Old 02-09-2013, 12:28 AM   #33016
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,722
[QUOTE=TrailDust&SaddleLthr;20683184]
Originally Posted by what broke now View Post
I have no idea about Yamaha's warranty policy,...
A few months ago I thought my fuel pump had gone out so I had my dealer investigate a possible free replacement by Yamaha should I have needed one.... Good thing there was nothing wrong with my fuel pump afterall and I did not need to replace it... but, for what it's worth, according to my dealer, whom I trust (rare for me to trust anyone!), Yamaha did not show having any recall or anything of the sort on those fuel pumps, so, had I needed a new one, I would have had to pay for it!
From what I have read, it seems that the most common denominator of fuel pump failure was caused by extreme heat (bike sitting in the sun for hours, even with engine off) and low fuel in the tank. So, for better or for worse, this is what I will believe for myself and I won't worry about it until my pump craps out on me... till then, I will just ride and trust the bike!
Some inmates on here also posted failure on replacement pumps as well.
I also read on here that a few members got theirs replaced for free by Yamaha at one point... they were lucky devils! Don't expect it!
As far as cost, several inmates here mentioned the best place to get a new one was from Service Honda and those pumps cost about $215.00 or so a few months back. It seems that they were on backorder for a long time from Yamaha though... don't know if it is still the case.
Thought I'd share my personal experience and what I heard on the subject.
Nothing more.
Cheers!
A good dealer can have them replaced under the emissions warranty. Several have but some won't.
Mr. Fisherman is offline   Reply With Quote
Old 02-09-2013, 06:35 AM   #33017
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,133
My fuel pump quit working last fall after the bike sat for a few months. I pulled the pump out and cleaned the electrical connector real good and then dabbed some electrical grease in there to keep out the elements. It started working again and got me through a 2500 mile trip. I ordered a new pump just in case... $405!
That connector is totally exposed to all the mud and water that collects under the tank. Cleaning and protecting it periodically is probably a good precaution.
Nothing more.
Cheers!
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 02-09-2013, 07:46 AM   #33018
ADWrider
AKA Acorn27
ADWrider's Avatar
Oddometer: 86
Nothing more.
Cheers!
Great info guys, exactly what I was looking for. Thanks!
Only God decides the LENGH of your life, but you decide its WIDTH.
ADWrider is offline   Reply With Quote
Old 02-09-2013, 08:11 AM   #33019
bogboy
bogboy's Avatar
Oddometer: 58
Nothing more.
Cheers!
Do these pumps seem to go when you install a larger tank? I plan on getting a 4.7 IMS and was wondering if it has to do with fuel below pump while pump runs instead of being submerged. Have folks been having problems with stock tank fuel pumps?
bogboy is offline   Reply With Quote
Old 02-09-2013, 08:18 AM   #33020
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,932
[QUOTE=bogboy;20685333]
I can only relate my experience... 2010 WR-R I purchased new. I installed the 4.7-gallon IMS tank in May of 2011 and have since put over 10K miles on it. The bike has almost 21K total. No fuel pump issues.
GSBS is offline   Reply With Quote
Old 02-09-2013, 10:37 AM   #33021
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,317
I have not had an issue with my pump 30k kms on bike about 20k of that has been with an ims 3gal tank. But I did have a failure with a 2007 versys fuel pump. Died and left me stranded in a parking lot. Same deal just shy of $400
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Old 02-09-2013, 11:43 AM   #33022
ba_
ba_'s Avatar
Oddometer: 2,732
Pro Moto Billet rear rack
Whoever has installed one of these things were you able to get a lot of threads into the nylock nuts on the front most bolts? Seems like those bolts could be a few mm longer
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Old 02-09-2013, 12:18 PM   #33023
TwilightZone
Oddometer: 3,007
>"Whoever has installed one of these things were you able to get a lot of threads into the nylock nuts on the front most bolts? Seems like those bolts could be a few mm longer "
I believe there were two shim lengths provided (ie. tubular shims). If you have the wrong shims in the wrong place the bolts will turn out to be too short.
"I don't really know, I've been too busy falling down."
TwilightZone is online now   Reply With Quote
Old 02-09-2013, 12:20 PM   #33024
ba_
ba_'s Avatar
Oddometer: 2,732
I put the long ones in the front and the short ones in the rear since the instructions didn't specify. It seemed to leave the rack nicely balanced front to rear. Did I mix it up?
Old 02-09-2013, 12:30 PM   #33025
TwilightZone
Oddometer: 3,007
>"I put the long ones in the front and the short ones in the rear "
I think it's the opposite...
Old 02-09-2013, 12:30 PM   #33026
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by sodapop View Post
I have this one and it's awesome. Really well made.
Sent from my Nexus 7 using Tapatalk HD
Thanks guys, I ordered one of these.
UtahFox is offline   Reply With Quote
Old 02-09-2013, 12:51 PM   #33027
ba_
ba_'s Avatar
Oddometer: 2,732
I'm sensing that
Old 02-09-2013, 02:46 PM   #33028
TwilightZone
Oddometer: 3,007
>"I'm sensing that "
Heh... I put mine together the wrong way too... the first time.
Old 02-09-2013, 02:47 PM   #33029
skierd
Wannabe Far-Rider
Oddometer: 2,925
I broke my first fuel pump at 25kish miles when I dropped the fuel tank and snapped the lead off. Current one is an '08 fuel pump I bought cheap from a rider on here as a replacement with unknown miles on it before I got it, and it currently has another 20k on it from me, with no issues. Every bike needs a problem area I guess, and the odd bad $215 fuel pump seems to be the only real issue for the WRR/X.
Dave
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 02-09-2013, 05:22 PM   #33030
UtahFox
UtahFox's Avatar
Oddometer: 446
So I'm going to look at my prospective WRR on Monday. It's a 2011 with 375 miles on it. It has some scratches on it from a low speed fall(s), otherwise it's like new. Are there any things I should look for before pulling the proverbial trigger?
Times are GMT -7.   It's 05:53 PM.
