Old 02-18-2013, 11:07 AM   #1
Sam Bateman OP
Oddometer: 16
Question for You 1-Piece Suit Users
How do you route the cord for electric vests and such out from inside your 1-piece?
Is there a pass-through pocket or something similar?
I've got an Olympia Phantom and if there is such a pocket I haven't been able to find it.
Never had the need to use the electric vest under this thing until this Winter.
Sam Bateman
Arvonia, VA
Sam Bateman is offline   Reply With Quote
Old 02-18-2013, 11:12 AM   #2
srpuywa
Big 'G'
srpuywa's Avatar
Oddometer: 451
aerostitch one piece has zippered pocket
IBA 53683
09 R1200 GS ADV
srpuywa is online now   Reply With Quote
Old 02-18-2013, 11:50 AM   #3
Bubba Bauer
Bubba Bauer's Avatar
Oddometer: 156
http://www.webbikeworld.com/heated-m...jacket-review/
If that fits underneath or something similar with an inbuilt powersource.
Or if you want to get even slimmer surfers use heated vests as well whith the added benefi of being waterproof .
Bubba Bauer is offline   Reply With Quote
Old 02-18-2013, 09:14 PM   #4
10/10ths
Road Trip Fool
10/10ths's Avatar
Oddometer: 937
New 'stich...
...and retro-fit option for old 'stich is a dedicated jumper wire pass through for heated gear.
I have had it retro-fitted to two Roadcrafters.
Works great!
1997 Ducati Monster 750
2004 Honda RC51
2011 Suzuki GSX1250FA replaced my '04 Wee 2-14
10/10ths is offline   Reply With Quote
Old 02-19-2013, 12:04 AM   #5
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,255
Sam Bateman
Arvonia, VA
On your phantom. Get another #8 YKK molded tooth zipper pull. (You may want to get two and do both legs.) You can order those from Seattle Fabrics, if you can't find someone local to you that has them. Take a pair of wire cutters and cut the two little plastic stops at the bottom of the leg zipper off. The stops that prevent the zipper pull from running off the end of the zipper. Now run the pull down the leg and right off the end of the zipper. Reverse the pull and put it back on, with the wide end of the pull pointed up the leg. Now put your new pull on oriented the way the original pull was, narrow end pointed up the leg. The narrow end of the two pulls should face each other. Now get a needle and thread and make several loops around the zipper tape, at the end of the zipper, on each half. Your replacing the bottom stops with thread so the zipper pulls don't pull off. Or Seattle Fabrics also sells replacement bottom stops if you prefer.
Now you should have a double pull Zipper. (What Olympia should have put on there to start with.) You should be able to zip down the top of the zipper a few inches, stick you cord through, and then zip it up tight around the cord.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 02-19-2013, 11:57 AM   #6
AMSBIKER
AMSBIKER's Avatar
Oddometer: 76
I have a joe rocket survivor suit. I put a small hole in one of the pockets on the left thigh area and threaded a gerbing extention lead thought it. It pops out through the normal pocket zip which closes 99.9 percent and the pocket flap locks over that. I kept it in the pocket when not in use. The inner part just plugs into the gerbing jacket as usual. Never had any problems with water leakage.
AB
AMSBIKER is offline   Reply With Quote
Old 02-21-2013, 06:57 AM   #7
Sam Bateman OP
Oddometer: 16
I Appreciate All the Replies
I'm leaning towards the putting a hole in the back of the pocket thing right now.
Although that zipper modification would also work nice.
Sam Bateman
Arvonia, VA
Times are GMT -7.   It's 10:30 AM.
