02-08-2013, 08:07 AM
#60016 | |
Oddometer: 734
Can you put up a link to the web page i need to be on? i have the hardest time on there web site. Wanted to email them about a return and keep getting asked ?'s i could not answer and i could not get to there email. stuck |
02-08-2013, 08:11 AM
#60017 |
Kool Aid poisoner
Oddometer: 4,830
You need to log into the My Garmin page and then click on the My Support tab. Since you use your own log in and password I obviously can't link it for you.
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
02-08-2013, 08:16 AM
#60018 |
Oddometer: 734
02-08-2013, 08:28 AM
#60019 |
Kool Aid poisoner
Oddometer: 4,830
It won't access ANY of the maps including the latest CN or Topo maps when I have them installed on the card. If I install them directly to the GPS memory then it allows me access to them.
02-08-2013, 08:32 AM
#60020 |
Kool Aid poisoner
Oddometer: 4,830
Also, you can actually SEE those maps on the card in the My Garmin Devices column, but you can't find them under the pull down menu for Currently Displayed Maps.
02-08-2013, 08:34 AM
#60021 | |
Oddometer: 734
So your having the same problem when u download to ur card only Albie? Are u getting the error message when u plug in ur gps? |
02-08-2013, 08:37 AM
#60022 | |
Oddometer: 4,811
![]() Morning Gents!
RIDE SAFE |
02-08-2013, 08:41 AM
#60023 |
Kool Aid poisoner
Oddometer: 4,830
Here's a shot of what I'm talking about Charlie, I've got the Topo 24K and CN 2013.30 loaded on the GPS, then I have TOPO 100K and CN 2013.20 on the SD card. I can only access the 2 maps on the GPS mem, but not the 2 on the SD card.
02-08-2013, 08:43 AM
#60024 |
Kool Aid poisoner
Oddometer: 4,830
I don't get any error messages, I just can't use the maps on the card.
02-08-2013, 08:50 AM
#60025 | |
Oddometer: 734
Well its nice to see it might not just be me then. If the maps all fit on the GPS with room left over is there a reason to have the card? The guy at garmin said it would run better with the maps on the card. stuck |
02-08-2013, 09:01 AM
#60026 |
Kool Aid poisoner
Oddometer: 4,830
Well, you either have to move the maps to the GPS memory or load them up on your PC if you want to be able to use them in BC. Since you probably only need a couple blocks from CN (unless you plan on doing a lot of long road trips) the mapset should easily fit on your on your GPS.
02-08-2013, 09:17 AM
#60027 | |
Oddometer: 734
stuck |
02-08-2013, 09:22 AM
#60028 |
Oddometer: 23,824
I still like mapsource much better than base camp..
02-08-2013, 09:23 AM
#60029 | |
Kool Aid poisoner
Oddometer: 4,830
#60030 |
Kool Aid poisoner
Oddometer: 4,830
Of course you do, You probably like Windows 98 also.
