Old 02-15-2013, 06:59 PM   #12121
mechahayai
Oddometer: 142
Is that an FH008?
mechahayai is offline   Reply With Quote
Old 02-15-2013, 07:41 PM   #12122
GSPD750
GSPD750's Avatar
Oddometer: 1,468
Originally Posted by mechahayai View Post
Is that an FH008?
It's actually the FH020AA. More here at an earlier post #11863
Anyhow...I just finished the install and am quite pleased. Fired it up
and it was still putting out 14.4 vdc with grips and lights on. One of
the old connectors ( 3 wires/3 phase yellow) had evidence of overheat but no real damage.
That connector gets changed with the new generation Delphi connector from Eastern Beaver (see pic).
Those are the only 3 wires you solder for the whole install and then it all just snaps in.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 02-16-2013, 07:27 AM   #12123
mechahayai
Oddometer: 142
How did the final install go? IIRC the 12 and 20 are a bit taller. I believe Jim originally installed an FH008 on is AT as it is closest to the stock size. I picked up an FH008BA and hope to do a direct plug and play, but it's going to take a little tinkering to get it there.
Old 02-16-2013, 10:33 AM   #12124
GSPD750
GSPD750's Avatar
Oddometer: 1,468
I thought the FH008 had the same foot print and mounting holes as the 0012/0020 and it's the 0010 and 0011 that are taller? Anyhow, the 0020 that I installed now supercedes the 0012 which has the same dimensions and specs but with some minor changes to the heat sink casting.
The 0020 fit nicely on my RD07A as you can see in the pic. Notice the old white round connector in the middle which is not used now. I blanked off the inside with a plastic plug. Tie wrapped below that is the new Delphi 3 yellow wire connector (no particiular order). The hole you see between green and white connector was where the old 3 yellow wire connector lived. That connector gets tossed and was prone to overheat and high resistance.
To the left and in front of the starter relay you can see the new 30 amp fuse holder and the black and red wire that now go directly to the battery.
In the end their are a total of 5 wires that you need to pinch and solder (3 phase yellow) and the 2 pos/neg wires to the battery. I say "pinch and solder" because that was my method as I did not have a fancy crimper.
Carefully bend the wire tabs over with some small needle nose pliers followed up with a dab of solder. Jim has a link here.
pinching and soldering
This is an easy and worthwhile mod IMO and certainly a preventative one if your running old connectors that could can be prone to high resistance and eventual meltdown. The MOSFET is more effecient and produces less heat at the R/R so that the mounting/cooling is not so much an issue anymore.
GSPD750 screwed with this post 02-16-2013 at 12:56 PM
Old 02-16-2013, 12:27 PM   #12125
mechahayai
Oddometer: 142
That looks good. Thanks for the pic. Mine is a 7 wire set up so it's a bit different.
mechahayai screwed with this post 02-16-2013 at 03:27 PM
Old 02-18-2013, 12:04 AM   #12126
gkam
gkam's Avatar
Oddometer: 68
Can these R/R charge a lithium battery?
gkam is offline   Reply With Quote
Old 02-18-2013, 06:04 AM   #12127
SulytS
Oddometer: 6
THIS IS BRILANT...
Originally Posted by GSPD750 View Post
Hello Alain...sounds like you had a great trip in the Andes. I would like to hear about it someday. Well it's +8C here today and I'm putting my soldering/crimping skills to work with the installation of the Mosfet R/R into my AT.
Hopefully it will look like Jim's from Eastern Beaver. His pic.
My task today is to install the following.
SulytS is offline   Reply With Quote
Old 02-18-2013, 12:48 PM   #12128
GSPD750
GSPD750's Avatar
Oddometer: 1,468
I don't see why not but I'm still digesting all that lithium battery stuff. Their certainly is a considerable amount of weight to be saved thats for sure.
See links below...yeah....to much to read. Therefore I'll stick with the proven lead/acid/AGM technology for now.
Shorai Motorcycle Battery vs. Ballistic Motorcycle Battery Comparison - webBikeWorld
http://www.batterybusiness.com.au/products/lithium
Shorai LFX14A1-BS12 Battery - 129.95
Ballistic Battery 12V LiFePO4 8 Cell EVO 2
Vehicle Replacement Batteries for Motorcycles, ATV, Watercraft, Snowmobile, Utility Vehicle
Ballistic Battery 12V LiFePO4 EVO 2 Review - YouTube
Ballistic Battery EVO2 Review at Motochanic.com - YouTube
Shorai Lightweight Motorcycle Battery Review - Make your motorcycle 4 pounds lighter. - YouTube
Old 02-23-2013, 08:25 AM   #12129
ROYMACNIC
Oddometer: 64
Shock rebuild
Hi, anybody in the UK had an RD04 shock rebuilt? I've got a few possibilities to have this done but was wondering if anyone had any recommendations,where you have had a good service or anybody that should be avoided,thanks, Roy.
Roymacnic
ROYMACNIC is offline   Reply With Quote
Old 02-24-2013, 05:48 AM   #12130
La Case
La Case's Avatar
Oddometer: 45
many news on the official Africa-twin TRIP public page ;)
like it if you use FB we need to have a lot of followers to ask sponsorings
https://www.facebook.com/tripmoto2013
Next trip 2013 France -> Turkey
La Case is offline   Reply With Quote
Old 02-24-2013, 05:51 AM   #12131
La Case
La Case's Avatar
Oddometer: 45
Me and my Half-build AT Rallye, 'll be paint soon
Old 02-24-2013, 09:33 AM   #12132
Stormforce8
Farkle Tart
Stormforce8's Avatar
Oddometer: 543
This is an RD03 shock that was completely rebuilt back to new by Clarence at PLR Suspension. Excellent chap who really knows what he's doing
Before
After
www.ruggedroads.com
2000 Honda XRV750 Africa Twin RD07A - Rugged Roads Rallye Sport,
2002 Honda XRV750 Africa Twin RD07A - RWB
1989 Honda XRV750 Africa Twin RD04 - HRC
'Maybe I'm just simple - but can't we all just get along..........'
Stormforce8 is offline   Reply With Quote
Old 02-24-2013, 12:17 PM   #12133
ROYMACNIC
Oddometer: 64
Thanks for that Stormforce8,thats just what I'm looking for.
Roymacnic
Old 02-24-2013, 11:46 PM   #12134
The Apostle
The Apostle's Avatar
Oddometer: 29
960cc AT ???
I found an advertisement for a used AT converted to 960cc with the use of a crank (not sure if translation is OK) from Varadero. Is that possible ????
The Apostle is offline   Reply With Quote
Old 02-25-2013, 12:05 AM   #12135
Schelbi
Schelbi's Avatar
Oddometer: 200
Where is the advertisement? If it's in Germany I can check translation for you.
1975 Honda CB550 Four 1980 Honda CX500 dual sport conversion
1983 Honda XLV750R 1983 Honda XL600R
1983 Honda CB985FII Bol d'Or 1983 MZ ETZ250 sidecar
1985 Honda XL600LM 1988 Honda NX650
1989 Honda XL600V Transalp 1992 Honda XRV750 SW-Motec 1995 Husqvarna TE610
Schelbi is offline   Reply With Quote
Times are GMT -7.   It's 03:40 AM.
