02-20-2013, 06:49 AM
#15931 | |
Oddometer: 491
But, if you put on a lot of miles, gas can add up, and the more expensive gas gets, the faster it does. On the bike, 5000 miles / 45mpg = 111.1 galons of gas X $4/gal = $444 per 5k miles. In my truck, that same 5000 / 14 = 357 X 4 = $1,428. So, as I see it, that's about $1000 savings for every 5000 miles I'm driving. (That's assuming you're not just out riding for fun, which you may not do in your car.) The way I look at it, a $10k bike would pay for itself in 50k miles, but then there's the added benefits of having a fun 'toy' or 'hobby', and not just a means of transportation that is also an expense.
-Lee |
02-20-2013, 07:25 AM
#15932 |
armchair asshole
Oddometer: 2,558
The most worthless thing you can spend money on is gas. Even if you come out not saving much money by using a motorcycle for your main mode of transport you are going to be wasting less money on gas. I'd rather have my money go to something more tangible. Additionally we all lose when gas consumption is high as the prices go up (and then the prices of everything goes up) so you are doing the economy a better favor by spending your money on "real" goods.
02-20-2013, 07:40 AM
#15933 | |
Oddometer: 633
I also agree with the other poster that in many cases other consumables are a wash. I believe the poster that brought the commuting question up said he had a 4runner. (Did I get that right?) While you can get a set of 4 car tires for $500, when you get truck tires it will easily hit $1000, my lexus (with stock tires) costs me $1600 a set. While those tires will last 40k, the $250-$300 set of bike tires will last 10k each. Geof |
02-20-2013, 08:08 AM
#15934 | ||
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,397
Awesome bike. You'll love it. --mark EDIT: Regarding tires, you can make smart choices here too to save money. For example, running a set of Full Bores (M-41 front, M-40 rear; these are very similar to Shinko 705s but I've found they last a little longer) costs you about $125 a set. The rear tire will last you around 6000 miles, maybe more. The front, easily twice that, so you only need to replace that with every other rear. So we're talking about $200 in tires every 12,000 miles or so. Probably a wash with car tires, but cheaper than truck tires.
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe My ride reports: Missile silos, Labrador, twisties, and more Bennington Triumph Bash, May 31-June 2, 2013 markbvt screwed with this post 02-20-2013 at 08:31 AM |
02-20-2013, 08:43 AM
#15935 | |
Tigers R great.
I've read that you really shouldn't use an oil that's thinner than recommended because the engine and all the clearances in it (like the plain main bearings) have been designed for a particular viscosity of oil to hold the two surfaces apart. Some cars use 0W-30 but I would let that near my Tiger. Still it's your choice and your money so YMMV applies. Just don't moan at Triumph if your engine goes POP.
2002 Tiger955i in black, 68500 miles. 2012 Tiger800XC in black, 19000 miles. Bike history [(N) = bought new] :- YAS1, RD350B(N), XS750(N), XT500, XJ650(N), XJ900S(N), CBX750, XL185S, XR250RF, XR600, 600LC4, TDR250, R100GS, TS200R, Tiger955i(N), Scrambler900efi, Tiger800XC(N)... |
02-20-2013, 09:06 AM
#15936 |
Oddometer: 491
In regards to oil, isn't fork oil a standard viscosity (i.e., 5W), not variable? That makes a bit of difference when comparing to motor oil.
With motor oil, both 5W-30 and 10W-30 are still a 30W oil once up to operating temp. The difference between the 5 and 10 is the cold viscosity. So, the 10W would be 'further from ideal' in cold temperatures, but only when first starting up. The 5W should provide better lubrication (because it's more viscous) at start up, but both 5W-30 and 10W-30 should be equal once up to temp. At least, that's the way I've always understood it. Am I wrong? Link - http://www.upmpg.com/tech_articles/motoroil_viscosity/ In a car I used to have, it recommended 0W-30, but I would use 5W-30 (OK as an alternative via the manufacturer) in the warmer months, and it seemed to be fine. When I'd go to the track, some guys even ran 5W-40, which they claimed help manage engine temps.
-Lee |
02-20-2013, 09:29 AM
#15937 |
armchair asshole
Oddometer: 2,558
02-20-2013, 09:46 AM
#15938 |
Tigers R great.
No, you're completely wrong. You can get anything from 2.5 to 20 weight of fork oil.
02-20-2013, 09:48 AM
#15939 | |
Oddometer: 1,842
APPLICATIONS AMSOIL Synthetic 10W-40 Motorcycle Oil is recommended for liquid or air-cooled 4-stroke engines. It meets SAE 80W/90, API GL-1 gear oil requirements and is recommended for transmissions on both 4- and 2-stroke motorcycles. AMSOIL MCF is recommended for Honda®, Kawasaki®, Yamaha®, Suzuki®, BMW®, Husqvarna®, Victory® and other motorcycles where 10W-40 or 20W-40 engine oils or SAE 80W/90, GL-1 gear oils are used. Not recommended where an API GL-4 or GL-5 gear oil is required. http://www.amsoil.com/shop/by-produc...otorcycle-oil/ i hate oil discussions. its way to opinionated!!!
Ride 365 LLC Braaaap! fbj913 screwed with this post 02-20-2013 at 09:56 AM |
02-20-2013, 09:49 AM
#15940 |
Tigers R great.
Well all I can say is good luck. After all, it's your bike making the rattling noise, not mine.
02-20-2013, 09:51 AM
#15941 |
Oddometer: 124
02-20-2013, 10:04 AM
#15942 | |
armchair asshole
Oddometer: 2,558
Rotella T6 is one of the most commonly used synthetic oils by motorcyclists. Been using it for a long time including track use. My thinking of the rattling noise was more along the lines of perhaps a valve(s) becoming out of tolerance. |
02-20-2013, 10:16 AM
#15943 | |
PIN IT & BANG GEARS
Oddometer: 2,510
![]() I have also estimated the cost of owning the RV is about $12,000 a year. I guess we all have differing priorities. I have four other cars and the 3 bikes. Seems like I spend my money 'real good'.
Chris Brown - "The Browneye" ![]() http://www.stewardsofthesequoia.org/ • Grand Canyon Adventure Ride 2012 Laguna Seca 2012 RR • Sequoia 3-Day Campout • Thanksgiving 2012 |
02-20-2013, 10:22 AM
#15944 | |
Oddometer: 491
-Lee |
02-20-2013, 10:40 AM
#15945 | ||
Oddometer: 491
-Lee |
