Old 02-09-2013, 11:02 AM   #46
brucifer
brucifer's Avatar
Oddometer: 1,668
Donkey Hotey, so if the S3 and M2 share the same frame, would I be correct in assuming they share the same foot peg location?
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 02-09-2013, 11:08 AM   #47
Tim McKittrick
Oddometer: 1,448
Originally Posted by Tom S View Post
Are you really saying it’s my fault or is it just that you’re gonna blame me?
Poor example? Maybe so. From my very short time on a ‘98 S1 I don’t recall having any complaints about shifting. Not familiar with that Baker kit. My shifter & linkage are all stock items.
Suzuki? I don’t want to touch another one.
I'm content to just assign blame, and thank you for your evil influence.
I don't know the travails you have suffered at the handgrips of Suzuki products, but the ones I have owned had the sweetest gearboxes ever.
Tim McKittrick is offline   Reply With Quote
Old 02-09-2013, 11:54 AM   #48
Donkey Hotey
De Jo Momma
Donkey Hotey's Avatar
Oddometer: 8,735
Yup.
Donkey Hotey is offline   Reply With Quote
Old 02-11-2013, 12:53 AM   #49
EmptiMind OP
EmptiMind's Avatar
Oddometer: 103
Originally Posted by Donkey Hotey View Post
There were two generations of Showa shock: the earlier 16.5" and the later 14". They had some failures on the 16.5" shocks and they came up with a safety containment loop thingy that clamped around the shock in case the shock eye failed. They were butt ugly. I would imagine that bike got it and somebody removed it.
When they ran out of 16.5" shocks, they started installing the 14" shocks from the factory and any remaining bikes got it for the 'recall'. Plenty of aftermarket replacements are available in both lengths.
The 16.5" Showa is rumored to be at risk for the eye breaking (hence, the steel safety loop added later). From posts on Badweb, nobody ever ACTUALLY had one fail but, the margin is questionable. I would probably start looking for an aftermarket or at least the 14" replacement Showa. Even if that shock were perfect, it will leak sooner or later.
So any aftermarket that's the right length should fit? Any suggestions, anyone?
Someone once told me I wouldn't ever grow up.
I'm glad they were right.
EmptiMind is offline   Reply With Quote
Old 02-11-2013, 07:35 AM   #50
Mr. Canoehead
Taste Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,149
Maybe you are not asking this question but....
As a rule, just because a shock fits doesn't mean it will work. There are all sorts of issues like suspension geometry. wheelbase, linkage ratios, bike weight, etc that makes shock design very specific to a bike. You might find a 16.5" Showa shock off a motocross bike - it won't work on your Buell!
2005 GS1150 Adventure - Range Rover, 2002 DR650 SE - Land Rover
"Not all who wander are lost" - JRR Tolkien
Mr. Canoehead screwed with this post 02-11-2013 at 07:41 AM
Mr. Canoehead is offline   Reply With Quote
Old 02-11-2013, 07:37 AM   #51
Donkey Hotey
De Jo Momma
Oddometer: 8,735
Old 02-11-2013, 08:04 AM   #52
Mr. Canoehead
Taste Gunnels!
Oddometer: 1,149
I guess it seems obvious but there was a long discussion a while ago about people putting EBay WP takeoff shocks from non-linkage KTM dirt bikes on DR650's - it fit but of course it didn't work very well.
Old 02-11-2013, 08:13 AM   #53
Donkey Hotey
De Jo Momma
Oddometer: 8,735
It wouldn't work at all. Tube-frame Buell shocks get longer on the downstroke. The shock gets pulled, not pushed.
Your point would be well taken on another brand but, it was just funny to read in this case.
Old 02-11-2013, 08:59 AM   #54
EmptiMind OP
EmptiMind's Avatar
Oddometer: 103
Yeah, sorry for the generalized question. Took an ambien and apparently surfed the forums. I know Buell utilized pull shocks and understand the basic mechanics behind the shock.
What my drugged mind meant to ask is that I can get a 16.5 inch aftermarket shock meant for a sports tourer that can handle the weight rather than having to "upgrade" the bracket to fit the smaller 14 inch?
Old 02-11-2013, 09:26 AM   #55
SilveradoTX
SilveradoTX's Avatar
Oddometer: 58
This has been quite informative. Do continue.
2007 Buell Lightning XB12Scg
Lunasee. Be seen.
SilveradoTX is offline   Reply With Quote
Old 02-11-2013, 10:02 AM   #56
Tim McKittrick
Oddometer: 1,448
Because the Buell uses a pull shock aftermarket options are limited and expensive. The Penske is proported to be the best, but it'll set you back a grand or more.
The stock Showa works reasonably well and when in good condition has a bit of adjustability, but they are prone to leakage and are not easily rebuilt. As the numbers of tubers out there has declined the number of suspension shops willing to fix the showas has also dwindled.
Race Tech is still fixing them, and can improve them to a degree with their own shim stack "gold valve". A simple re-seal and recharge will restore stock performance for about $250. The addition of the gold valve will up the price but it does make the shock work better- this is the route I went and I have been very pleased with the results. I think it ended up costing me close to $500 once shipping to and from was factored in, still considerably less than the next best option.
Old 02-18-2013, 06:27 AM   #57
EmptiMind OP
EmptiMind's Avatar
Oddometer: 103
I got her
She's mine. Been riding her the last two days and couldn't be happier. Only issue I've found is that one of the luggage has a small crack. Rear shock seems to be handling two up just fine. Do have to say with that stock seat I seem to be riding on the gas tank, I hear the Corbin isn't much better, any suggestions?
Old 02-18-2013, 09:04 AM   #58
Tim McKittrick
Oddometer: 1,448
I don't have any direct experience with any saddles other than stock, but have heard good reviews of the sergeant seats.
Saddlebag repair:
http://badweatherbikers.com/buell/me...842/34032.html
Old 02-18-2013, 11:08 AM   #59
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 3,554
Originally Posted by Tim McKittrick View Post
I don't have any direct experience with any saddles other than stock ...
If you rode a KTM you’d probably think this was better.
Tom S is offline   Reply With Quote
Old 02-18-2013, 12:09 PM   #60
Tim McKittrick
Oddometer: 1,448
I do ride a KTM, and you are not far off.
I bought a Corbin for it after 3 days of ownership.
Times are GMT -7.   It's 12:00 AM.
