02-04-2013, 08:08 AM
#481 |
Desubicado
Oddometer: 86
Question; I currently have some 35w PIAA's mounted on my F650. As they drain my battery I would like to replace them, do you think the existing wiring harness would work, allowing me to mount your LED's and connect?
Saludos Martín
Todo es posible nada es seguro |
02-06-2013, 06:52 AM
#482 |
Let There Be Light
Oddometer: 848
Many thanks for the follow up
LED LIGHTS - LED Lights For Sale - MondoMotos - Motorcycle Accessories BLOG - BackRoadBiker RIDE REPORTS - Four Corners - Amish Country - Costa Rica - RoadRUNNER - Expedition Michigan (or not) - Tellico Plains |
02-06-2013, 10:51 AM
#483 | |
Let There Be Light
Oddometer: 848
Either of the light sets (MM10 or MM8) we sell will work with your existing wiring. Ordering "lights only" saves you a few bucks and will bolt up and wire up in place of the PIAA's (and wont overwhelm your electrical system thanks, -Brian
02-06-2013, 07:10 PM
#484 |
Oddometer: 186
I have a pair of lights from MondoMotors on my BMW 650 and they replaced the PIAA's. They are MUCH brighter, and draw much less current from the charging system. Just cut the wires from the old lights, and splice in the new lights. Meke sure to use heat shrink tubing over soldered connections. The new lights mount up very well in place of the old ones. It's a no brainer!!
Cheers, Bill |
02-08-2013, 07:44 PM
#485 |
Oddometer: 291
Received the MM10's yesterday.
Fab work in process for mounts tonight.
Piloting a bike with its disperate focus awakens clarity, perhaps the wind shews the clutter. Drawn to this place, I am inspired to share my ride, especially watching others' journeys. In a little way gregarious again, marveling at the profound experiences of nearly everyone whom I meet. Its like a whole new clan. Teach me more. |
02-11-2013, 11:06 AM
#486 |
Let There Be Light
Oddometer: 848
Like to see some pics once you get them installed
thanks, -Brian
02-12-2013, 03:53 AM
#487 |
Oddometer: 183
Finally got around to finishing up my installation on a 2002 Aprilia Caponord. With the PIAA brackets, they went right on my factory crash bars.
![]() ![]() And a video of them in action... BrittC screwed with this post 02-12-2013 at 06:10 AM |
02-12-2013, 05:50 AM
#488 | |
Oddometer: 291
Mounts are done. Turned out great. Busy wiring in a fuse block for heated gear and then I will connect my GPS and lights all at once.
02-13-2013, 07:09 AM
#489 | |
Let There Be Light
Oddometer: 848
Many thanks for the pics and video ![]() ![]() -Brian
02-20-2013, 07:13 AM
#490 |
Oddometer: 39
Can they be wired in directly?
I am thinking of getting a set of the MM10 Bullet lights on my Super Tenere for day and night driving lights. I'm also thinking of getting a set of the MM8 Flood lights to light up more of the dark back roads and what little off roading I may do.
Can I wire the MM10's into my running lights and the MM8's into the high beams? That way the MM10's will always be on even when the high beams are on along with the MM8's. Is this not a good idea or should I use some kind of controller and/or a fuse block? Is this overkill? I was thinking that the MM10's would light a bit further and the MM8's would light a wider path. Maybe the MM10's will be all I need? Does it matter what height you mount them? I was thinking of mounting the MM10's low on the crash bars and the MM8's up by the headlights. Thanks, Chris |
02-24-2013, 06:03 PM
#491 |
Wrong Island, NY
Oddometer: 1,236
Ordered my set in November and finally got around to installing them on my 2002 R1150R today. In a word- AWESOME!!!!!!!!!!!!!!
Installed them in the bolt hole for the oil coolers: ![]() Clean and elegant design made them fit sweetly in place: ![]() Switch was installed on the inside of left hand turn signal assembly: ![]() Low beam only: ![]() Low and Mondo Lights:BAM!!!!! ![]() Thinking about ordering set for the LT where the Piaas normally go in under the front cowling. |
03-06-2013, 06:34 AM
#492 | |
Let There Be Light
Oddometer: 848
sorry for the delayed response. Ive been traveling alot lately. You can wire the lights as described above (directly) no problem. Mounting either of the light sets low will light up the side of the road closer to you. thanks, -Brian
03-06-2013, 06:36 AM
#493 | |
Let There Be Light
Oddometer: 848
Thanks for taking the time to post your review and pics ![]() ![]() -Brian
03-09-2013, 05:12 PM
#494 | |
Living the Dream....
Oddometer: 2,104
Great Product!
Brian, Thanks for the lights and the great service!!!
The new units look fantastic!! I don't ride much a night.... I run them mostly during the day for visibility for on coming traffic. ....And for setting up camp on the Adventure Rides. ![]() Quote:
The F800gs Snatchy Throttle Fix Boost your Beamer...BMW efi GS Power Controller - l Now the Juice NEW!TheJUICE
03-11-2013, 06:37 AM
#495 | |
Adventurer-in-Tng
Oddometer: 12
