that way back in 2000. The Garmins with their 500 point max for tracks mystified me when I ran into the issue with my Garmin eTrex and 60csx. And now my new $500 Montana can do a 10000 point track...
Finally caught up to the 13 year old Lowrance. Of course the screen on the Montana is worlds better than the Lowrance. Kind of like comparing Pong to Playstation3 or XBox.Anyway, it seems strange that the thing is limited to such small numbers. In these days of 32 gigabyte micro-SD cards, it seems like we should be able to have tracks that are millions of points. We should not be running into any limitations like these. Is there some Montana forum somewhere on the net? I found Garmin's forum but they only have sub forums for running and swimming GPS units.
