Old 02-04-2013, 10:01 PM   #316
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,184
Originally Posted by drc42 View Post
I want to see you make another attempt with the SC500!!!
Sadist.
All I want is to hear the story of how he made it back to Mexicali.
Luke is offline   Reply With Quote
Old 02-04-2013, 10:17 PM   #317
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,184
I worked on the battery box today, got the body done, it still needs a lid and mounting tabs.
I made it out of 16ga steel. Instead of trying to use the bender, I scored it with the cutoff wheel then bent it at the scores by hand. Much better results. The bent corners do need to be welded to get their strength back but it's a really easy weld to make.
I was able to weld the edges up really quickly which got the torch pretty warm, so I stripped it to see what was getting hot. Nothing seemed to be overheating, just a healthy hot.
The box goes above the swingarm, under the air filter. It's a tight fit, but should work. The picture is with the swingarm at the top of its travel. There's a little piece of wood taped on the bottom which will allow the ignition module to fit.
Here's the box with its contents. Battery, starter relay, ignition.
The voltage regulator mounts on the bottom so it can cool.
Old 02-05-2013, 01:38 PM   #318
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,340
Nice tip. I don't have a brake, and occasionaly need to bend metal like that. I'll have to remember that one. How big is your tig welder. Mines got a pretty low duty cycle and warms up a bit when continual welding. I just let it sit for a minute now and then. Guess that's why fab shops step up to water cooled torches.
Keep up the good work and sharing your progress.
-= Scott
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 02-05-2013, 09:20 PM   #319
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 739
PPD Maintenance
With all the projects being worked on, some of the shop tools are showing the strain. One of the key assets in the LC Garage is our PPD or "Precision Polishing Device". This unit has taken a beating over the years and in the last few days has started to come apart at the seams. The fancy label says "sometimes bearing needs lube" ;
Picked up a new polishing wheel today at Lucilles (small tool store near where I work);
Ready for another year of precision polishing!
"Nothing can stop us but fear and common sense”
LC Garage is offline   Reply With Quote
Old 02-05-2013, 10:06 PM   #320
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,154
Awesome! I just put a polishing wheel, new cable, toggle switch and rubber feet on mine! Altho, I need a new stone, wire and maybe a couple more polishing wheels!
Low594 is offline   Reply With Quote
Old 02-06-2013, 08:49 PM   #321
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,184
-= Scott
The welder's a 130A stick inverter. For TIG I'm usually running the current between 50 and 70A, so that part runs cool.
This is the first time I've warmed up the torch anyway. Usually I'm fussing around for 15 minutes for each 30 seconds of welding.
Old 02-06-2013, 08:53 PM   #322
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,184
Why do I feel a sudden urge to install security screws on the float bowls?
Old 02-06-2013, 09:32 PM   #323
oregoncoast
Racing Like a Noob
oregoncoast's Avatar
Oddometer: 4,507
This would be a very wise move, since Rick has unfettered access to his own shop.....DAMHIK
Old 02-07-2013, 07:09 AM   #324
Loud Al
Loud Al's Avatar
Oddometer: 3,912
A Quick Trip to Big Sur
Allan
Loud Al is offline   Reply With Quote
Old 02-07-2013, 08:00 AM   #325
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,311
Originally Posted by Loud Al View Post
Story? or mystery?
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 02-07-2013, 08:32 AM   #326
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 739
Originally Posted by MortimerSickle View Post
Story? or mystery?
They are just busting my chops for "polishing" the floats on Paul's SL350 (last winter), and this one got caught in the wheel, flew across the room and was ruined. A vigorous discussion then ensued on the proper use of the bench grinder or "precision polishing device".
Old 02-07-2013, 08:44 AM   #327
MortimerSickle
Semi-Adventurer
Oddometer: 12,311
Oh, sorry about that.
G.H.W.S. 1878-1962
Old 02-07-2013, 12:19 PM   #328
Kootenai Rider
Displaced Adventurer
Kootenai Rider's Avatar
Oddometer: 2,270
Good to hear you're supporting the local shop. It was pretty quiet when I was there last now that Harbor Frieght opened down the street.
Like most great inventions, it is fantastic when used for its intended purpose, but in the hands of a villain, or worse, an idiot, it wreaks havoc.... - A-bone
2012 KTM 250XC-W "Ginger"
Kootenai Rider is offline   Reply With Quote
Old 02-07-2013, 01:04 PM   #329
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 739
Thanks, I almost forgot and went to the box store, but then remembered our friends in the local small shop. Got to do our best to keep the mom and pop stores going!
Old 02-07-2013, 11:46 PM   #330
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,184
The battery box is mostly installed, but turned out a bit crooked. It was a pretty frustrating day and I just wanted to get it mounted. The welding mask started flaking out, which made the welding pretty hard- it'd cut out randomly while welding. Now that the box is mounted it should be pretty easy to straighten it out, though.
It's a tight fit with the swingarm.
I mounted the seat pan. It's got a hook in the front and a tang in the back that is pinned in a clevis. I missed some pictures, so will get them later.
Here's the rear mount seen from the underside.
The battery box isn't the only crooked part. The swingarm turned out to be too far off to work, so it's getting modified again. The lesson here is that the order of the welds is critical. Instead of welding in all the reference parts (the axle mounts and pivot tube) and then the reinforcement crossbar, I should have started at the axle and worked forward, welding in the crossbar next and the pivot tube last.
Well, here goes, again. The brake side of the swingarm needs to move out about 3/4 inch.
Most of the crossbar has to come out, as it would be really doglegged otherwise.
Results. Yes the wheel is off, but it's off by just the right amount. There's one more thing on the swingarm to fix, but that's a different operation.
And finally a gratuitous selfs portrait.
Times are GMT -7.   It's 10:34 PM.
