02-01-2013, 12:14 PM
#3181 | |
not dead yet
Oddometer: 3,623
Don't know much about those little 110V fridges but I'm pretty sure they don't care how level they are.
Caution: Happy Fun Guy may suddenly accelerate to dangerous speeds. If Happy Fun Guy begins to smoke, get away immediately. Seek shelter and cover head. Do not taunt Happy Fun Guy. ~ Randy DL650 DRZ400s |
02-01-2013, 01:43 PM
#3182 | ||
Reality show stunt double
Oddometer: 13,428
These are our Golden Years. ~ ECThe future is no place to place your better days. ~ DMB |
02-01-2013, 01:53 PM
#3183 |
Nobody's Robot
Oddometer: 1,327
02-01-2013, 10:04 PM
#3184 |
Befuddled Adventurer
Oddometer: 1,210
hmmmm.
Cheers, Team FTB ------------------ Team "Fingering The Bean" Looking for the woman that takes the wheel when I'm seeing double. |
02-01-2013, 10:06 PM
#3185 | |
Oddometer: 1,210
02-02-2013, 10:53 PM
#3186 |
Twisted toy maker
Oddometer: 1,498
The sink hole, or how to fuck up a leveling jack......
It's been a little over a month or so since we brought our 2003 Newmar Dutchstar home and parked it in the driveway. Since our driveway is just dirt, with a thin layer of crushed rock over it, I made a set of four 12"x12"x4" pads out of pressure treated lumber and positioned them under the jacks before activating them. In no time at all, we were nice and level, and the slides were out. last week I was doing some work changing a set of blinds over the galley window ( I hate those metal mini blinds,and I had a nice honeycombed Bali that fit perfectly in the space and matched too boot) all of a sudden, the rig lurched at the back, and there was an awful sound .It was well after dark by this time so I grabbed my flash light and went out into the rain(This is Oregon after all) got down on the ground and shined it on the right rear jack. I couldn't crawl under there, but everything looked stable enough to wait 'til daylight.
The next morning I went out to survey the damage. I won't repeat what I said. However, a 2 foot across sink-hole, about 18 inches deep had opened up under the jack.You can imagine the words that came forth. We had some sewer work done a few years ago and there must have been a void in there just waiting for 16,000 pounds of RV to find it. The pad I had made, in this instance did more harm than good, as the hole opened up in just the right place for it to tilt into the hole, causing the foot to come off the jack. The end of the hydraulic piston was embedded deep in the hole where I couldn't see it. I retracted the jacks. they all came up except that one. Ok Plan "B" owners manual, manual retraction, ok got it. followed them to the letter. No good. OK, plan "C" Start up rig let suspension air bags fill. unit lifts. Place filler in hole then set 2x6 chunk between it and jack piston. dump air, forcing piston upwards. Repeat as needed until levelling system warning light goes out and shrill alarm stops. reversed all of the instructions on the manual retraction. and now we're ready to roll, from the looks of things, I'm going to at least need a new retractor spring. I hope to hell those feet are designed to do what this one did. A new jack would be a serious pain right now. I'll get under it again tomorrow when I can get it onto solid concrete and try to get the foot back in place......
I like your Christ, I do not like your Christians. Your Christians are so unlike your Christ - Ghandi Leave everything to Chance..... |
02-03-2013, 06:09 AM
#3187 | |
one really mean cat
Oddometer: 2,674
02-08-2013, 10:25 AM
#3188 | |
On Any Sunday
Oddometer: 578
"Nothing can stop us but fear and common sense” |
02-08-2013, 09:56 PM
#3189 |
Oddometer: 261
Who makes a MH, like the Bluebird Wonderlodge?
Some time ago, I found a line of well respected diesel pushers. The model I liked was about 40', with an entry at the front.
The ones I could afford, were made in the late 80's and early 90's. They look like a Bluebird Wonderlodge. All metal construction, no slideouts. I can't remember what they are called, anybody help me?? |
02-09-2013, 06:26 PM
#3190 | |
Old wanderer
Oddometer: 302
All metal...entry at front: perhaps a converted MCI or Prevost? Conversions were done by several firms, some on new coaches and some after service. Wide range of interiors/plans. All metal...most made with mid entry: Newell. Or could be a Wanderlodge...my FC is the "school bus" style...in late 80's BlueBird changed chassis/bodys to resemble the mainline RV style. These were typically 40'...the telling of most Wanderlodges of this era is the distinctive "goat rail" around the roof perimeter and a sturdy rear ladder for the heavy alum. plate roof deck and two spotlights on the front. If you go to Wanderlodge Owners Group and look at the coaches for sale...you will see a range of the styles. A site for many other brands (Prevost/MCI) is busforsale.com
02-09-2013, 10:22 PM
#3191 |
Oddometer: 261
Thanks Faw3 ,
I found what I was looking for: it's the Foretravel U320. I especially like the above model, built after 1996. I start my inquiries now, I hope they have a good reputation. Smoky |
02-10-2013, 03:34 PM
#3192 | |
Radical centrist
Oddometer: 21,234
Sent from my iPad using Tapatalk HD
PirateJohn -- http://www.PirateJohn.com IBA #7552 - SS1K in 2000 and 50CC in 2002 In the Laredo, TX area and always willing to help travelers escaping into Mexico.
02-11-2013, 09:38 AM
#3193 |
Oddometer: 261
So I'm new to this. Is FRP a much poorer construction?
I've been comparing the Bluebirds to the Foretravel. I really like the looks and interiors of the Foretravels. But are the Bluebirds a better coach, and all steel construction? Can you direct me to a good forum on these topics? Many thanks. |
02-13-2013, 09:58 AM
#3194 |
Radical centrist
Oddometer: 21,234
FRP isn't as sturdy and can delaminate. Once water gets inside the layers the wood paneling (assuming they used wood sheets, which is common in boat construction) can deteriorate quickly.
Steel is sturdier. There are plenty of stories of Wanderlodge owners surviving crashes, hurricanes, and fallen trees that would have seriously damaged or destroyed a lessor motorhome. With all of that said Wanderlodge was about the last holdout for steel construction and there is a reason for that - steel is hugely heavy, and you get a vehicle with relatively poor fuel mileage (expect about 4.5 mph for a PT series Wanderlodge and maybe 8-9 for a Forward Control). That, and as slideouts became popular the extra weight was just unmanageable. So you pays your money and you takes your choices. Foretravels have a reputation for being a really nice FRP build but you probably want to look at the individual unit before any money changes hands. Ditto with Wanderlodges - that steel body usually holds up well but sometimes everything else has been neglected. Sent from my iPad using Tapatalk HD
02-13-2013, 10:09 AM
#3195 | |
visionary
Oddometer: 2,043
![]() I figured that if you drove that slowly, you'd get much higher FUEL MILEAGE!! (fixed for yas)
"Good Times & Good Friends Make Life Better" www.artworks-unlimited.com |
| Thread Tools | |
