Old 02-06-2013, 12:02 PM   #31
burmbuster OP
burmbuster's Avatar
Oddometer: 1,429
Originally Posted by sierraoffroad View Post
is the bra in the background on the left an emergency strap for spherical shaped objects on the bike?? what size is it?
Or maybe its one of these?
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Old 02-06-2013, 01:36 PM   #32
Kinsman
Ribs....for her pleasure
Kinsman's Avatar
Oddometer: 3,987
I make my own with 1" webbing. They are a lot like the Helen2Wheels stuff.
Cheap, simple, strong.
Chris R
Schreckendgust Field, Montana
Kinsman is offline   Reply With Quote
Old 02-06-2013, 03:39 PM   #33
StuartV
Motorcyclist
StuartV's Avatar
Oddometer: 1,396
Originally Posted by NJ Moto View Post
Those are only slightly less expensive than Rok straps and the design of the Rok straps is superior. The built in elastic in the Rok straps means they maintain tension on your gear at all times.
- Stu
'09 R12GS, '05 GSX-R1000
Iron Butt # 4999, WERA/CCS EX # 666 (currently, expired), AMA Life Member
Racer, Drummer, Bassist, Software Engineer
StuartV is offline   Reply With Quote
Old 02-06-2013, 05:20 PM   #34
NCK
NCK's Avatar
Oddometer: 480
exactly. worth every single penny. rok has the dominant design.
NCK is offline   Reply With Quote
Old 02-06-2013, 05:42 PM   #35
Maggot12
U'mmmm yeaah!!
Maggot12's Avatar
Oddometer: 4,296
Rokcraps don't have near the ability or versatility of the 1" ratchets straps. I have a dozen in the garage with 600, 1000, and 1200 lb strength. I usually take 4 with me for anything overnight or longer. I typically carry 2x 15ft long and 2x10ft long. They can be used to tow or lift a bike from a ditch, strap down a bike in a truck bed or trailer. Endless possibilities while camping such as holding up a tarp, hammock, clothsline, a winch while in bear country, etc, etc.
And of course strapping down your favorite gear to your luggage.
Maggot
Don't sweat the petty things; Pet the sweaty things !!!
Maggot12 is offline   Reply With Quote
Old 02-06-2013, 07:03 PM   #36
NCK
NCK's Avatar
Oddometer: 480
Originally Posted by Maggot12 View Post
Rokcraps
Old 02-07-2013, 12:16 AM   #37
vwboomer
Buffoon
vwboomer's Avatar
Oddometer: 9,965
I have rokstraps.
But when looking for more at Cabelas (they dont have em) I came across an adjustable length bungee that wraps itself around a plastic clip to hold it in place. Cant link it right now, but it is pretty handy. I carry those and rokstraps now.
vwboomer is online now   Reply With Quote
Old 02-07-2013, 05:35 AM   #38
kitesurfer
kitesurfer's Avatar
Oddometer: 1,614
it's one of the smaller sizes...almost as small as the thong hanging up that you missed
2012 VSTROM ADV 650
US NAVY RETIRED
kitesurfer screwed with this post 02-07-2013 at 05:35 AM Reason: ,
kitesurfer is offline   Reply With Quote
Old 02-07-2013, 06:14 AM   #39
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,768
Originally Posted by beechhunter View Post
Rok straps
Jim
Old 02-07-2013, 06:24 AM   #40
JimVonBaden
"Cool" Aid!
Oddometer: 51,768
Just be careful with ratchet straps on a bike. You can pull hard enough to start bending and breaking things.
The problem with most straps is that when you tie something to a bike it is nearly always something soft. As you ride that item will compress and the tension on the strap loosens up. You are constantly tightening them, unless you cranked the hell out of them in the first place, and then you have issues with smashing your gear, or damaging the bike.
Now, I know a lot of you have never had an issue, but can you honestly say you have not had to adjust your straps fairly often on a long ride?
ROK straps virtually eliminates that issue. They just do not get loose. As for the plastic buckles, they only fail when you do not clip them in all the way. I had only ONE failure in tens of thousands of miles and that was due to only getting one side of the clip properly in place. Even then, it only failed when I was trying to take it off.
Jim
Old 02-07-2013, 09:16 AM   #41
lmychajluk
Oddometer: 1,864
Jim - Based on your comments, would you recommend against soft luggage like the Wolfman Teton or Expedition saddle bags, where the mounting straps double as compression straps for the bags themselves?
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is offline   Reply With Quote
Old 02-07-2013, 09:25 AM   #42
SCQTT
Zwei Kolben
SCQTT's Avatar
Oddometer: 5,346
Thanks Jim......I did not feel like typing that all out.
I was ready to chime in with I tie my stuff down with logging chain....you know...cause, ITS"S STRONG!
This is SPARTA!
SCQTT is offline   Reply With Quote
Old 02-07-2013, 09:27 AM   #43
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 11,475
Rokcraps
You KNOW, don't you, that your wit detracts from any useful content your post might have had . . .
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 02-07-2013, 09:47 AM   #44
jgiacobbe
Skid plate tester
jgiacobbe's Avatar
Oddometer: 2,153
I had 2 Rock straps fail at the same time in the same way leaving my dry bag sliding down the road behind me. I guess I had them too tight because they both broke at the nylon used to attach the plastic buckles. It was almost as if the buckle wore through the fabric. Now I use cheap nylon webbing and good old fashioned knots.
jgiacobbe is offline   Reply With Quote
Old 02-07-2013, 10:01 AM   #45
JimVonBaden
"Cool" Aid!
Oddometer: 51,768
Those are a bit different in that the straps are integrated. I suspect, though lack direct knowledge, that they hold better than non-integrated straps.
Jim
Times are GMT -7.   It's 12:40 AM.
