02-08-2013, 04:07 AM
#16 | |
Brit in the Soviet Union
I would agree with you if it was a bike built with 1980's technology, but 90,000 km is nothing for a conservative modern motor (normal power for a 950 twin and not particularly high revs/piston speeds). The Nikasil bore showed no signs of wear - I could not feel a step between the area where the rings had made contact and where they had not. The surface colour was a little different, but the original honed surface was still very much visible. The Nikasil is very, very hard - really much better than previous common bore materials. The piston-ring end gaps were/are well within the service limit (was 0.30. limit 0.50 mm). The bores had the original finish, then the honed finish, but oil consumption was the same in both cases. My leak-down test suggested a good seal, but as I have not experience re leakage tests, I'm not sure of the conclusions that can be drawn from them. For these reasons I find it hard to believe that bore/piston/ring condition is responsible for the high oil consumption. But I don't know enough to be sure. Thanks for your input - it helps me think it trough.
KTM 950 Adventure (2004) Honda 650 Dominator (1988) Kawasaki KLR 650 (1988) Yamaha RD 350 LC (1984) |
02-08-2013, 04:19 AM
#17 | |
Looking at my leak-down results, do you think that ring seating could be the problem? Thanks.
02-08-2013, 04:27 AM
#18 |
Oddometer: 5,032
Compression is good. Did you change the oil rings. What’s the filter like?
02-08-2013, 04:37 AM
#19 |
Rear plug after 5000 km
This is my rear plug. Removed after around 5000 km, during high oil consumption:
![]() Is it a plug from a cylinder that's burning too much oil (0.34 litres/1000 km)? I think the dry black soot around the outside is completely normal. And the rest looks pretty good - maybe it shows the fuel/air ratio to be a bit weak? But there's a lot of oil on the sealing ring! I've just noticed it. Is it oil? It looks like it. Maybe the pressurised oil from the cam-bridge is getting past the bottom spark-plug-tube O-ring? Once in the spark-plug tube/chamber, the oil may evaporate, or drain out of the drain hole to the outside of the motor.
02-08-2013, 04:49 AM
#20 | |
Yes, I did change the oil rings. Which filter? The air filter - I always replace at the beginning of each season - every 12 - 14,000 km. So it's been old and new over the high oil consumption period. The oil filter - I change twice a season - every 6 - 7,000 km. Thanks.
KTM 950 Adventure (2004) Honda 650 Dominator (1988) Kawasaki KLR 650 (1988) Yamaha RD 350 LC (1984) RedRupert screwed with this post 02-09-2013 at 11:16 AM Reason: Typo |
02-08-2013, 06:16 AM
#21 | |
I used a Flex-Hone to hone the bores in accordance with the manufacturer's recommendations and instructions. I used the 240 grade Aluminium Oxide version, which produced a nice light and even cross-hatched surface. I used WD40 to lubricate, and ran the tool through the bore with quick strokes for only 20 seconds. It does not look as if I've ruined the cylinder - remember that it drank oil before I honed, as well as after. Flex-Hones should not be used in two-strokes because of the ports. ![]() This is the result:
02-08-2013, 07:24 AM
#22 | |
Oddometer: 5,032
Is there oil on air filter, if you’re not loosing oil down the guides and seals and no oil is being blown on the filter, I would say due to your resent top build its just burning the oil. My lc8 burnt oil till 9k miles, then stopped. Plug looks fine, not oily and just looks like the engine is running a little rich. charlie264 screwed with this post 02-08-2013 at 10:00 AM |
02-08-2013, 07:30 AM
#23 | |
Oddometer: 186
02-08-2013, 07:42 AM
#24 |
Oddometer: 4,552
The leakdown is too high.
You need to run the leak down and listen at the crankcase vent, if it is going by the rings you will hear the air escaping. Sometimes you have too much blowby and overheat rings, they lose temper. 30 % is too high. When this happens you have to install new ones. You oil will turn black very fast if this is true Sometimes rings crack, this can be from installation or from excess piston groove wear. Rings can also be put on upside down Rod |
02-08-2013, 08:04 AM
#25 |
Ride more, BS less!
Oddometer: 8,398
I agree also. What the OP may have accomplished is makeing the bore even smoother in the end. Thus the same or worse than before.
08 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150 Hi/low beam conversions for: Trail Tech, Baja Designs |
02-08-2013, 09:44 AM
#26 | |
Oddometer: 107
/OT
--- '03 KTM 950 Adventure |
02-08-2013, 10:19 AM
#27 |
bikaholic
Oddometer: 1,536
If you think using thicker oil is the answer you're ass backwards as it is harder for the rings to wipe off the thicker oil. Try going to a lighter oil it takes less power to circulate and may even improve gas mileage a little.
02-08-2013, 04:16 PM
#28 |
Oddometer: 267
Yea,, it does not take very long at all to seat rings when everything is right.. 30 weight non detergent oil can be found at marine suppliers sometimes in my country.. as hard and sharp aas nicasil is I'd expect less than 100 miles ot bed the rings, sometimes some mild lugging for 2 or three minutes will help..
On a engine with forged piston and aluminum bore the leakdown needs to be done as soon after stopping as possible, you need the motor warm. The forged pistons loosen way up when cold.. The cosworth I mentioned would go from 30% cold to 5% hot.. :) Cheers Dave |
02-08-2013, 05:01 PM
#29 |
Oddometer: 136
Ring lands
I can't report on KTM 9xx pistons, but I have seen worn 1st/2nd ring lands causing oil consumption in automotive and motorcycle engines. They also had good compression and moderate leak down.
02-08-2013, 05:44 PM
#30 |
ADVENTURE-HOLIC
Oddometer: 206
crankcase pressure
excess crankcase pressure or poor/improper venting can contribute exponentially to oil consumption. As before, you sound like you've got your shit together....but something to consider......
Good luck and laters.....
W A L S T I B........ S F...................... what a long strange trip it's been......SO FAR...... |
