Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 02-06-2013, 01:46 PM   #15661
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,678
Originally Posted by dljocky View Post
Good day all,
Is there a thread/link that s specific to mpg? I,m wondering how many fols are getting 240-250 miles per tank and how often?
I get 220 pretty regularly. Stock exhaust, and I keep current on available ECU maps.
Old 02-06-2013, 01:59 PM   #15662
dljocky
Oddometer: 863
Thanks! I'm really interested in either the 800XC or the Roadie, but wanted to get a good feel for the mpg.
dljocky is offline   Reply With Quote
Old 02-06-2013, 02:04 PM   #15663
cug
Oddometer: 4,923
48.3mpg over the ~4500 miles I have the Tiger 800 Roadie.
Note: I do a lot of weekend touring with my wife. She's on her own bike and we go at a very unhurried pace.
cug is offline   Reply With Quote
Old 02-06-2013, 02:13 PM   #15664
abruzzi
abruzzi's Avatar
Oddometer: 990
Good day all,
This might help:
http://www.fuelly.com/motorcycle/triumph/tiger%20t800xc
Geof
http://tigertriple.com/
abruzzi is offline   Reply With Quote
Old 02-06-2013, 02:16 PM   #15665
andoulli
CAJUN
andoulli's Avatar
Oddometer: 2,114
Good day all,
I'm getting 43 to 45.
andoulli is offline   Reply With Quote
Old 02-06-2013, 02:49 PM   #15666
marloweluke
The Flying Dutchman
marloweluke's Avatar
Oddometer: 149
Originally Posted by HelmetHead Cycle View Post
OK, I need some help deciding. I have ridden the Roadie, but not the XC. I do know the Roadie is lower and scrubs in curves. Is this an issue with the XC?
I have my Roadie all set up for sport touring. It has a Penske rear shock where I have raised the ride height by about 15mm. I have moved the sidestand inside the frame with some 9mm spacers and dropped the Traxxion Dynamics forks with the AK-20 kit about 4 mm in the triple clamps to raise the front as much as possible. Set up like this you won't hit the sidestand cut-out plunger any more. I ride quite aggressively on the road and I can still scrape the pegs, but by that time you're moving along pretty good. The bike is really awesome for this on the road. I have a dedicated track day bike so I find the Tiger keeps the speeds sane. I would be going way too fast if I was on a sportbike. Like Browneye said, it is not a sportbike. I think if you are an aggressive road rider you will prefer the Roadie. I still take mine off-road but probably 5% or less. If you want to take yours off-road quite a bit get the XC. For how I use the bike the Roadie suits me best.
WITHOUT RISK........THERE IS NO ADVENTURE
marloweluke is offline   Reply With Quote
Old 02-06-2013, 04:00 PM   #15667
DropinParts
Ducatista
DropinParts's Avatar
Oddometer: 96
Originally Posted by some call me...tim View Post
Just another option for those of us interested in aftermarket seats, I happened to stumble on this one: http://www.revzilla.com/motorcycle/m...adventure-seat I haven't heard this mentioned before, nor do I know anything about the quality. I posted up a thread in the general equipment section to see if anyone else has any experience with them. I like the look of it at least.
Hey Tim,
I just ordered the Saddlemen seat from Revzilla. Should receive it in a few days.
FYI... I did talk to a salesperson at Revzilla about both the Saddlemen and the Moose Racing seats. I wanted more room in the riders portion. He called both manufacturers and informed me the Saddlemen would be a better choice.
I will post my opinion of the seat after putting a few miles on it.
There are two roads in life, the twisty one is vastly more fun.
DropinParts is offline   Reply With Quote
Old 02-06-2013, 04:21 PM   #15668
cug
Oddometer: 4,923
Do you adjust preload from time to time for varying loads? If yes, how much pain is that?
Old 02-06-2013, 04:42 PM   #15669
ducnut
Oddometer: 3,320
I've got one, on my 1050, and have never touched the preload. Even two-up, tank bag, and full panniers, I didn't touch anything. If you're clear about your intentions with the bike, the shop should be able to set it up accordingly. Traxxion setup mine with a passenger and full luggage and track day possibilities in mind. I've, actually, reduced preload from where they had set it. Yeah, two-up, it will run wide. But, at that pace, I should be by myself and at the track. Otherwise, it's plush and controlled. She has made numerous remarks about how nice my bike rides. I agree.
As a side note, I setup my Daytona the same way "marloweluke" setup his. I slid down the forks in the clamps and jacked up the rear to where it was on the verge of unstable, hard on the brakes. The bike would turn on a dime. I'd setup my 1050 the same way, but, it's already taller than I'd like.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 02-06-2013, 04:45 PM   #15670
dljocky
Oddometer: 863
Mpg?
Thanks for the input everyone.
Old 02-06-2013, 04:59 PM   #15671
marloweluke
The Flying Dutchman
Oddometer: 149
I don't really need to fool around with the preload although when I have to it certainly is not as convenient as the hydraulic preload adjuster. I do have a Torrington bearing kit between the collar and the spring which makes it a little easier to change preload. For two up touring I was considering getting a second heavier spring as it is quite easy to undo the bottom linkage, take off all the preload and replace the spring with a heavier one. Would be worthwhile doing for a longer trip. An extra spring is about $100.
Old 02-06-2013, 06:35 PM   #15672
doxbike
Oddometer: 278
FWIW-Gift card
Dealers are offering $1750 gift card on the XC; $1500 on the Roadie right now
doxbike is offline   Reply With Quote
Old 02-06-2013, 07:23 PM   #15673
lmychajluk
Oddometer: 2,085
Is that for accessories, or can it be applied to the price of the bike?
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is offline   Reply With Quote
Old 02-06-2013, 07:28 PM   #15674
doxbike
Oddometer: 278
I'm sure it's for accessories, altho I noticed on the board that they had a Tiger at a discounted price of @$2000 off OTD price-sorry I don't remember whether a Roadie or XC, but??????
doxbike screwed with this post 02-07-2013 at 06:25 AM
Old 02-06-2013, 07:31 PM   #15675
DennyMyBoy
Hoping for a Tiger
Oddometer: 34
Tiger 800XC vs. Trophy SE
All is well with the world!
I'm the guy who made a commitment to purchase the 800XC, and a few days later, upon viewing the Trophy, had big time 2nd thoughts. Finally had a chance to demo the Trophy today. It's a great bike, I'm sure they'll sell tons of them, but for me and my needs and where I am in my life the Tiger 800 XC is head and shoulders above it as a far better choice!
Was beautiful, smooth, and very powerful.
But for this rider here are the negatives:
Legs were too cramped even with stock seat in the highest position
Bike felt heavy and cumbersome during slow speed handling. Within the first one minute of the ride that was the deal breaker for me
Compared to the light weight and plush suspension of the 800 XC, the suspension felt a little jarring on beat up pot hole filled suburban roads
Compared to the 800, I felt too isolated from the ride experience by the size of the fairing and the multitude of the electronic gadgets
Grateful that I feel clarity and a sense of peace about which motorcycle to purchase!
Thank you all for your help!!
DennyMyBoy is offline   Reply With Quote
Times are GMT -7.   It's 06:42 AM.
