Old 02-11-2013, 08:50 PM   #1
jdbski OP
old but getting younger
Oddometer: 374
Rear drive rebuild cost 2005 r1200gs 40,000 miles?
I have to get my drive rebuilt as it puked its gear oil recently. I think I stopped before causing too much damage but who knows. Anyway has anybody had their drive rebuilt and if so how much did it cost?
Thanks,
Jb
jdbski screwed with this post 02-11-2013 at 09:21 PM
jdbski is offline   Reply With Quote
Old 02-11-2013, 09:44 PM   #2
rdwalker
Oddometer: 2,439
Thanks,
Jb
Puked oil? That means that likely only a seal went. If you are lucky, no mechanicals failed and you are not facing high costs.
There are several items that could fail, so the cost will vary. If you are very lucky, it is the big seal on the side of the FD (surrounding the opening) - a not uncommon issue on the R12GS. This is very inexpensive, you just pop out the bad one and knock a new one in. Even I could do that... (Though I paid the dealer a bit under $200 four years ago, when my '06 GS had about 38k on the odometer).
Other seals are much more elaborate. Before asking for costs, you'll need to determine what happened.
rdwalker is offline   Reply With Quote
Old 02-12-2013, 06:34 AM   #3
Dan Căta
Dan Căta's Avatar
Oddometer: 1,465
Send a message via Yahoo to Dan Căta
+1 replace the seal, check for wheel play at 9-3 and 12-6. In case there is none, ride it and check again periodically.
Dan.
Dan Căta is offline   Reply With Quote
Old 02-12-2013, 12:16 PM   #4
jdbski OP
Oddometer: 374
Good to know. I suspect something had to have happened to a bearing somewhere as i got a wobbly feeling when it went, which is why i pulled over to inspect everything in the first place. The potential good news is that i did not find any metal in the fluid that i removed when i took it off the bike. and only minor stuff attached to the speed sensor too.
So the dealer has it and will call when he cracks it open. I will post the outcome when i hear the news.
Thanks,
jb
Old 02-13-2013, 09:00 PM   #5
jdbski OP
Oddometer: 374
Got the word today it's going to cost 850 all in for seals and bearings
Figure it could have been a lot worse. Can't wait to try it out.
Old 02-13-2013, 09:32 PM   #6
Final Drive
Final Drive's Avatar
Oddometer: 43
Any warning before it went? Did you wobble / check for play after the seal gave way? Just interested to learn all I can since I too have an '05.
Final Drive is offline   Reply With Quote
Old 02-14-2013, 05:35 AM   #7
rdwalker
Oddometer: 2,439
Got the word today it's going to cost 850 all in for seals and bearings. Figure it could have been a lot worse. Can't wait to try it out.
Considering that they had to open the housing (based on your note), you got away cheap. Enjoy the ride!
Old 02-14-2013, 09:04 AM   #8
jdbski OP
Oddometer: 374
i felt a wobble at low speed on the pavement. I thought i had a flat tire, felt just like it. (i have had a few rear flats over the years)
And when i stopped i had oil all over the rear wheel and tire.
jb
Times are GMT -7.   It's 09:05 AM.
