Old 02-19-2013, 04:02 PM   #1
D.T. OP
Difficult but useful
D.T.'s Avatar
Oddometer: 11,416
Talking Smart phone question...
I didn't want to ask this question in Jo momma, so I'll toss it in here.
I just got a LG smart phone and I was wondering if there are any apps or software for it to be able to use the USB cable to use my laptop screen to surf the web.
I found something on the LG website but I don't have internet for my laptop to down load it yet.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. screwed with this post 02-19-2013 at 05:45 PM
D.T. is online now   Reply With Quote
Old 02-19-2013, 04:13 PM   #2
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,314
Originally Posted by D.T. View Post
I didn't want to ask this question in Jomamma, so I'll toss it in here.
Coward!
"Shiney Things" would be appropriate.
HapHazard is offline   Reply With Quote
Old 02-19-2013, 04:17 PM   #3
wsmc831
wsmc831's Avatar
Oddometer: 776
You could always just get a free app that lets your laptop use your phone as it's ISP.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is online now   Reply With Quote
Old 02-19-2013, 04:57 PM   #4
It'sNotTheBike
Oddometer: 704
I just got a LG smart phone and I was wondering if there are any apps or software for it to be able to use the USB cable to use my laptop screen to surf the web..
What you want to do is called "tethering".
In a "tethering" scenario your laptop uses your phone to transmit and receive
data to and from the internet via the cell phone's radio connection to cell towers
which then connect to a server run by the cell company, etc.
Your cellular provider probably has restrictions on tethering, and for good reason :
a laptop can use a lot more data than a cell phone typically will. If your cellular contract
allows tethering you can probably find software for your phone which enables such
use. Google can find the software in a few clicks. If your cell phone contract prohibits
tethering you should look into the implications of using the phone in a manner which
is prohibited by the terms of your contract. It can get expensive, and your cell provider
definitely will discover you are doing this, because they employ very smart people to keep
an eye on their networks for reasons just such as this.
Assuming your cell provider does allow tethering, unless your cell contract allows
unlimited data use you should be careful that you don't use more than the amount of data
transfer allowed you per month under the terms of your contract. If your usage exceeds the
allowed amount of data you could find yourself with a phone bill that is significantly larger
than you are accustomed to paying.
It'sNotTheBike screwed with this post 02-19-2013 at 05:13 PM
It'sNotTheBike is offline   Reply With Quote
Old 02-19-2013, 05:44 PM   #5
D.T. OP
D.T.'s Avatar
Oddometer: 11,416
Yeah, I could have put it in ST, but...
Nice answer It's! Tethering eh? Cool. I have unlimited web and data on a no contract phone.
There is something called PC sync I was going to try (bottom right hand corner)
PC Sync To synchronize your phone with your PC via a USB cable, you need to install the LG PC Suite program on your PC.
D.T. screwed with this post 02-19-2013 at 05:50 PM
Old 02-19-2013, 05:57 PM   #6
Garp
Garp's Avatar
Oddometer: 2,445
You need to read the small print and make sure you know what your carriers version of unlimited really means. Very few carriers allow truly unlimited usage, most will throttle you after somewhere between 1 GB and 5GB of data in a month. After that you can continue to download, but it will be at very limited speeds. They don't cut you off, but they make it so slow that you won't want to keep going.
Garp is offline   Reply With Quote
Old 02-21-2013, 09:45 AM   #7
muguvian
lugrubious
muguvian's Avatar
Oddometer: 102
For what you're wanting to do you need something like PDANet+. PCSync is not a connection to any networks, just connecting your phone as an external drive.
muguvian is offline   Reply With Quote
Old 02-21-2013, 10:21 AM   #8
D.T. OP
D.T.'s Avatar
Oddometer: 11,416
Thumb
Working on the pdanet stuff, thanks! Having some problems so far. Probably going to buy the full version.
D.T. screwed with this post 02-21-2013 at 10:28 AM
Old 02-21-2013, 10:54 PM   #9
D.T. OP
D.T.'s Avatar
Oddometer: 11,416
Thumb
Whelp, I went to the library today and brought my laptop. Tried to download the PDAnet software but I needed my cable to connect my phone which I didn't bring. Plus my laptop is old and battery lasts about 20 minutes on battery power. So I take out the flash drive and use the library computer to save the PDA software. Just got home about 1/2 hour ago, install the PDA program, hook up the cell phone and wa la I have internet on my laptop!
Thanks guys for the help! Didn't cost me anything, I didn't need the full version either.
Old 02-25-2013, 03:55 PM   #10
EJSCC2
Oddometer: 15
FoxFi - creates wifi zone
On Androids - I have used EZTether, but switched to FoxFi... it creates a local wifi zone and is quite simple to set up and get going... don't need to download anything to the PC.
Recently, the developer changed and does not allow a trial. You may not find it under Google Play --- most cell providers want to hide apps like this, but this is EXACTLY what the Android operating system was built around, so you may have to search in Google --- not in Google Play --- to find it.
I purchased it for $7 or so and it works fine. Much easier than physically tethering by USB cable, and can support multiple PCs streaming Netflix (when I am able to get 4G coverage from Sprint --- when not in 4G mode, there is quite a bit of buffering).
Good luck.
EJSCC2
Birmingham, AL
EJSCC2 is offline   Reply With Quote
Old 02-25-2013, 04:03 PM   #11
troidus
Oddometer: 15,463
This sounds like you want to hook an external display to your phone. I see that that's not what you intended, but that could be cool in its own right.
troidus is online now   Reply With Quote
Thread Tools
Times are GMT -7.   It's 12:35 PM.
