Old 02-08-2013, 08:57 PM   #5221
pecos
BAM!!
pecos's Avatar
Oddometer: 532
az-twin, that looks good. You threaded a hole in the HB bracket. Did you drill into the subframe? So one bolt goes through both brackets and frame. The other bolt is just attached to the hb bracket. And the other bolt goes through hb and frame.
I am running a sw mototech rear rack and remus exhaust. The exhaust will need to be adjusted also since holes do not line up.
pecos is offline   Reply With Quote
Old 02-09-2013, 06:03 AM   #5222
vfrpilot
Stress Relief Rider
vfrpilot's Avatar
Oddometer: 719
Originally Posted by vfrpilot View Post
Here's a better pic
Sorry, let's try this again.......
*1975 Kawasaki KS125 **1987 Honda TR200 Fat Cat
*1976 Honda MR250 Elsinore **1987 Honda XR200R
*2011 Beta 400RR **2012 R1200GSA
*2012 Gas Gas TXT250 **2014 Beta 520RS
*2014 Ural Patrol
vfrpilot is offline   Reply With Quote
Old 02-09-2013, 06:21 AM   #5223
xaman
Oddometer: 541
That tank looks great
xaman is offline   Reply With Quote
Old 02-09-2013, 07:48 AM   #5224
dantroop
dantroop's Avatar
Oddometer: 176
You read my mind. I was going to ask for a pic without the bag. Nice fabrication! I like how you mitered it to follow the lines of the swing arm and at the bottom too.
dantroop is offline   Reply With Quote
Old 02-09-2013, 08:52 AM   #5225
john_aero
john_aero's Avatar
Oddometer: 1,173
are the radiaors easily damaged on these bikes?
not fan off the crash bars but if the rads get damaed in drops i will buy one
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 02-09-2013, 10:17 AM   #5226
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,422
Depends on how you crash and if you break the handlebar bolt off when you crash. The TT radiator bar on my bike has a few scars, so I think it is worth it.
tbarstow is offline   Reply With Quote
Old 02-09-2013, 12:02 PM   #5227
Royal Tiger
Pz VI B, Sd Kfz 182
Royal Tiger's Avatar
Oddometer: 1,383
Tee, it's the SW-Motech bars OR the TT radiator bar correct? i.e. you can't mount both?
2013 Yamaha XT250 * 2005 BMW R1200ST
Royal Tiger is offline   Reply With Quote
Old 02-09-2013, 12:43 PM   #5228
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,422
Correct. You can only mount one of them.
Old 02-09-2013, 04:25 PM   #5229
Antti
Antti's Avatar
Oddometer: 183
Last night I found out the SW-Motech center stand does not fit with the Touratech brake lever. My buddy is going to try and grind the brake lever pivot housing down far enough to clear the center stand bracket that mounts to the right footpeg. Ugh. Nothing is easy. We did manage to put the two new Iridium plugs in. After the center stand gets done I have to cut the Touratech skid plate to fit the SW-Motech crash bars. After that will be the Oxford heated grip install. She's coming along but slower then I'd like.
Heres TT large plate fitted with Swmotech bars.
R1100GS, 690 Enduro, R80G/S project bike.
Antti is offline   Reply With Quote
Old 02-09-2013, 05:28 PM   #5230
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,322
Yes, the one bolt just holds the Ohlins bracket to the H&B bracket. I cut the end of the bolt off so it does not go all the way through, then I used Red Loc tight on that one bolt so it would stay. I made it up the CDR like that, so I think it is good.
Rob Swartzwelder, Southern AZ
I'm not real fast, but I do have a dog named Dakar!
97 M900, 07 G650 XChallenge,11 KTM 990 ADV R
2011 North up the CDR
Sierra Vista AZ to Paonia CO and Back through Moab UT
AZ-Twin is offline   Reply With Quote
Old 02-10-2013, 08:37 AM   #5231
Royal Tiger
Pz VI B, Sd Kfz 182
Oddometer: 1,383
Thanks. I bought the SW-Motech.
Antti, thanks for the pic. I bookmarked it on my phone the last time you posted it for me.
Old 02-10-2013, 11:15 AM   #5232
john_aero
john_aero's Avatar
Oddometer: 1,173
cheers for that
Old 02-11-2013, 04:29 AM   #5233
Perun
Oddometer: 204
Wolman gets my vote. I built the racks and the dry bags are super!
Can you share some info/photos on how you bilt the racks? It looks great.
Perun is offline   Reply With Quote
Old 02-12-2013, 03:56 PM   #5234
vfrpilot
Stress Relief Rider
vfrpilot's Avatar
Oddometer: 719
Sure can.
I made my own hoops
Had to fit everything just so
Got it all fitted and welded
Then had it powder coated
Put it on and admired it
*2014 Ural Patrol
Old 02-12-2013, 04:52 PM   #5235
Gunslinger1
GIVE'R
Oddometer: 628
Show Off.............
Sure can.
I made my own hoops
Gunslinger1 is offline   Reply With Quote
Times are GMT -7.   It's 04:21 AM.
