Old 02-07-2013, 07:59 PM   #31
Navin
Navin's Avatar
Oddometer: 7,657
I just gutted my whole air box. If you aren't worried about off road, pod filter it and jet/tune for it.
The engineers knew best? Bah! The federal government designed the friggin intake and exhaust!
Navin is offline   Reply With Quote
Old 02-07-2013, 08:06 PM   #32
Fictitious
Fictitious's Avatar
Oddometer: 202
Originally Posted by It'sNotTheBike View Post
Probably because the OP imagines the trained engineers who designed the air intake
botched the job, though those engineers had access to a dyno and more than likely spent
many hours making sure the airflow was optimized for the resonant cavity of the air box,
( think of Helmholtz and you will be on the right track).
How likely is it that the engineers did a bad job and someone who needs to ask how
best to cut holes in the air box will do a better job ? Sort of like leaving an orangutang
in front of a typewriter and waiting for the sonnets of Shakespeare to be produced
( don't hold your breath waiting for anything intelligible to come out of that typewriter ).
The goals of the engineers might differ from the goal of the OP. It is possible to tune the same engine differently to get different characteristics. I'm not saying going around drilling random holes in things is the way to go, but if you can manage to shove more air and fuel into an engine in the correct mixture, you will get a bigger boom and more power. Whether or not this produces undesired results by way of reduction of fuel economy, airbox noise, etc... is irrelevant; none of those things are (hopefully) the goal of the OP.
On the dyno comment, you do realize that the reason most people cut holes in their airbox is that they've purchased a jetting kit which requires larger airbox holes work properly? Most companies who make these kits such Dynojet or JD, also have access to dynos, and their results against the stock power curves can be seen.
Anyway, to answer the OP's original question, use a holesaw to cut out the corners then use a heated razor blade to cut nice straight lines between the holes. Optional is some sort of sanding wheel for cleanup after. You can see it illustrated here on a DRZ400S https://www.youtube.com/watch?v=VtKWbs0N5lo
Stuff, as well as things
Fictitious is offline   Reply With Quote
Old 02-07-2013, 09:03 PM   #33
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,536
Originally Posted by Ricardo Kuhn View Post
Regardless of been a good idea or not, like making holes on a piece of plastic just for fun..
You can use stainless steel mesh like this and some pop rivets to add effect.
Nice "effects" but I have never seen that screen in SS.I could use some. I sure have quite a bit of that in Aluminium, some of the old satellite dishes were made of it. Works great with Devcon for roadside repairs.
Have tools, will travel!
Old 02-08-2013, 07:49 AM   #34
kantuckid
Oddometer: 2,927
Are you a hotrodder by chance?
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85
kantuckid is offline   Reply With Quote
Old 02-08-2013, 07:53 AM   #35
Ohlinspro
We sell all brands!
Ohlinspro's Avatar
Location: Near Six Flags Great Adventure in "God's country"
Oddometer: 337
652165265
6552162+6
Ohlinspro is offline   Reply With Quote
Old 02-13-2013, 08:23 AM   #36
seniorasi
Oddometer: 816
Can't we all just "Get along"?
seniorasi is offline   Reply With Quote
Old 02-13-2013, 08:42 AM   #37
Smoke Eater 3
Oddometer: 660
I prefer a step bit. But if you use a hole saw run the drill in reverse for a cleaner hole. It takes longer because its not as aggressive.
Smoke Eater 3 is offline   Reply With Quote
Old 02-13-2013, 09:38 AM   #38
sledgegreen
Oddometer: 12
I have used auger bits to make neat holes in plastic.
sledgegreen is offline   Reply With Quote
Old 02-17-2013, 06:01 AM   #39
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,408
Hole saw works best, deburr with a Burr-Kwik sheet metal deburring tool. SOUND is the biggest compromise in airboxes. Intake noise can be louder than exhaust.
I'm with the "keep it intact as designed" group.
Old 02-17-2013, 09:48 AM   #40
anotherguy
anotherguy's Avatar
Oddometer: 6,207
BTW making holes in the lid on the outside of the filter doesn't change the Hemholtz. But it does move the anti-resonance. Tread lightly.
Old 02-17-2013, 11:53 AM   #41
DirtyBlackIrish
DirtyBlackIrish's Avatar
Oddometer: 153
Originally Posted by groundrules View Post
you don't sound as smart as you think you sound.
I second that!
Semper Fidelis
DirtyBlackIrish is offline   Reply With Quote
Old 02-17-2013, 12:33 PM   #42
triplenickel
triplenickel's Avatar
Oddometer: 2,426
All you guys swinging from the engineers nuts have never worked with one have you?
07 SE
PG007
Old 02-17-2013, 01:57 PM   #43
itsatdm
itsatdm's Avatar
Oddometer: 4,818
Before any one turns the air box into swiss cheese, consider that the next obstacle is the size of the venturi of your carb.
Old 02-17-2013, 03:12 PM   #44
Fixnfly
Fixnfly's Avatar
Oddometer: 344
I just can't believe there are now 3 pages on how to drill a hole in plastic
01 DRZ400S 93 GSXR750 13 Z1000
Fixnfly is offline   Reply With Quote
Old 02-17-2013, 05:25 PM   #45
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,408
Nope. No manufacturing exposure at all. Building custom machinery. At all. Ever.
Times are GMT -7.   It's 01:25 AM.
