Old 02-05-2013, 10:51 AM   #16
kruzuki
Gear in the Machine
kruzuki's Avatar
Oddometer: 798
Brake fluid works and looks good for about a day. That's why all the used car lots use it.
I'm allergic to asphalt, whenever I touch it I get a rash.
kruzuki is offline   Reply With Quote
Old 02-05-2013, 11:28 AM   #17
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,538
Originally Posted by simmersonwheels View Post
I've been reconditioning bikes for years, worth cockpit silicone is a miracle on any black plastic. Faded signals, instruments, trim etc, maes it literally like new
Wurth? hard to find in BC and some of their products aren't even available in Canada. Mind you I saw a Wurth rep driving in Kelowna last year, couldn't turn around and chase him for ahum.....infos and catalogues.
Yeah I know, all that stuff is online but if available in Courtenay well, our C/O Dustin would hand deliver to me.
I'll go put brake fluid on my test saddlebag, can't be worse than everything else I have done to it and I can still make it look like new with more than a few products or techniques. The brake fluid I put on my XR sure has worked for quite a while. Too bad we did not know about that back then.....I may have been tasked to do that.But would have been DOT3, much stinkier than DOT4. We just used pure silicone in the 70's, must have been even before ArmorAll and all them other consumer potions.
DOT 5 is silicone based....no car lots around here to ask.
Have tools, will travel!
Old 02-06-2013, 08:38 AM   #18
Terry
Terry's Avatar
Oddometer: 1,301
I see a Wurth NON-silicon (carnuba) Cockpit Care Spray or a Wurth Vinyl and Rubber Care with Silicone. Which is it?
http://www.stableenergies.com/Wurth/products/267/
"The rights of every man are diminished when the rights of one man are threatened." John F. Kennedy, June 11, 1963
Terry is offline   Reply With Quote
Old 02-06-2013, 11:39 AM   #19
MacNoob
MacNoob's Avatar
Oddometer: 1,584
DOT 5 Silicone brake fluid. I did my pink KLR last summer, only to find out that it is actually red. And it's still red.
"Ignorance, you see, can be out thought. Arrogance can be outmaneuvered. But ignorance and arrogance combined are unassailable."
82 Honda C70, 71 Honda CL175, 08 Kawasaki KLR650, 85 Honda GL1200 Goldwing
MacNoob is offline   Reply With Quote
Old 02-06-2013, 12:01 PM   #20
Aprilia
Oddometer: 670
Heat gun...as previously described you heat a small area keeping the tip moving till the plastic just glasses over. Let it cool for a moment then hit it with terry towel and polishing compound for a quick buff before moving on. This is my KLR after I scubbed it repeatedly. It had been left outside for 12yrs in Az desert sun.
After heat gun treatment....
Aprilia is offline   Reply With Quote
Old 02-06-2013, 12:09 PM   #21
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,538
There was one of them pink ones for sale not too far. I should have considered it.The pink color may have been a bargaining tool on his too high asking price.
Better drive up to the village they may have DOT5 altough I don't think so, had a hard time last year if just for the DOT4 I needed and wasn't cheap.
$15.00+ at CT the DOT5.....I should really buy a KLR and go get it sunfaded in Mexico. Maybe not a KLR but that's the plan.....thumper and sun.
Old 02-07-2013, 01:10 AM   #22
heirhead
Oddometer: 513
Hello,
Googled cockpit silicone and they sell it on Alibaba global sales but you have to buy 2,000 minimum.
Hope its good.
Heirhead
heirhead is online now   Reply With Quote
Old 02-08-2013, 06:00 AM   #23
Flying-D
Just Passing Through
Flying-D's Avatar
Oddometer: 2,616
Google search didn't really yield any results for "worth cockpit silicone." Any more info? Is this a trade name or a brand name?
It's really all just stuff...and in the end, none of it means shit.
Flying-D is offline   Reply With Quote
Old 02-08-2013, 09:49 AM   #24
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,538
Wurth.
Apparently some of their products have a nice scent. Hum, wonder what the scent is, I don't like most of them added "scents".
26,500 results under Wurth!
https://www.google.ca/search?source=....1.aID-VIoKZ9w
Times are GMT -7.   It's 08:14 AM.
