01-30-2013, 11:48 PM
#46 |
Oddometer: 953
i had a 87 ktm 500mx
my normal tight trails it was scary warp drive too much fun |
01-31-2013, 11:07 AM
#47 | |
Oddometer: 363
What frame is that stuffed in?
02-07-2013, 06:09 PM
#48 |
Oddometer: 335
Ill be getting an 02 kx 500 next month
![]() Does baja designs make a total ds kit for it or do I need to send it out to ricky stator?
02-08-2013, 08:36 AM
#49 |
Oddometer: 220
Mzb ignition is best solution
Can only get them through Kxriders.com One of the vendors has the rights to the K5 system.. Motorrad screwed with this post 02-08-2013 at 10:28 AM |
02-08-2013, 04:45 PM
#50 |
Oddometer: 149
I have an e-line stator coil in mine. It's OK for a Baja Headlight, but not if you really need to see anything in the dark. Takes a lot of revs to get good light. Lots of revs = lots of speed. Lots of speed and off-road riding the 500 at night is not a good combo. Damhik.
![]() The Baja kit is the generic bolt-on, where almost everything is self contained in the headlight mount. Keep your Visa card on file with BD, as EVERYTHING on the 500 is a "wear item". ![]() I've replaced lights, LEDs, relays, horns....heck, the BD aluminum main mount bracket broke from fatigue cracking. And, yes. I did have my crank trued. Barry
2001 KX 500 2001 KDX 220 - Both CA plated |
02-08-2013, 04:57 PM
#51 | |
Oddometer: 149
![]() . . . ('cept maybe a CA plated KDX220 instead of the XR. You know - two strokes.) 'sup 'RAD?
02-09-2013, 09:22 AM
#52 |
Oddometer: 220
02-11-2013, 07:37 PM
#53 |
Oddometer: 103
here is what you are looking for in colorado springs found this for you..
http://cosprings.craigslist.org/mcy/3571933321.html
KTM 08 990 Adventure ![]() KTM 01 520 SX ![]() KTM 06 300 XC-W-SXS top end mod ![]() Wife rides KTM 05 200 XC-W ![]() 2008 Honda Xr 650L
02-11-2013, 09:22 PM
#54 |
Oddometer: 70
Do it!!
DO IT DO IT DO IT!!!..the 2 stroke 3 hunny makes sweet power, light weight, will outrun most 450-530's. And is SO MUCH easier to flick around. (and pick up
) Properly jetted stock 3.2G tank will give you a reliable 75+ miles. I have an side plate tank with an extra gallon or so, easy 100 miles range, from Baja Designs, the headlight is weak, especially without a battery, you can fit a battery in the airbox with an oem KTM battery tray, bolts right in, all the street kit is easily fitted. DISCLAIMER...don't do anything before you make sure you state's DMV will let you have a plate.The only downside of these is that most organized DS rides don't have very much terrain that actually taxes a KTM 300. Put a rekluse clutch if you have the cabbage and it's like CHEATING ![]() CHEERS
R1200GS, Big ADV sled ![]() KTM 300 EXC Plated, Lil DS Rocket |
02-17-2013, 05:52 AM
#55 |
Oddometer: 5,647
I wouldn't want to ride it around the world, but it sure is a hoot to ride around town. Not to mention showing its perfectly legal taillight to almost anything else street legal on tight trails. It drinks more gas than my 640, probably vibrates more and is still one of my all time favorites.
KTM 640 LC4E KTM 200 MXC XT200 |
02-18-2013, 07:41 PM
#56 | |
Oddometer: 70
OOOOOHHHH Pweeettttyyy
02-19-2013, 07:45 PM
#58 | ||
Oddometer: 112
Challenges with a DS 2-T: range, vibration. For overland travel: relatively frequent piston ring replacement.
There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter. -Ernest Hemingway Seavoyage screwed with this post 02-20-2013 at 05:56 PM |
