Old 02-17-2013, 10:32 AM   #3286
kb7tgr
Oddometer: 58
No after market tail
I simply removed the funny lower fender and the license light and put a 1 inch strap on for a plate holder. No money and looks great.
kb7tgr
Jim
kb7tgr is offline   Reply With Quote
Old 02-17-2013, 10:38 AM   #3287
gaan
Oddometer: 8
Originally Posted by CRFSoCal View Post
Is that the best dual sport crf? It looks good. The muffler looks a little darker then the one i have more or a grey then a silver.
yes it is. added a nomadic rack, replaced the dirt only tires with Dunlop D606 DOT legal tires and ordered a front sprocket guard. here's a larger pic. the muffler is the blue titanium with the carbon fiber end.
gaan is offline   Reply With Quote
Old 02-17-2013, 11:11 AM   #3288
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Originally Posted by Mk5mike View Post
Sure did
That's wonderful. How did you discover them?
Spud
Old 02-17-2013, 12:51 PM   #3289
CR250R
StllSmokin
CR250R's Avatar
Oddometer: 15
How did some of you manage to mount the white side plate with aftermarket exhaust? I assume its some sort of bracket, does anyone sell them?
CR250R is offline   Reply With Quote
Old 02-17-2013, 12:54 PM   #3290
gnath9
gnath9's Avatar
Oddometer: 281
The FMF has mounting brackets welded on
gnath9 is offline   Reply With Quote
Old 02-17-2013, 05:42 PM   #3291
Telemarktumalo
Go Red Sox!
Telemarktumalo's Avatar
Oddometer: 379
I notice that your exhaust has no heat shield like the OEM. I have a Giant Loop Coyote bag and it drapes across the plastic cover and part of the aluminum heat shield. Do you carry any overnight gear?
Originally Posted by gaan View Post
.... the muffler is the blue titanium with the carbon fiber end.
Telemarktumalo is offline   Reply With Quote
Old 02-17-2013, 07:58 PM   #3292
CRFSoCal
Oddometer: 43
It looks amazing. Where in socal are you located? -Is that muffler a special order then from FMF?
CRFSoCal is offline   Reply With Quote
Old 02-17-2013, 08:02 PM   #3293
Mk5mike
Mk5mike's Avatar
Oddometer: 308
Spud
Actually Craigslist. And today I got to ride this morning around mt Shasta dam and then came back to my duty station in Lemoore and plan on going up past Oakhurst to go ride up there
Mk5mike is offline   Reply With Quote
Old 02-17-2013, 09:01 PM   #3294
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Good for you! I also discovered that dealership on Craigslist.
I also found a local Honda dealership selling the bike for MSRP, without adding any bogus charges. A dealership in Orem, Utah is doing the same.
Spud
Old 02-17-2013, 09:58 PM   #3295
G19Tony
G19Tony's Avatar
Oddometer: 418
Spud
Monarch Honda, in Orem is where I got my bike. MSRP OTD, no other fees. It was totally worth the drive from Vegas.
BMW F800GT, Hodaka Dirt Squirt, Honda CT70, Honda Grom, Zongshen RX3
G19Tony is offline   Reply With Quote
Old 02-17-2013, 11:14 PM   #3296
gaan
Oddometer: 8
According to Best Dual Sports, it's the only Q4 blue titanium with the carbon end cap that FMF makes. I also have the Powercore but it doesn't look as nice. ;) I'm in Walnut.
Old 02-18-2013, 05:52 AM   #3297
Avi8tor
ADV Poser
Avi8tor's Avatar
Oddometer: 218
Originally Posted by Ed@Ford View Post
New topic...CRF windshields....I've seen at least one inmate here using the TCI Products Windscreen and brackets....Has anyone bought the brackets and made their own windscreen? To me the TCI windscreen is a little bit tall and dorky. I've made unique windscreens for my KLR, BMW Dakar, and V Strom, but used existing attachment points...but there's nothing to start from on the CRF.
National Cycle Spitfire...cheap and works well. This is a carry over from my DR-Z. It sits a little high on the CRF, but still works well.
CURRENT: None
PAST:
2013 CRF250L - 2009 DL650 - 1997 GL1500SE - 2005 DR-Z400S - 2008 DL650A - 2008 ST1300 - 2009 KLR650 - 2002 DR-Z400S - 1987 RM 250 - 1980 KD-80
Avi8tor is offline   Reply With Quote
Old 02-18-2013, 08:06 AM   #3298
G19Tony
G19Tony's Avatar
Oddometer: 418
Could you show me more of your ADV monster lights? I have a set on my Versys, and I want to put a set on my LRP. How did you mount them, and which ones did you get? Thanks.
Old 02-18-2013, 10:54 AM   #3299
Avi8tor
ADV Poser
Avi8tor's Avatar
Oddometer: 218
These are model 44s. I used the two top bolts for the headlight shroud. They barely fit without rubbing the turn signals and are able to point straight ahead. I did have to buy an extra flanged washer for the left side to get a solid mount. They have not moved since I put a little blue thread locker on them.
Parts needed were two longer bolts and one flanged washer.
CURRENT: None
PAST:
Old 02-18-2013, 01:22 PM   #3300
G19Tony
G19Tony's Avatar
Oddometer: 418
That's great. Thank you. They look perfect there.
Times are GMT -7.   It's 05:26 AM.
