Old 02-09-2013, 10:37 PM   #226
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,789
Originally Posted by NDEBT View Post
I bet Bueller can work on these. I cant. I get it but everytime I try to fix one these it kicks my ass.
You can't even spell epitrochoid.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 02-09-2013, 10:43 PM   #227
NDEBT
NDEBT's Avatar
Oddometer: 5,217
I can now. Thanx.
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. -Mark Twain
NDEBT is offline   Reply With Quote
Old 02-09-2013, 10:49 PM   #228
cogitate
cogitate's Avatar
Oddometer: 5,146
Question for the TDI fans:
One of my friends has a 2012 TDI. She told me today it has a shudder when it accelerates, and a lag. Her previous car was a Mazda 6, before that an Acura RDX. She knows how to drive well, and drives a lot.
The dealer told her all TDIs do that, she just needs to get used to it.
Anybody know if a shudder is normal? She says once up to speed it is fine. She is getting 35 mpg, I thought it should get better
bikeless. And doing ok with it. For now.
"The Howtostretch Handbook", a guide to stretching, free download
cogitate is offline   Reply With Quote
Old 02-09-2013, 11:40 PM   #229
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,789
I can now. Thanx.
That is the answer I was hoping for. Thank you.
Old 02-10-2013, 07:03 AM   #230
soldierguy
Location: California, sometimes the coast, sometimes Tahoe
Oddometer: 473
I used to have a '10 Golf TDI with the 6-speed manual and had no shudder. Not much detail in your post, but I'm assuming a low-speed shudder, like when she first lets off the brake at a stop light? If she's got the DSG transmission, I've heard complaints about shudders and lag coming off the line. Could be a programming thing. I'd have her go test drive a similar car and see what happens, as well as get the dealership to plug it in and make sure there aren't any stored codes, software & firmware are up to date, etc. Also, if after test driving a different one your friend believes hers isn't normal, she should have her service advisor ride with her to make sure they experience the issue. Early on there was a batch of questionable DSGs, but that was well before your friend's '12 TDI.
Turbo lag. In mine, just coming off the line I'd notice a small amount of turbo lag, but by 1500-1600 rpm the car was on boost and all was well. Wasn't noticeable in mine once I was moving. Again though, I had a manual, and I'd think a DSG would make lag feel worse because the computer is likely trying to get the car out of the clutch friction zone as quickly as possibly and with as few revs as possible to reduce wear and prevent heat buildup.
35 mpg sounds like it could be normal...keep in mind the EPA ratings (depending on transmission) are 30-31 city and somewhere between 40-42 highway. The new TDIs (09 and later) are very economical IF you stay out of boost and keep the revs low...drive anything other than very economically, and the mileage will be less than the older TDIs. I typically got high 30's in mine around town simply because I stayed out of heavy boost and tried to drive economically. Highway I'd see 42-45 mpg keeping my speeds in the 70-75 neighborhood, and averaged 50 on one tank of 65 mph freeway driving.
soldierguy
'13 Yamaha Super Tenere - my dream bike
soldierguy is offline   Reply With Quote
Old 02-10-2013, 07:10 AM   #231
ducnut
Oddometer: 3,305
^^^ In addition, I think I'd look to another dealer.
I'm not a fan of clutches/DSG/dual-clutch automatics, given modern traffic congestion.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 02-10-2013, 07:49 AM   #232
Bueller OP
Cashin?
Bueller's Avatar
Oddometer: 17,266
They are simplistic but fascinating engines. I've never been in one, but did see a couple of them apart because I worked at a huge multi-line dealer for almost 10 years and was friends with the Mazda techs. They typically did not rebuild them. Replacements from Mazda weren't all that expensive, certainly less than the short blocks from Mitsubishi.
Make sure you don't put conventional spark plugs in them
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 02-10-2013, 10:17 AM   #233
cogitate
cogitate's Avatar
Oddometer: 5,146
Thanks for the info, will talk to her later. She said it is the low speed shudder, not sure of the transmission. Her last few cars were manual trans, perhaps she got the DSG. Will report back
Old 02-10-2013, 10:37 AM   #234
NDEBT
NDEBT's Avatar
Oddometer: 5,217
This is a cool thread. Pulling wrenches is a very hard way to make a living. You really need to want to do it to make it work. I think everyone at some time should work flat rate. It gives you a whole different look at work most will never get it.
Old 02-10-2013, 11:09 AM   #235
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,387
+1, one of the least thankful jobs and lowest paid of the crafts. You have to be a bodyman, detective, hvac specialist, doctor, upholsterer, weightlifter, electrician, etc. And no comebacks! Or you get to do it all over again for free.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is online now   Reply With Quote
Old 02-10-2013, 07:00 PM   #236
Ducky 149
Oddometer: 326
I have been on the line wrenching for 25 years. Started on SAAB then on to Volvo and now Audi. The biggest problem is the lack of pay advancement. Every year the book drops times, warrenties get longer. They cover more. Now there is prepaid maintenance that the factory takes the money up front and then pays you warrenty time to do the service. There is getting to be less and less greybeards around that actually know how to fix something vs. changing a part. The way it looks to me is that there is going to be 1 or 2 highly skilled technicians telling 8-12 kids what parts to change out. Techs getting maybe 50-60k and kids 25-30k. Future doesn't look very bright in this industry from where I am standing.
I overheard my service mgr one time ask the Volvo rep about kicking in some money on a XC90 trans job. They were GM transmissions and were all shitters. Car had 75k on the clock. Rep looks Mgr in the eye and asks..."At what point are the people going to assume ownership of this vehicle???" Car was 25k out of warrenty and had never been in for any CP work.
"I can't believe I threw up in front of Dean Wormer!!!! Kent, You threw up on Dean Wormer"
Ducky 149 is online now   Reply With Quote
Old 02-10-2013, 07:31 PM   #237
NDEBT
NDEBT's Avatar
Oddometer: 5,217
I'm afraid we are there my friend My lead tech I pay for every flag hour the shop makes.That use to be my job I just can't do it all anymore. I push paper more than anything anymore.
NDEBT screwed with this post 02-10-2013 at 07:40 PM
Old 02-11-2013, 06:30 AM   #238
ducnut
Oddometer: 3,305
What is a "flag hour"?
'96 Ducati 900SS
Old 02-11-2013, 07:29 AM   #239
Bueller OP
Cashin?
Bueller's Avatar
Oddometer: 17,266
An hour flagged by a Tech. In other words, a billed hour of labor.
Old 02-11-2013, 07:33 AM   #240
Bueller OP
Cashin?
Bueller's Avatar
Oddometer: 17,266
The business was headed there at the turn of the new millenium. Tech pay continues to drop, and the gap between vehicle complexity and Tech knowledge continues to grow. That is the reason why I continue to work on my own vehicles despite the physical pain and difficulty it causes me for days afterward.
Thread Tools
Times are GMT -7.   It's 04:42 PM.
