Old 02-07-2013, 04:19 AM   #16
GodSilla OP
I did that.
GodSilla's Avatar
Oddometer: 6,426
Well, my little mate welded a large lever to the pin (welded both sides of the hole) and we worried away, but just ended fatiguing the pin off.
So, I'm hunting for a metal disintegrator just over the border tomorrow, and if I can't find one (or if they charge too much) I'll simply be looking for a replacement.
This is the last roll of the dice for this caliper.
I'm here all Millenium, 2 shows a day......
GodSilla is online now   Reply With Quote
Old 02-07-2013, 04:39 AM   #17
exoff-roadgoat
Will ride for food
exoff-roadgoat's Avatar
Oddometer: 3,239
I would go with #9 or #10.
exoff-roadgoat is offline   Reply With Quote
Old 02-07-2013, 04:45 AM   #18
See-Three
C3
See-Three's Avatar
Oddometer: 104
I had this very same problem last summer. I tried welding the brake pads to the pin to use as levers, but they would just bend. I settled with drilling the pin out and using a nut and bolt. worked like a charm.
See-Three is offline   Reply With Quote
Old 02-07-2013, 09:01 PM   #19
GodSilla OP
I did that.
GodSilla's Avatar
Oddometer: 6,426
I was nursing that idea myself See-Three, but I have found a solution.
An ex-local in here put me on to a workshop that employs a guy who rode trials in the same club I used to be in, and I took it out to show him. He has a metal disintegrator/spark eroder but said it is slow, old hat now, and expensive, then went on to say he can fix it fairly cheaply with his milling machine. So I get it back next week - yay!
I'd like to thank you all for your time and suggestions, it is much appreciated. This place contains the best folks around for sure.
Times are GMT -7.   It's 01:43 AM.
