02-13-2013, 05:32 PM
#31 | |
Stuck...
Oddometer: 86
I'm in the exact same predicament as the poster above. I'm planning a trip that will start in WI then head to Oregon and ride the TAT (backwards) and finally end in FL. I want to be off the beaten path (or even off-road) as much as possible. I've been trying to scour the regional GPS threads for routes I can use to get to the west coast, but still need to find a GPS (and figure out how to use it
02-14-2013, 03:49 PM
#32 |
Oddometer: 20
I just subscribed to this thread, so I hope it keeps going.
02-15-2013, 08:34 PM
#33 |
Wannabe
Oddometer: 982
Tracks is where it's at so I went with the Montana 600. So far, so good but very limited use to date.
All things being equal... fat people use more soap |
02-16-2013, 09:05 AM
#34 | |
Kool Aid poisoner
Oddometer: 4,827
I'd go with the ZUMO for the ease of use. On a long trip, you're gonna hit that 50 point limit a LOT with the Montana.
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
02-19-2013, 12:30 AM
#35 | |
"Moto Porn"ographer
Oddometer: 3,800
Easy to convert one to the other. Montana takes infinitely more trackpoints than a Zumo takes waypoints. If you are building off road routes/tracks, the Montana is infinitely better.
Sibirsky Extreme 2009 BOOK and DVD available HERE Moroccan Extreme 2011 DVD available HERE www.sibirskyextreme.com |
02-19-2013, 04:52 AM
#36 |
Sure, why not?
Oddometer: 16,137
But the 660 takes tracks too, doesn't it?
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA Proud walking jingle in the midnight sun. Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/ |
02-20-2013, 01:28 PM
#37 |
Kool Aid poisoner
Oddometer: 4,827
Nope, easier to use the ZUMO with big routes for long trips
02-24-2013, 01:48 PM
#38 |
Oddometer: 28
Could you explain why the zumo is better for long trips? I'm comparing these two units and following others' tracks for long (multi-day) trips is my primary reason for getting a GPS.
2007 r1200s 2008 wr250r 2009 dorsoduro |
02-24-2013, 03:32 PM
#39 | |
Sure, why not?
Oddometer: 16,137
Routes give you turn by turn directions, so you get an audio heads up that there is a turn ahead in say, half a mile (this early alert may be configurable to a distance you like, not sure), and again when you reach the place to turn. This means you can concentrate on the road and assessing any threats, as opposed to a track that merely displays on the screen, so you have to keep looking down at it to figure out how to stay on it. Having said that, you can follow routes on a Montana, too. I don't think the Montana offers "junction view" like the 660 does, so that might make the 660 navigation marginally better, but am not sure.
02-24-2013, 03:38 PM
#40 |
Oddometer: 562
I bought a Montana in early 2012 to replace my GPSMAP 276C, which had taken me around North America numerous times without a problem. Last summer I did a month-long trip to Colorado, Utah, Nevada, New Mexico then back home. I don't care whether someone buys a Zumo, or a Montana, but to suggest that a Montana is not suited for long road trips is just plain silly. I was using routes, not tracks, by the way. Is a Zumo "easier"? I have no idea, as I've never owned one, but don't decide between these units on the basis of an uninformed assertion about either one of them.
02-24-2013, 03:47 PM
#41 | |
Oddometer: 28
thanks for the follow up
02-24-2013, 04:12 PM
#42 |
Sure, why not?
Oddometer: 16,137
It turns out that in some cases dirt roads and even some trails may be present in routable map sets like CN or the recent Garmin topo sets. In those cases, you could use routes created from your friends' tracks to give you the turn-by-turn directions when available, if that appeals to you. Of course, if the tracks go over non-routable paths, then tracks will be your only option for following a prior way someone went. You'll have to get one in your hands and try using it to find out what you like the best, as everyone has their preferences. Personally, I like routes with audio alerts for turns whenever possible, but that's just me.
02-24-2013, 04:43 PM
#43 | |
Oddometer: 28
(although the montana doesn't have audio "stock" I think it can be added simply with a bluetooth doogle--not that I'm running helmet speakers anyway). Trying to choose my first GPS and it's a bit overwhelming.
02-24-2013, 07:44 PM
#44 | |
Oddometer: 79
The Zumo is better suited for using routes, compared to the Montana. The Montana is better suited to use tracks, compared to the Zumo. (The Montana can use routes, but there are some constraints). Routes will provide you with turn-by-turn instructions (on both units). Tracks have the advantage that they never get recalculated by your GPS. The Zumo includes Bluetooth, for wireless communication with your helmet headset (if you use a Bluetooth headset to receive audible directions). The Montana's base includes hardwire audio output that can be connected to a Bluetooth transmitter or hardwired into your helmet communicator. With my last Zumo (a Zumo 550), when you were routing using routes, you could search for various points of interest (like gas stations or restaurants) located along your travel path. I assume the Zumo 660/665 still have this capability. The Montana does not allow you to perform these searches while using routes (unless you want to re-route yourself to the location of that gas station or restaurant). |
02-25-2013, 06:13 AM
#45 | |
Sure, why not?
Oddometer: 16,137
