02-08-2013, 07:58 PM
#16 |
Lampin' it
Oddometer: 4,234
About that hat you owe me Just kidding, looks great!!Maybe time to nOOb up this thread with some Sailah machining. This should be in Fabrication 001 Copied this from my build threadGot my stuff back from the waterjet guy. First the Dong is Done Fits well, I knew I'd have to grind it where the welds from the tab attach to the frame. No biggie, and the bolts line up great. I'm going to punch some holes in it and hopefully find a good peg position when the new IMS pro pegs arrive. My waterjet guy looks at me when I walked in and said "WTF is that??" ![]() ![]() ![]() He also made a plate that the fuel pump will bolt to. I had to open up the hole slightly to about 60 mm. I don't use my 4 jaw chuck often but tonight was one of those nights ![]() ![]() Here it is bolted to the plate ![]() ![]() And the 4" square tubing I'm basing the surge tank from ![]() I need to find a sealant for the threads as they will be exposed to gas, didn't really think that through. Any suggestions? I bought some Loctite No 567 sealant as it was recommended for gasoline.
We're not out here to rough it. We're here to smooth it . Things are rough enough in town. Nessmuk |
02-08-2013, 08:38 PM
#17 | |
Oddometer: 1,093
couldnt that piece have blind tapped holes so you dont have to use sealer ? I just hate to count on sealer, you know how it is, less chances you give it to leak- the less chance it leaks. |
02-08-2013, 08:52 PM
#18 |
Oddometer: 1,093
Close- jacks, snowmobile jacks (powder jack). They are actually 100% made in the USA- 90% right here in Colorado - in my shop . The company owners used to farm some of the work out but I managed to get most of it into my hands. For a few months out of the year it is pretty good work, no home run job, but it makes some money and they really do have a great product.Here's a new one - not a vent cover either -
02-09-2013, 07:38 AM
#19 |
Oddometer: 256
567 is my favorite thread sealant for everything (I have used almost every kind out there). If it's recommended for gas I would go with it.
02-09-2013, 10:00 AM
#20 | |
Oddometer: 7,200
02-10-2013, 02:11 PM
#21 | |
Oddometer: 1,093
02-10-2013, 02:23 PM
#22 | |
Oddometer: 7,200
02-10-2013, 05:35 PM
#23 |
Lampin' it
Oddometer: 4,234
Remade the part using 3/8" plate. Bored the center hole on the lathe. transfer punched the holes, drilled 5mm holes close to the bottom using drill stop on the press. Tapped using a M6 but I need a bottoming tap to get all the way down. Have one on order.
The one I made came out nicer than the waterjet part. I spent hours laying those out in CAD, took 30 seconds with a transfer punch and the holes are more accurate. You can see the stock donut gasket so I used some longer button head M6 bolts I had. I also clocked the fuel pump so that it will fit in the corner of the square tubing. ![]()
02-10-2013, 06:04 PM
#24 |
Oddometer: 7,200
Would there be any benefit in radiusing the pump bore so the donut sits down lower and has a larger contact area and you can use shorter screws? Might reduce squeezeout.
02-10-2013, 06:19 PM
#25 |
Lampin' it
Oddometer: 4,234
probably but I was trying to get the part made. I thought about grinding a radius on a turning tool then got lazy
02-11-2013, 03:10 AM
#26 | |
QuestionableBanterer
Oddometer: 10,906
Or does it compress into a groove in the pump? I can't see it too well. |
02-11-2013, 05:39 AM
#27 |
Lampin' it
Oddometer: 4,234
I believe you are correct the groove is in the fuel pump flange on the tank. I'll chuck it up and redo it.
02-11-2013, 06:09 AM
#28 | |
Oddometer: 10,906
Gland/groove depth should be 80% of o-ring cross section and 50% wider. You probably knew that, but I like reading the handbook. |
02-11-2013, 06:37 AM
#29 | |
Oddometer: 1,093
BTW- next to thumbing through the McMaster Carr catalog, I too like to read the machinery's handbook. Guess some people are weird that way |
02-11-2013, 07:02 AM
#30 |
Oddometer: 10,906
