Old 02-10-2013, 02:53 PM   #106
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,261
Originally Posted by zipper421 View Post
i have drawn up a body but im not sure what im doing yet
i started with a 24 inch wide car
im down to 22 inches
the length is stock ural 70 something
You got me sorta measuring 76" long 23"wide big box trunk,seat 22" at cockpit opening , Ural like nose 18" at narrowest.I guess you got to figure how you'll use it.Will wife,children or dog go along? Are you going camping ? MInes way bigger than I needed but I liked the idea of being able to haul allot of stuff. Your an enigma to us all out here in Adv hack land
Enigma :1: an obscure speech or writing
2: something hard to understand or explain
3: an inscrutable or mysterious person
More idea's ? http://canadagsa.smugmug.com/Motorcy...4828&k=6RQ5wGJ
There's allot to consider, you still need trail reduction and a different final drive for that R1150 the bigger it gets the more difficult it is to get moving with that 31/11 final drive and 6th will be down hill only.DB
Patience: A minor form of despair disguised as a virture.
Ambrose Bierce
davebig screwed with this post 02-10-2013 at 03:00 PM
davebig is offline   Reply With Quote
Old 02-10-2013, 05:44 PM   #107
claude
Sidecar Jockey
Oddometer: 3,636
Originally Posted by Bobmws View Post
I have a question on the swaybar, perhaps better directed to Claude.
Are the arm lengths equal, and the attachment points equidistant from the axle center on each wheel, or can the preload be adjusted to create a 'balance' in the actual travel?
Additionally, will camber adjustment affect the swaybar settings?
If you are planning on a swaybar for a hannigan it is a little different deal than what has been pictured here. We have done ouur swaybars on them and have used hannigan's type also. Our swaybar on a hannigan requires the sidecar body to be jacked up or have the swaybar run through the body. The arms do not have to be equal. The arm position (angle of the arm) is crtical as is the placement of the heim end linkcage. This is more critical with a rea rmount swaybar...and then things do change a little more on a hannigan as they do not use a front pivot swingarm on the sidecar except for their high performance sidecars. Lots of variables need to be addressed. Feel free to call me if you wish,
Claude
http://freedomsidecars.com/
Old 02-11-2013, 05:21 PM   #108
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,248
Thanks Claude.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 02-13-2013, 05:16 AM   #109
zipper421 OP
Oddometer: 204
diff swap
has anyone here done a diff swap with the 850
what years will work
any info would be appreciated
I love it when they say, "Where did you buy that ?"
zipper421 is offline   Reply With Quote
Old 02-13-2013, 06:31 AM   #110
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,261
Final Drive
Zipper
Since they are actually not differentials the bmw folk call them final drives, any r850r oilheads will work but there's lots to consider.Doe's your bike have ABS ? If so you'll need a ABS final drive or remove your ABS which isn't that hard.
The 850 used a 37/11 there are some early 1100rs that had 34/11 all the r1100gs and r had 33/11(gears stamped in top by the breather) anything is a step in the right direction. If your not going to the mountains or around the world and your easy on clutches you may not need the 37/11, they are a pain to shim if one buys the gears and builds one. I maybe able to help you out in the future as I have 3 extra final drives.If only it where as easy as slapping a chair on and living happily ever after.DB
http://www.ebay.com/itm/110974721419...84.m1423.l2648 He wants too much.
You'll eventually want one of these: http://www.ebay.com/itm/BMW-R-1150-R...32eeb3&vxp=mtr
Ambrose Bierce
Old 02-13-2013, 12:35 PM   #111
zipper421 OP
Oddometer: 204
ebay
im watching that final drive
you think its to much
i made my own y pipe
i only buy what i cant make
Old 02-13-2013, 01:17 PM   #112
zipper421 OP
Oddometer: 204
almost
today was a good day
so tempted to put it on the ground but i still have the sway bar to build
every thing els is done
almost time to powder coat
Old 02-13-2013, 01:51 PM   #113
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,261
[QUOTE=i made my own y pipe
i only buy what i cant make[/QUOTE] Why didn't I know that ? Rhetorical.
That's too much but they are few and far between, the 33/11 I sent you also would be a cheap upgrade and allow you to keep the ABS and might be enough unless your a slow hand on the clutch and its a good price.
Where did the Hiems come from on car spring adjuster ? DB
Ambrose Bierce
Old 02-13-2013, 02:05 PM   #114
zipper421 OP
Oddometer: 204
pm
not sure what you sent me
hiems are off ebay
Old 02-13-2013, 03:08 PM   #115
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,261
hiems are off ebay
Link http://www.ebay.com/itm/110974721419...84.m1423.l2649
link http://www.ebay.com/itm/360591763976...84.m1423.l2648
Ambrose Bierce
Old 02-15-2013, 05:55 PM   #116
zipper421 OP
Oddometer: 204
sway bar progress
past couple days spent on sway bar
progress is slow but hopefully well thought out
rework sucks
Old 02-15-2013, 05:58 PM   #117
AceRph
Affluenza Free!
AceRph's Avatar
Location: Where the stupidest people on earth run things
Oddometer: 24,634
Nice work.
Equal to all of you of roads and good luck! - krokodil al-kashi
“We are turning into a nation of whimpering slaves to Fear—fear of war, fear of poverty, fear of random terrorism, fear of getting down-sized or fired because of the plunging economy, fear of getting evicted for bad debts or suddenly getting locked up in a military detention camp on vague charges of being a Terrorist sympathizer.” —”Extreme Behavior in Aspen,” February 3, 2003
"The State sees the spectre looming ahead of terrorism and anarchy, and this increases the risk of its over-reaction and a reduction in our freedom." - Stanley Kubrick
AceRph is offline   Reply With Quote
Old 02-15-2013, 06:33 PM   #118
zipper421 OP
Oddometer: 204
work
thanks
Old 02-15-2013, 07:20 PM   #119
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,261
Hmmmmm !
Zipper
We've grown accustomed to pretty nice work, but that's really a standout! Only one question is that bar solid ? Who did you consult on how much bar is enough ?DB
I think you owe yourself a present a liquid cooled torch and a cooler or something !
Ambrose Bierce
Old 02-15-2013, 07:30 PM   #120
zipper421 OP
Oddometer: 204
hey
thanks dave
google miller syncrowave 350
o its liquid cooled
the lights in the neighborhood go dim and all the tvs go black when i fire up my welder
Times are GMT -7.   It's 10:46 AM.
