Old 02-14-2013, 07:57 PM   #53941
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,562
Originally Posted by kenny61 View Post
add a usb charger port
hmmmm... Is that version 4 that I see on the horizon?
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 02-14-2013, 07:58 PM   #53942
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
Originally Posted by Cjsgptx View Post
Any of you guys ever had your XR run like it is missing? When I start mine it just seems like it takes forever for it to warm up and even when i put it on no choke, it sounds like it is missing and sometimes dies. Any ideas? Air filter is good. Has gasoline, lights and horn works. Only thing is, i cant seem to get my spark plug socket down in there to get it out. I am using a 5/8" sparkplug socket. Is thier a special size i dont know about? I am a noob with this bike so take it easy on me!
Chris
You need a thin-wall spark plug socket, such as the one Honda "used" to supply in the tool kit. You can get the "official" spark plug socket from Honda. It's part #2 in the following diagram.
The spark plug socket is Honda part #89216-MJ1-000, and it sells for $14.45. I'm sure you can get an aftermarket socket which will also work.
Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil
Old 02-14-2013, 08:01 PM   #53943
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
Originally Posted by mendoteach View Post
The dash is looking good. Keep it up! Maybe you'll make one to fit the Voyager. Hopefully, Trailtech comes out with a fully map, color version one of these days. The market is ready!
Spud, D-Ray is legit! I just watched the oil changing one. SWEET!
X2 on the dashboard, Red!
D-Ray is a good ol' boy; I would love to go riding with him!
Spud
Old 02-14-2013, 08:04 PM   #53944
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
Definitely add a USB port, and anything else you can think of! I'm designing a mount for a Trail Tech Vapor I plan to install on my "new to me," CRF250X. Do you plan to secure the mount to the handlebars bolts?
Spud
Old 02-14-2013, 08:06 PM   #53945
Cjsgptx
Dirt Junkie
Oddometer: 442
Spud
Thanks Spud! Any way to help me about my bike running like shit?
Current Bike: 2008 XR657L
Looking for a Cop Glide! You know, 'Cop Motor, Cop Suspension".
I deserve the best, anything less is unacceptable.
Cjsgptx is offline   Reply With Quote
Old 02-14-2013, 08:20 PM   #53946
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
A poorly running engine can be caused by problems in one of the four, following areas.
1) Spark
2) Fuel
3) Air
4) Compression
It's hard to tell what is causing the problem until you do some testing. I would start with the spark plug, but you need a new socket before you can remove it.
Are the jets clean in your carburetor? Have you cleaned the air filter? Does the bike have good compression?
Spud
Old 02-14-2013, 08:20 PM   #53947
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,023
Chris
You need either the spark plug wrench that came in the stock tool kit, or something like this special socket from Motion Pro.
The spark plug is 18mm, but because of how deep it is in the head, and some other obstructions on the head you can't get a standard 18mm spark plug socket down to it. You need a thin wall design. The tool kit spark plug socket can be ordered from your favorite Honda dealer, or you can buy the one pictured and linked above. My parts book lists part # 89216-MJ1-000 for the Honda tool. There may be other options but I don't know what they are. I would also note that about 2007 or 2008 Honda quit including the tool kit on the bike when new. You now have to buy it separately if you want it.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 02-14-2013, 08:45 PM   #53948
ONandOFF
Must / takeit / easy
ONandOFF's Avatar
Location: Harrisonboiig; Shenandoah Valley riding wonderland
Oddometer: 4,383
Originally Posted by ADV BUM View Post
If there was anytime you could afford Giantloop stuff, now is the time. They are improving/ changing models so some stores have the old stock on clearance. I just picked up the older mojavi. I already had the coyote. Mojavi is great for everyday stuff, but if your really camping or traveling off the bike the coyote holds much more.
And the Great Basin holds even more!
What's the best place to buy this stuff on sale?
Let's ride!!!
- No offense, but there've been a lot of people over time who were just as sure, but got it wrong.
- Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad.
ONandOFF is offline   Reply With Quote
Old 02-14-2013, 08:46 PM   #53949
Sierra Thumper
Oddometer: 641
Question Is a Sudco FCR41 flatside pumper carb worth the upgrade on an internally stock motor?
A friend has a Sudco FCR41 flatslide pumper carb for sale.....I was thinking of picking it up, but I wanted to know from you guys what performance gains I would get on an internally stock motor. I have a Uni filter, desnorkeled and cut air box, full exhaust and the stock carb with Daves Mods. Will the FCR give me any more overall power than the stock carb?
I'm not sure I want to go through the carb swapping effort unless I can get more power......I'm happy enough with the throttle response of the stock carb that I don't want the hassle of changing over just for that.
C'mon pumper guys, lead me down the right path
Also, would I need to get a different throttle or cables? And I'm assuming I'd need an adapter or 2 of some kind to mount the carb up?
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 02-14-2013, 08:47 PM   #53950
ONandOFF
ONandOFF's Avatar
Oddometer: 4,383
Originally Posted by elsalvadorklr View Post
... something we forget entirely is that all of us ADD weight, be it skidplate, bar risers, barkbusters, bigger pegs, racks etc...
Not watching out diet...
OOPS Red beat me to it again
Let's ride!!!
Old 02-14-2013, 08:49 PM   #53951
joexr
joexr's Avatar
Oddometer: 729
Not more power , just more instant power thru better throttle response.
joexr is online now   Reply With Quote
Old 02-14-2013, 08:52 PM   #53952
ONandOFF
ONandOFF's Avatar
Oddometer: 4,383
Originally Posted by Sierra Thumper View Post
I guess I'm the exception the only weight added to my bike is the skidplate.......but the stock rockguard had to come off for it. Besides that my bike is minus some stock parts, and other parts have been replaced with lighter aftermarket stuff. My bikes ALL dirt bike......well as close as a street legal dualsport can get
Just me, my machine and my backpack
That makes two of us, so I guess you're not THE exception.
Let's ride!!!
Old 02-14-2013, 08:53 PM   #53953
Brown Falcon
Mossy-Back
Brown Falcon's Avatar
Oddometer: 704
Chris
For mine I use a deep 18mm socket, a 3/8 u-joint, and a long extension. Works for me.
Evan
Ooh-Rah! Once a Marine, always a Marine!
'93 XR650L (Xena)
Brown Falcon is offline   Reply With Quote
Old 02-14-2013, 08:55 PM   #53954
Brown Falcon
Mossy-Back
Oddometer: 704
http://www.atomic-moto.com/this_months_bombs.html
They are having a sale on Giant Loop stuff right now.
Evan
'93 XR650L (Xena)
Old 02-14-2013, 08:58 PM   #53955
Sierra Thumper
Oddometer: 641
Spud
I have a pretty good selection of tools, but the spark plug socket that comes in the honda tool kit is the easiest one to use for getting the spark plug out easily imo. If I didn't have one, I'd pick it up
Times are GMT -7.   It's 05:08 PM.
