Old 02-07-2013, 12:48 PM   #1
Wistrick OP
Wistrick's Avatar
Oddometer: 275
changing stand
I can't seem find an answer can this be used on tubeless tires on regular street tires the pictures only show dirt tires,,
http://www.chaparral-racing.com/Prod.../124-1039.aspx
thanks
Dan
Wistrick is offline   Reply With Quote
Old 02-07-2013, 02:40 PM   #2
ColemanCox
Oddometer: 87
I have that same stand and haven't had any issues changing tubeless tires. Go back and forth between TKC80s and Anakee's.
Thanks,
Coleman
ColemanCox is offline   Reply With Quote
Old 02-07-2013, 03:26 PM   #3
dirtybike
Oddometer: 125
Thanks,
Coleman
What wheels? I use a Mike's Racing Product stand, (similar idea, but higher off the floor), but I don't have the bead breaker. Do you use the bead breaker for tubeless tires on spoke rims? Like the OP mentioned, most of the advertising details are oriented toward dirt bike wheels.
I'm considering adding a bead breaker to my stand to use on my R1150GS wheels.
dirtybike is offline   Reply With Quote
Old 02-07-2013, 03:48 PM   #4
Wistrick OP
Wistrick's Avatar
Oddometer: 275
I was looking at the mikesracing one I am changing tires on a Kawi Versys and a MG Norge...I would love to buy mikes racing one if it will work..
Dan
Old 02-07-2013, 04:00 PM   #5
dirtybike
Oddometer: 125
I've used my MRP stand on my R1150GS spoke wheels, my R1100RS cast wheels, R90/6 spoke wheels, and my XR400. The stand just helps you keep the wheel in place - - instead of chasing it around the garage floor -- and protects the disk and sprocket from damage.
I use a separate bead breaker, and tire irons to change the tires. Nice thing with the MRP stand is that you put your foot on one of the legs to keep it steady,and you can use your hip to push against the tire. Also saves your knees, as the tire is at hip level.
When I saw the stand that you linked, I was wondering if the bead breaker was effective. MRP has an add on bead breaker that I have been considering.
I also wonder if anyone uses a mounting bar like a MojoLever with these stands.
Old 02-07-2013, 04:27 PM   #6
ColemanCox
Oddometer: 87
Spoke wheels on my 1200GS Adv.... No issues breaking the bead on either of the tires.
Coleman
Old 02-07-2013, 05:34 PM   #7
Wistrick OP
Wistrick's Avatar
Oddometer: 275
mikes racing stand inbound
Mike called me back quickly and says it will work just fine...so I ordered one...
Dan
Times are GMT -7.   It's 08:39 PM.
